Need a favor; need a pic in the engine bay
Old Feb 10, 2008 | 05:47 PM
gapboi210's Avatar
I need a close up pic of what holds the upper radiator hose in place. Mine rubs against the cruise control servo. I have seen pics of the bay in here and it looks like there is something that holds is below the cruise control. I need a closer pic so I can see what I am looking for next time I go to the JY.(hose are usually already gone)
Old Feb 10, 2008 | 06:02 PM
Greeny's Avatar
¯\(°_o)/¯
I don't think there is a upper hose holder on the vg,or at least not on my wifes vg..
Your hose may just be worn out causing it to sag down onto the servo.
Old Feb 10, 2008 | 06:19 PM
ColombianMax's Avatar
its right next to the distributor cap cover
Old Feb 10, 2008 | 06:26 PM
Greeny's Avatar
¯\(°_o)/¯
Ok,my vg doesn't have the strap, but it also doesn't rub the cruise servo either.
Old Feb 10, 2008 | 08:24 PM
jonmandude's Avatar
There is strap there, but it still shouldn't rub. You can see it between the distributor and cruise servo. Do you have the correct hose?
Old Feb 10, 2008 | 08:58 PM
92gxe/cg2's Avatar
Yeah, when i replaced that hose i did not recall a strap on there, im pretty sure mine doesnt have it, but also theres no problems with it rubbing anything... but then again the old one had wat looked like marks from rubbing and then it burst...
Old Feb 10, 2008 | 09:31 PM
gapboi210's Avatar
it is a brand new hose. It is shaped correctly but rubs against the cruise control. I cut a piece of the old hose and covered it where it rubs until I can find that little arm.
derekinthez
Nov 13, 2022 04:00 PM
6spd4dsc
Mar 4, 2016 05:19 PM
fastcarny
Oct 6, 2015 10:42 AM
seesole
Sep 14, 2015 12:38 PM
03VQMAX
Sep 5, 2015 03:47 PM
