I passed!
Old Jan 17, 2008 | 10:57 PM
smitty124's Avatar
I passed!
Well, after my EPIC e-test failure last month
I spent the last few weeks fixing a bunch of stuff.
I replaced:
PCV & EGR valves, CTS sensor, 02 sensor, plugs, air filter, cat converter
did a seafoam flush and switched to synthetic oil (which virtually stopped my vtc clack)
repared/replaced rear manifold/y-pipe studs/gaskets..
unrelated: replaced engine mounts & F&R brakes.. :P
anyhow, this managed to bring all 3 test levels down to passing range! (I can now register my max and drive it again!)
The CO and NO readings were reducted bigtime. Actually all 3 were! HC ppm went from 221 down to 58. But still, 58 is the limit! (Damn! that was close!) Im wondering if theres anything else I can do to bring that result down?
I still have abit of a rough idle (all injectors work) im thinking it could be coil packs.
Anyway, im just glad I have a car again! I doubt the $450 repair limit on the original would have accomplished much.
Old Jan 17, 2008 | 11:13 PM
ColombianMax's Avatar
Congrats, who'd ever expect Canada to be so green...
Old Jan 18, 2008 | 07:55 PM
sonicii's Avatar
HC is probably Hydrocarbons, which is just unburnt fuel, so it could be too much fuel being injected, or a bad coil pack causing in incomplete burn.
Although a new Cat converter should have cleaned this up for you if it was at full operating temp when the test was done, unless there was a lot of unburnt fuel before the cat??
Old Jan 18, 2008 | 07:59 PM
Dhunterx's Avatar
Well, he did say his idle is still rough, which could be an ignition problem, resulting in unburnt fuel. If replacing the coil packs fixes his idle, it might fix the HC #. (Silly emissions tests. )
Old Jan 22, 2008 | 06:53 AM
smitty124's Avatar
so basically it's running to rich? And the rough idle is the result? would resetting the ECM help any? (it hasnt been done and i've changed/replaced a bunch of stuff. )
Old Jan 22, 2008 | 05:51 PM
internetautomar's Avatar
mod or sell?
have you checked your timing?
is the IAC clean?
Old Jan 22, 2008 | 10:19 PM
How do you check timing on a VE btw? I only know how on vg
Old Jan 22, 2008 | 10:51 PM
505max94se's Avatar
The same way that you check timing on most any other engine.
Old Jan 22, 2008 | 10:55 PM
by 'check' I was also hoping you guys were able to read my mind and acknowledge that I meant check/adjust lol woops
Old Jan 23, 2008 | 08:52 AM
mod or sell?
you check it by using a timing light and a modified spark plug wire.
Old Jan 23, 2008 | 10:41 AM
BenStoked's Avatar
Jesus was a Zombie.
next obvious Q: how do you adjust it?
Old Jan 23, 2008 | 11:07 AM
505max94se's Avatar
All newer timing lights that i've used do not require you to use a modified spark plug wire. They will pick up the signal before the coil.
Old Jan 23, 2008 | 11:08 AM
505max94se's Avatar
by rotating the cps
Old Jan 23, 2008 | 12:54 PM
mod or sell?
that may be, but the other way we know for sure works, is specified in the FSM, and is more trustworthy to me
Old Jan 23, 2008 | 01:17 PM
Greeny's Avatar
¯\(°_o)/¯
+1
The procedure for this is in section EC...sub-section EF & EC-180/EF & EC-181
Old Jan 23, 2008 | 01:35 PM
505max94se's Avatar
That's understandable.
Mar 12, 2020 12:06 AM
09maxshawn11
Sep 30, 2015 10:28 AM
hntwhttail
Sep 12, 2015 03:43 PM
