VE SSSIM
Old Feb 9, 2008 | 02:55 PM
505max94se's Avatar
VE SSSIM
I'm thinking about removing the "shelf" in my VE's IM plenum to gain some extra top end power. For those of you that don't know, the VQ35 guys do this and gain ~12whp in the higher rpms, but they lose some low end power. Has anybody done this before? What do you guys think about this?
Old Feb 9, 2008 | 02:58 PM
MrGone's Avatar
Lot of work, use a 5spd manifold
If you want to be insane, smooth out the casting in the runners (or the whole thing if you want :eek3: )
Old Feb 9, 2008 | 03:04 PM
505max94se's Avatar
It shouldn't be too much work. I have plenty tools for grinding and cutting metal.
Either manifold would work because they both have the shelf. The 5spd manifold just has a moving plate to simulate one common plenum for all 6 runners to increase top end power. The plate is closed for low end power and it opens for top end power.
Instead of being insane, maybe I'll just send it to extrude hone.
Old Feb 9, 2008 | 03:07 PM
505max94se's Avatar
BTW, this is top secret information that's why it's called the SSIM (Super Secret Intake Manifold).
Old Feb 9, 2008 | 03:42 PM
Thanatos's Avatar
COOOL A SECRET!
Old Feb 9, 2008 | 08:07 PM
MrGone's Avatar
yes, but the 5spd one has a rear access cover where the automatic does not
Old Feb 9, 2008 | 08:10 PM
MrGone's Avatar
I knew about it when Matt first started doing it to VQ35's, it's only secret because most people on this forum aren't familiar with finessing motors. It's essentially the difference between a single and dual plane intake manifold for a small block pushrod V8, except the results aren't as great.
Old Feb 9, 2008 | 09:06 PM
505max94se's Avatar
Yes, but if I were to do it, I'd cut off the rear piece off, remove the shelf, and then weld a flat piece of aluminum back over the hole.
I was looking at my extra upper plenum and the design is horrible. It would be awesome if I could somehow make on 00VI fit on a VE.
I knew about it when matt first started doing it too. I just thought that it was funny because nobody could figure out what he had done to the IM that made him so much power. Then people started calling it the SSIM. lol.
Old Feb 10, 2008 | 06:02 AM
internetautomar's Avatar
mod or sell?
don't forget to notch the dual plane divider to pick up a couple more ponies
Old Feb 10, 2008 | 06:11 AM
xx-Marshall-xx's Avatar
kthxbye2u
Wouldn't you have to basically cut the thing in half, take what ever you want out. Then weld it back together.
Old Feb 10, 2008 | 06:16 AM
mod or sell?
cut the end off and cur from there
Old Feb 10, 2008 | 06:36 AM
harmbone2k2's Avatar
6yrs old=36,500 miles :)
'Secret Sauce' > super secret.
Old Feb 10, 2008 | 09:53 AM
Alex_V
I thought it was Secret Sauce as well (I do alot of lurking in the all motor/turbo sections).
Oh and 505 I have a VE-5 IM laying around if your interested.
It'd be pretty cool to see a dyno difference between the two. Do VEs fall off near/at redline? I thought they had pretty good top end.
~Alex
Old Feb 10, 2008 | 10:51 AM
505max94se's Avatar
Old Feb 10, 2008 | 11:14 AM
505max94se's Avatar
I knew that it was secret something... lol
I do alot of lurking there too. I spend most of my time there.
No thanks, I have an extra one sitting in my garage.
~Alex
Yeah, I'd like to a see a dyno comparison as well. Maybe I'll do just that.
I don't think that they fall off much at all near redline, but if you extend the rev limit, I'm sure that there's some power to be had.
Old Feb 10, 2008 | 11:15 AM
505max94se's Avatar
Old Feb 10, 2008 | 11:32 AM
MrGone's Avatar
For the VE it shall be called the Super Secret Sauce Intake Manifold for it's unrivaled greatness.
Old Feb 10, 2008 | 11:33 AM
505max94se's Avatar
SSSIM
Old Feb 10, 2008 | 11:34 AM
MrGone's Avatar
SSSIM
sweet
Old Feb 10, 2008 | 11:51 AM
Alex_V
hmm I need to do it to my VG. But I have ALOT of work before I get it driveable again :cry:
That includes a pass. axle and input shaft bearing among other things, other wise Id just go do it now...
YSIM for the VG (Yummy sauce IM that is :P)
~Alex
Old Feb 10, 2008 | 12:08 PM
mod or sell?
sssweet
free fix
Old Feb 10, 2008 | 01:38 PM
505max94se's Avatar
sweet
@ title edit
Old Feb 10, 2008 | 02:43 PM
Pearl93VE's Avatar
I can has?
~Alex
How much do you want for it?!
Old Feb 10, 2008 | 09:47 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
~Alex
wouldn't a jeremy-style custom IM work better on a VG though? granted it's more work...
Old Feb 10, 2008 | 11:39 PM
505max94se's Avatar
Yeah, if you're boosted. Although, a proper custom NA manifold should make some nice gains.
Old Feb 11, 2008 | 08:39 AM
Jeff92se's Avatar
I'm needing a caw
Wouldn't it be easier just to use the Auto Ve manifold?
Old Feb 11, 2008 | 10:35 AM
505max94se's Avatar
I was kind of thinking the same thing, if I were to cut open the manifold and weld it back together. It'll be a pita either way.
I just really want an 00VI
Old Feb 11, 2008 | 11:18 AM
Jeff92se's Avatar
I'm needing a caw
I thought the auto didn't have all that crap inside? ie.. already gutted perse
Old Feb 11, 2008 | 11:31 AM
MrGone's Avatar
nope, autos have the divider
Old Feb 11, 2008 | 11:47 AM
505max94se's Avatar
yep, they just don't have the flapper thingy (VI)
Old Feb 14, 2008 | 04:08 AM
maximagician's Avatar
[QUOTE=MrGone;6238080]Lot of work, use a 5spd manifold ...end qoute.
on an auto ve?
Old Feb 14, 2008 | 06:28 AM
Dhunterx's Avatar
For the VG's, just try to fit the pathfinder IM under the hood.
Old Feb 17, 2008 | 04:44 AM
[QUOTE=maximagician;6245749]
on an auto ve?
no reason to put a ve 5 speeds intake with the power valve on my auto right?
