Car won't start (Clicking!!)
Old 01-22-2008 | 07:24 PM
Lumberg™'s Avatar
on this site too damn much
Ok so I got my girlfriend a 3rd gen max tonight but now the thing won't start. There's no power at all when I try to start it on its own but when I hook it up to my car with jumpers I get all the lights on in the dash and the headlights will turn on but when I go to start the car, all it does is make a clicking sound. I'm guessing its the battery but I don't want to go out and buy a battery and then find out its the starter or alternator.
What do you guys think it is?
Thanks!
Old 01-22-2008 | 07:30 PM
Greeny's Avatar
¯\(°_o)/¯
Pull the starter,have a local autozone or other parts store test it.
Old 01-22-2008 | 07:40 PM
LvR's Avatar
LvR
I would first physically change the battery with a known good one from the car you used to jump the Max with - if it then still refuses to turn over, then starter removal should b the next step as Greeny said there
Old 01-22-2008 | 07:43 PM
BenStoked's Avatar
Jesus was a Zombie.
to me it does sound like a battery.
check the terminals make sure they arent loose.
also check the terminals on the starter solenoid for good connection, as well as the ground terminal on the block.
a bad connection on the battery (loose negative) caused this for me...
Old 01-22-2008 | 08:07 PM
Lumberg™'s Avatar
thanks guys... where's the starter located in the 3rd gen?
oh and the positive connector was loose but I tightened it after I parked my car and the car was just dead, no power. I'm guessing it is the battery then but why the clicking when I connected my car to it?
Old 01-22-2008 | 08:20 PM
Greeny's Avatar
¯\(°_o)/¯
As mentioned prior,you might want to swap a known good battery into the car before going any further.
Old 01-22-2008 | 08:35 PM
Lumberg™'s Avatar
think i'll give that a shot tomorrow when i get home from work.... thanks guys
CapedCadaver's Avatar
Call me Wookiee Goldberg
also make sure that the problem isn't the NSS. i had to call my bro for a jump a month after i bought the car, only to have the thing start right up when he got there and said "show me what it's doing".
Old 01-22-2008 | 08:45 PM
Lumberg™'s Avatar
NSS??
Old 01-22-2008 | 08:51 PM
Mike90SE's Avatar
NSS??
Neutral Safety Switch
Also, make sure the connections at the battery are clean. As in, no corrosion of any kind. Have seen many a batteries replaced because of this.
Old 01-22-2008 | 08:56 PM
Lumberg™'s Avatar
where's the NSS and how do I know if it's causing the problem? Is this the switch to take it out of park if the key isn't in the ignition? This is an auto by the way.
Thanks again guys! I'm heading off to bed but will check back in the morn.
Old 01-23-2008 | 07:20 AM
Mr.Davon24's Avatar
I had this problem recently * thanks greeny by the way * Anyway as everyone suggested change out the battery first. I did that and had the old one tested there was a cell dead. Swapped in the new battery a vola. Also check to see if your connection is loose and or a build up around the terminals.
Old 01-23-2008 | 07:40 AM
Lumberg™'s Avatar
Yeah gonna do the swap when I get home from work today and hopefully that does the trick.... Thanks guys and I'll keep ya posted
Old 01-23-2008 | 08:59 AM
internetautomar's Avatar
mod or sell?
another option is to undo the battery cables from the battery and hook the jumper cables up to them directly without the battery. if it cranks then the battery is shot, otherwise I'd check the starter.
BTW cheap jumper cables are worth their weight in **** when it drops to 0 outside.
Old 01-23-2008 | 09:08 AM
Lumberg™'s Avatar
^^ hmmm good idea man. Yeah I think my jumper cables are pretty sh*tty cause my gf's mom gave me them in some car breakdown package. It was around 35-40 last night and I think it's around 45 right now so maybe they're ok.
Old 01-23-2008 | 09:24 AM
mod or sell?
that sounds plenty warm to me. we're at 9*f right now.
Old 01-23-2008 | 09:31 AM
Mr.Davon24's Avatar
LOL TRUE INDEED. I found that out the hard way to.
Old 01-23-2008 | 10:46 AM
Lumberg™'s Avatar
oh wow I thought you were referencing temps in celcius.... anyways, i tried hooking the jumpers up to just the cables removed fromt he batter and still got the clicking sound and no start. Once I take the cables off, the car has NO power at all. Can't even get the key out.
Should I still try to swap the batteries or is more than likely something else? What should be my next step?
Thanks guys.
Old 01-23-2008 | 11:00 AM
Brudda Bob's Avatar
Thanks guys.
Swap the battery as suggested before with one thats RATED/POWERFUL enough to start the car.
The fact that your battery cannot even power your accesssories indicates it's "completely dead"
Old 01-23-2008 | 11:11 AM
Lumberg™'s Avatar
I'm gonna swap it with my battery ('99) but why wouldn't it have started when I hooked it up to just the cables separated from the battery like someone suggested above. I'm just hoping its not a starter problem. Where is the starter located by the way so I can try tapping it to see if that might help.
Thanks!
Old 01-23-2008 | 11:16 AM
Pearl93VE's Avatar
I can has?
Thanks!
What Engine? VE or VG? Auto or Manual? You can pretty much find it by looking...... Starters are kind of distinctive...
Old 01-23-2008 | 11:26 AM
Lumberg™'s Avatar
it's a 92 auto but not sure on the engine.... it doesn't have the black middle piece on the trunk so I'm guessing its a GXE from what I remember about 3rd gen's.
Old 01-23-2008 | 11:40 AM
BenStoked's Avatar
Jesus was a Zombie.
what color are the gauges. thats the usually the most obvious difference.
btw
vg has distributor.
Old 01-23-2008 | 12:08 PM
Lumberg™'s Avatar
they aren't white so I guess it's a GXE which means its a vg right?
Old 01-23-2008 | 12:48 PM
Mr.Davon24's Avatar
does it have color matched mirrors, crome trim, or even what does your speedo go up to????? If mirrors are color matched it a GXE correct me if I am wrong.
Old 01-23-2008 | 12:55 PM
Lumberg™'s Avatar
it's a gxe.... i'm done work in a little so I'm gonna go try to clean the terminals and if that doesn't work, swap the battery with mine. The cars parked illegally cause when I got it towed it was dead and there was no parking anywhere so I had to push it onto the curb. That's why I want to get this thing started and moved into a spot. It doesn't even have tags yet! And I still need to fix the brake master cylinder so it will stop! yikes
Old 01-23-2008 | 12:59 PM
Greeny's Avatar
¯\(°_o)/¯
btw
vg has distributor.
Folks,he bought tigga the don's car..It's a 92 gxe auto..
http://forums.maxima.org/showpost.ph...2&postcount=17
The starter is located on the front of the transmission bell housing,right in front of the cooling fans(kinda toward the bottom of the rad fans)
Old 01-23-2008 | 03:17 PM
Lumberg™'s Avatar
thanks guys and yeah I bought Mike's car last night for my girlfriend.
I just brought the battery to Pep Boys to test it and it was at 200 amps and it charged and tested good all the way to 500 amps. Bought a terminal cleaner as well, cleaned the terminals, put them on, and it started right up. Sounded a little hesitant though when it was on and kinda sounds like a belt is loose (maybe the alternator?). Well next, I'm gonna try to get the alternator off (is there a right up on how to remove this and where its located?) and get that tested next. Anyone in the Philly area wanna come by and help??
Old 01-23-2008 | 03:21 PM
Greeny's Avatar
¯\(°_o)/¯
Take a look around your engine bay dude,,all the item locations you are inquiring about are all in plain site if you actually look under the hood..
Old 01-23-2008 | 04:27 PM
Pearl93VE's Avatar
I can has?
+1. The alternator is in plain sight below the A/C compressor. You shouldn't really need a write up, it has bolts you can visibly see holding it on, and a wiring harness, unbolt the bolts, and disconnect the wiring harness
Old 01-23-2008 | 05:04 PM
Lumberg™'s Avatar
It would be nice if I actually knew what an alternator or a starter looked liked? I'm mechanically inclined I just don't know where to start
Old 01-23-2008 | 05:07 PM
Greeny's Avatar
¯\(°_o)/¯
http://images.google.com/imghp?hl=en&tab=wi
type in "alternator"..Then type in.."starter"
Old 01-23-2008 | 05:08 PM
Pearl93VE's Avatar
I can has?
But seriously dude....
google search...
starter
http://images.google.com/images?svnu...=Search+Images
alternator
edit: hah, Wayne beat me to it...
Old 01-23-2008 | 06:03 PM
Lumberg™'s Avatar
thanks guys... i think i was just being lazy So the alternator is just held on with some nuts and bolts? Is there anything I have to disconnect? Is it easy to get to and get off?
-Alex
Old 01-23-2008 | 06:06 PM
AllMaxxedOut's Avatar
The same thing happened to my 3rd gen. But the alternator was not charging the battery so when it shut off it did the same clicking at time to start and wouldn't turn over. I would have alternator checked as well to make sure it is charging the battery.
Old 01-23-2008 | 06:16 PM
Lumberg™'s Avatar
^^^ that's what i'm gonna do next. Take it off and bring it to pep boys to get tested.
Thanks guys!
By the way, anyone in the philly area know how to change a brake master cylinder? And how do I know if I have ABS?
-Alex
mod or sell?
VE alternator:
VE A/T starter:
next question..
Old 01-23-2008 | 06:17 PM
mod or sell?
Thanks guys!
-Alex
look at the passenger front corner of the engine bay, if you see a spider of metal lines you have ABS
Old 01-23-2008 | 06:29 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks guys!
-Alex
take a look at this sticky..
http://forums.maxima.org/showthread.php?t=296859
Old 01-23-2008 | 07:33 PM
BenStoked's Avatar
Jesus was a Zombie.
y'know a haynes or chiltons is only like $30 or so, and are filled with photos.
worthwhile investment to add to the info available here
but, yeah, im lazy too, and would prefer to find the info online...
Quick Reply: Car won't start (Clicking!!)
