New dilemma
Old Jan 23, 2008 | 07:32 AM
Mr.Davon24's Avatar
New dilemma
There are a few things going weirdy on my baby pearl
1st My transmission no longer goes in reverse
2nd I have an exhaust leak in either them IM or before the flex pipe.
3rd My (e) brake light ( on dash ) stays on for some weird crazy reason.
My question for the semi-experts is how hard would it be to correct these problems?
I am some what mechanically inclined and can be coached to getting the job done.
I know a lot of people would reply with the ve5 swap but, I read that it is not as easy as it sounds. I don’t want to let my baby down. Can someone please shed some light on the ole girly I call Pearl?
Old Jan 23, 2008 | 07:49 AM
Greeny's Avatar
¯\(°_o)/¯
1st..Your transmission is going out..Replacement/rebuild/or manual swap are your only options.
2nd..exhaust leak at the IM?..Do you mean EM(exhaust manifold)?Either way your going to have to crawl under the car while it's running to verify where the leak is coming from.
3rd..Does the brake light stay on even while the car is off(keys out of the ignition)?
Old Jan 23, 2008 | 08:15 AM
Mr.Davon24's Avatar
Yes, the EM. Yeah I am going a lil abbreviation happy. As for the brake light nah it goes of when the car is off. The emergency brake still works properly car doesn’t budge when it’s engaged.
Old Jan 23, 2008 | 08:41 AM
Greeny's Avatar
¯\(°_o)/¯
you might have corrosion on the tail light bulb assembly,use search to find threads about "tail light bulb corrosion"
btw..the regular forum search is turned on for all users now,no more google search..
Old Jan 23, 2008 | 08:56 AM
LvR's Avatar
LvR
................As for the brake light nah it goes of when the car is off. The emergency brake still works properly car doesn’t budge when it’s engaged.
This is a safety issue and should not be happening - ie - the brake lights MUST still be working when the car is switched off - if its not somebody screwed with your wiring and this needs to be fixed too.
If the brake light stays on when releasing the brake pedal then the brake switch is either maladjusted or has a burned together set of contacts.
Old Jan 23, 2008 | 09:22 AM
internetautomar's Avatar
mod or sell?
brake light on dash not on rear end
if the dash light is on, you may need a new master cylinder because it doesn't have the correct pressure according to the sensor on it.
that being said we had a 78 camaro that always had the brake light on, bought it that way and sold it that way. Brakes worked fine probably a bad switch on the master
Old Jan 23, 2008 | 09:27 AM
Mr.Davon24's Avatar
^^^ Inter.Am.^^^ My brakes does work fine. Sometimes it goes off also special if I drive it until it's warm.
Old Jan 23, 2008 | 09:30 AM
Reece616's Avatar
from what i understand, the "e-brake light" on the dash is staying on, correct?
if so, you should probly check ur brake fluid and probly brake pads too.
if it's the actual brake lights (tail lights) then I think someone already said something about that...
Old Jan 23, 2008 | 09:37 AM
Pearl93VE's Avatar
I can has?
+1. Always check this first, it is almost always the culprit to the light being on in the car. I didn't bother checking mine because it was so close to being the right amount of fluid, but apparently that less than an oz. of fluid made the light come on when I turned too hard and stuff.
Old Jan 23, 2008 | 09:41 AM
mod or sell?
as an addendum, there is a switch that may be stuck by the E-brake lever that is reading always on as well which would trigger the light too.
Old Jan 23, 2008 | 09:52 AM
Mr.Davon24's Avatar
Oh, ok thanks guys. My simple **** didn't even bother to check that.
Old Jan 23, 2008 | 09:54 AM
Greeny's Avatar
¯\(°_o)/¯
I missed that also..
Old Jan 23, 2008 | 04:41 PM
ColombianMax's Avatar
As Maxshima said, check the brake fluid, if low.. fill to "MAX" line. If after several pumps if the light is still on...you probably have a bad ground for the ebrake.
NyCzBuBBa
Mar 12, 2004 04:18 AM
TitaniuMax03
Mar 1, 2004 03:09 PM
phenryiv1
Nov 11, 2002 01:57 PM
Ironlord
Jul 31, 2002 10:06 AM
MaxedOut2g
Sep 10, 2001 06:36 PM
