Intake manifold/injectors questions
Old Feb 9, 2008 | 02:32 PM
Deridex's Avatar
I've posted a thread about my **** poor gas milage (14 mpg) before and some people suggested that replacing some O-rings, hoses, and injectors might remedy the problem among other things. I never had a reason to really mess with any of the internal engine parts, so I'm a noob at this. Due to the reason stated in the previous sentence, I decided to practice on the engine from my parts car, which I stripped to the frame a few weeks ago. So now I got a few questions (below the pictures).
How to pull injectors off the rail without it ending up looking like that?
I heard there are supposed to be two O-rings, yet all injectors I pulled seemed to only have the one.
Is there a way to clean the cylinders of that gunk without actually taking apart the whole thing? And what is that part called?
Should I use carburator cleaner to take care of this, or is there something else I should use?
Is this worth cleaning?
Also, can any of the gaskets be reused or do I have to replace them all? And is there difference between hoses, like high/low pressure? If so, what kind should I get for the fuel rail?
Old Feb 9, 2008 | 04:50 PM
ColombianMax's Avatar
1. Best way to get those injectors out is to let them soak with some PB Blast then gently turn em side to side from the top with channel locks, if they dont move AT ALL, spray from more. Be sure to do this when the top cover is off which is 2 screws, I prefer to use vicegrips on those since they strip easily.
2. They do have to o-rings at least my gfs 89 did...
3 I used some carb cleaner, for both the Throttle body and the inside of the manifold.
TIP, if you're gonna have the plentum off, its good to replace the valve cover gaskets and all vacuum hoses, unless you know its been changed or gaskets arent leaking a single drop.
Old Feb 9, 2008 | 05:27 PM
Deridex's Avatar
Alright, that helps a bunch. Thanks dude.
internetautomar's Avatar
mod or sell?
injectors:
there is a lower o-ring on the injector which may have gotten stuck in the rail. to get them out you tap the tips and they pop out eventually.
Old Feb 9, 2008 | 05:43 PM
BenStoked's Avatar
Jesus was a Zombie.
video of injector removal courtesty greeny
http://www.viddler.com/explore/MyGreenMax/videos/5/
Old Feb 9, 2008 | 06:07 PM
Deridex's Avatar
That'll work. Also is there a reason AutoZone sells injectors for $99 a piece? Sounds like BS to me.
Old Feb 9, 2008 | 06:11 PM
BenStoked's Avatar
Jesus was a Zombie.
remans, avoid.
as internetautomar says, they usually do a half *** test to make sure they spurt fuel, and send em out. they dont take intermittent coil shorts, worn valves, etc into consideration.(paraphrased, brian...)
go new, and save some headache later(an empty pocket and stomache now is better, cause you can fill the wallet with paper and your stomach with water.)
Old Feb 9, 2008 | 06:16 PM
mod or sell?
price sounds about right.
the question is which ones are they.
Remans are worrisome, and if it's a 89-92 VG. There are several companies boxing a really crappy new one that had a high failure rate when I tried them for a customer a while back.
I'll stick with what I know works and only requires the job to be done once.
Deridex's Avatar
Originally Posted by benstoked
remans, avoid.
I'll keep that in mind. Well said by the way.
Old Feb 9, 2008 | 08:46 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
so like, what if you plan to re-use an injector? does that method kill it or not harm it?
Old Feb 9, 2008 | 11:07 PM
coolsun's Avatar
hey is it required to replace the throttle body gasket
Old Feb 9, 2008 | 11:09 PM
Its usually a good idea considering most will be original gaskets
Old Feb 10, 2008 | 01:37 AM
Hectic's Avatar
http://www.viddler.com/explore/MyGreenMax/videos/3/
http://www.viddler.com/explore/MyGreenMax/videos/4/
Old Feb 10, 2008 | 01:47 AM
Greeny's Avatar
¯\(°_o)/¯
junk in the trunk..
Old Feb 10, 2008 | 01:51 AM
Greeny's Avatar
¯\(°_o)/¯
IMHO, their really is no point in going to that stage on injector removal without replacing the injector, but if really need reuse the injector just use something with a soft end to smack the injector out.
Old Feb 10, 2008 | 02:42 AM
Now thats what I'm talking about, the kinky stuff! thats the real way to spice things up AND THEN post the video on the org
btw what was the purpose of that video Wayne?
Old Feb 10, 2008 | 06:12 AM
mod or sell?
only if you are taking off the throttle body, which you don't need to do.
Old Feb 10, 2008 | 06:13 AM
mod or sell?
it was to show how the car reacted to the 3rd rear sway bar mount he added.
Old Feb 10, 2008 | 08:09 AM
Obsession_92-94's Avatar
How would it have normally acted?
Old Feb 10, 2008 | 10:34 AM
I'm assuming those 2 vids are before and after so I'll take a shot at saying like the first video
Old Feb 10, 2008 | 11:21 AM
Alex_V
Ive used 10mm deep well sockets before to get good injectors out.
~Alex
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
