dohc Steering Rack
Old Jan 24, 2008 | 01:30 PM
rev2red's Avatar
dohc Steering Rack
is there anyway it would fit on to the sohc motor?? thanks
Old Jan 24, 2008 | 02:11 PM
Greeny's Avatar
¯\(°_o)/¯
They are the same on both models,so yes it will fit.
Old Jan 24, 2008 | 02:35 PM
maxitech's Avatar
I've heard in the past that the SE steering rack (from both VG's and VE's) has a slightly quicker ratio. Any 3rd gen rack should work in all 3rd Gens, tho...
Old Jan 24, 2008 | 03:10 PM
GRNMAXDMON's Avatar
isn't the VE SE rack stiffer than the VG rack?
Old Jan 24, 2008 | 03:12 PM
Greeny's Avatar
¯\(°_o)/¯
They have the same part # folks
Old Jan 24, 2008 | 07:39 PM
internetautomar's Avatar
mod or sell?
they are 100% identical, inside and out.
there are however differences in the pump which can also alter the way the steering feels.
Old Jan 24, 2008 | 08:37 PM
Mike90SE's Avatar
The racks may be the same, but I can tell ya that the hoses are different. LOL
Old Jan 25, 2008 | 06:51 AM
VEvolution's Avatar
I miss my VE
My GXE steering felt smoother then the SE
Old Jan 25, 2008 | 07:06 AM
Greeny's Avatar
¯\(°_o)/¯
My gxe's steering is also much smoother/easier to steer vs. my se's steering,I believe the gxe steering pump has more "push" so to speak then the se's pump,from a performance standpoint,you want to "feel" the road more,in which a lower volume steering pump will help in this case.
Old Jan 26, 2008 | 06:25 AM
VEvolution's Avatar
I miss my VE
Thats why the steering feel on sports cars is pretty heavy.
Old Jan 26, 2008 | 09:23 PM
JC93SE's Avatar
The part numbers ARE different. Two different ones listed for the GXEs, and one for all SEs. Different part numbers for pumps too, but says based on engine, not model- can't figure the difference by looking at the listing.
The GXE is a lot easier to "one-hand", but I miss the road feel of the SE.
Old Jan 27, 2008 | 01:57 AM
Greeny's Avatar
¯\(°_o)/¯
I am not referring to dealership part #'s(yes,dealer lists them as different),I am referring to all aftermarket part #'s.
Old Jan 27, 2008 | 06:34 AM
mod or sell?
it's like struts the dealer lists multiple #s but in the end they are all the same.
Old Jan 27, 2008 | 07:12 AM
JC93SE's Avatar
Is it that they really are the same, or that parts stores/suppliers/remanufacturers only want to stock (or rebuild) one part to keep it simple for them. It wouldn't be the first time that people could only buy what was being sold, and that their cars never were "quite the same" after the part was replaced with a "one part fits all". Often the answer is "close enough" for them.
Old Jan 27, 2008 | 08:12 AM
mod or sell?
yes it is the same.
the ratios are identical.
Old Jan 27, 2008 | 08:15 AM
JC93SE's Avatar
Guess it's really the pump that makes the difference, then?
Old Jan 27, 2008 | 08:18 AM
mod or sell?
correct, the pumps do vary and that is where the feel typically comes from on most cars.
Old Jan 27, 2008 | 09:16 AM
traxtar944's Avatar
Would be lost w/out the org
but an SE Power Steering pump cannot fit on a GXE, can it? Or should I say, a VE on a VG?? I've always wanted to tighten up the steering on the GXE, and eliminate the play in the wheel...so this thread is interesting to me.
So far, the only thing I did was get a smaller diameter steering wheel to change the ratios. It helped immensly, but hasn't eliminated the play. If someone could source a smaller volume steering pump that would work on the VG to give a tighter feel, it would be great. What about using a 300zx pump and swap out the pulley? Would that work? Is it even an improvement?
Old Jan 27, 2008 | 09:44 AM
mod or sell?
a VG SE pump will fit any VG, but expect to replace the accompanying hoses at the same time.
Old Jan 27, 2008 | 01:17 PM
goon9's Avatar
ALL VE PUMPS FIT VG'S!
ALL VG PUMPS VE'S!
And you don't need to change the lines, unless you are trying to get ppl to buy your parts.
Old Jan 27, 2008 | 02:46 PM
mod or sell?
interesting...
Old Jan 27, 2008 | 04:17 PM
Greeny's Avatar
¯\(°_o)/¯
ALL VG PUMPS VE'S!
Do you have a link to this info?
Have you installed a vg pump on a ve engine?or vise versa?
Just wondering...
Old Jan 27, 2008 | 05:01 PM
mod or sell?
I've got some research to do tomorrow at work
Old Jan 27, 2008 | 05:39 PM
goon9's Avatar
Just wondering...
I've had a gxe reman pump on my 90se, I currently have a 93se pump on it. The lines all match up, and the pump are identical.
Old Jan 27, 2008 | 06:13 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks tim,thats good to know,now i don't have to be VE specific at teh junkyard..
Old Jan 27, 2008 | 06:42 PM
Mike90SE's Avatar
While all hoses and pumps are interchangeable, the hoses are routed differently from a VG to a VE. It will work, but as I just completed this swap, the VE hoses are tucked in tighter and give a bit more room than if you try to use the VG hoses on a VE engine. But goon9 is correct, the pumps are identical as far as mounting goes. Not sure about the pressure though. My swap was SE to SE, so........IDK.
Old Jan 31, 2008 | 12:13 PM
traxtar944's Avatar
so putting a VE pump on my VG wouldn't give me a tighter steering response, since the pumps are identical.
Old Jan 31, 2008 | 12:32 PM
Greeny's Avatar
¯\(°_o)/¯
They are not "identical" so to speak..but each will mount up and work according to goons info.
It has only been speculated in this thread about the flow differences,maybe good can chime in as to the difference in feel from one to the other?
Old Dec 5, 2008 | 08:48 AM
maxitech's Avatar
I'd like to renew some interest in the subject of GXE steering feel vs. SE steering feel. I have always thought my GXE could use less power assist. Apparently there are no complaints about this from the SE crowd.
So it seems that the whole thing comes down to pump rates, yes?
Old Dec 5, 2008 | 08:59 AM
Greeny's Avatar
¯\(°_o)/¯
Yeah, that would be my guess, the lines and all seem to be identical between the two systems, but the power assist ratio between the two cars are very different.
Old Dec 5, 2008 | 10:47 AM
maxitech's Avatar
I wonder if it is the actual pump, or maybe the pulley diameter? It would be great if all it took was a pulley swap.
Old Dec 5, 2008 | 10:57 AM
Greeny's Avatar
¯\(°_o)/¯
The pulley diameter looks identical between the two..
Old Dec 5, 2008 | 11:11 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
is the 'difference' in feel engine-specific (all VG vs all VE) or trim-level specific (VE & VG-SE both vs GXE)?
Old Dec 5, 2008 | 11:16 AM
Greeny's Avatar
¯\(°_o)/¯
I can only account for the VE vs. gxe vg feel= night/day.
Old Dec 5, 2008 | 11:50 AM
maxitech's Avatar
Hmm...Who has extra pumps and feels like tearing them down in the name of technical information?
Old Dec 5, 2008 | 12:01 PM
aaron92se probably WOULD...... except whenever he starts selling his VE stuff after his VQ is running i already called dibs on his VE PS pump.... sawwy. i can do an external comparison of them tho when i switch them.. if that helps any.
i think i may have found the answer
rack = same
http://www.courtesyparts.com/maxima-...1715_1721.html
pump is VE vs VG (within that, normal susp vs SONAR)
Old Dec 5, 2008 | 12:52 PM
mrkanda's Avatar
Taking my Maxima to the Max!
ALL VG PUMPS VE'S!
That may be true, but how the line fits may be in question. I have an '89 GXE with the "boosted" PS pump. After it went bad due to a leaking rack I installed a different pump which did not have the electronic "booster" on it. I assume it was a pump from an SE (VG or VE, I don't know). Because of the location of the arm on the original pump which housed the "boost sensor" the high pressure hose was bent at a 90 degree angle at the pump, but the new SE pump required a straight line to the connection. My solution was to tweak the existing hose and install it backwards. It seems to work without any leaking or affect in performance, other than the stiffer turning feel you all speak of because of the lower steering boost pressure. Therefore, there is some difference in the shape and fitment of the different pumps. I will also change that HP Hose if its current routing ever becomes a problem. Otherwise, more feel -> more fun
I'll also try to post pics of the different pumps that I took when I was swapping them out.
Hope that helps.
-Mrkanda
P.S. My GXE does originally have the Sonar Suspension II setup.
Which leads me to another question- did the Sonar Susp include speed variable steering assist, thus the reason for the sensor?
Old Dec 5, 2008 | 12:59 PM
Hope that helps.
-Mrkanda
yes. GXE w/sonar is the original pump you had. VE is another. everything-else is the third (VGSE and all no-sonar GXE)
Old Dec 6, 2008 | 12:02 AM
mrkanda's Avatar
Well, I think I must have a VESE pump considering how stiff it feels now. I think that is good for performance, but I did like how easy it was to turn at slow speeds with the original Sonar GXE pump. I may just buy a rebuild kit and fix the original one. That way I can turn the hose back around the right way and reconnect the sensor. Would it still give the lower sensitivity at higher speeds if it's speed variable, and if so is that what is good for performance driving? Thanks.
-Mrkanda
Old Dec 29, 2008 | 09:52 AM
300zmax's Avatar
Stupid question but curious,
Is there alot of differece in a SE VQ rack or has anyone put a an SE power rack from a VQ into VG or VE car?
