WIRE HARNESS PROBLEM
Old Feb 11, 2008 | 03:00 PM
Thanatos's Avatar
i dont know the firing order or piston order on this engine. but i posted on a problem i have been having for a few days now and have found out well almost found out what it is. The Story - for the past couple of days my check engine light has been coming on at random. the engine will start missing and has a rough idle and lose of power. it did it a couple of times today and finally stayed on and is running like poo. i did a couple of test when i got home and found out that the plug that plugs into the coil on the back far left is not letting the plug fire. i swapped plug and then coils and it all points to the plug itself. i only have a light tester to test hot and grounds. the plug is showing hot on the middle plug prong while running same as the rest do. i hope i am making sense. when i unpluge any other plug to the coil the engine loses power to the coil and runs like so. when i unplug the plug to the one i am having trouble with it shows no sign. so i have a plug issue right. what can i do to fix this.
Old Feb 11, 2008 | 03:15 PM
Mike90SE's Avatar
uh, you could have what they call a burnt valve. Do a compression test on all six cylinders and then post the results.
Old Feb 11, 2008 | 03:17 PM
Greeny's Avatar
¯\(°_o)/¯
Sounds like a bad injector..
Did you check the ecu for codes?
Thanatos's Avatar
why would it be a burnt valve if the problem is in the harness.
Old Feb 11, 2008 | 03:41 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i dont know the firing order or piston order on this engine. but i posted on ......... ...
1-2-3-4-5-6
1 3 5 driver side->>>
2 4 6
front of car
v
v
v
Old Feb 11, 2008 | 03:45 PM
Thanatos's Avatar
Originally Posted by capedcadaver
1-2-3-4-5-6
2 4 6
front of car
v
v
v
wow thanks for this. i really appreciate it.
Old Feb 11, 2008 | 03:46 PM
Thanatos's Avatar
ok Greeny i did the test and it says codes - 34 and 51
Old Feb 11, 2008 | 03:50 PM
Thanatos's Avatar
what does a detonating knock sensor and a fuel injector curcuit open mean.
Old Feb 11, 2008 | 03:52 PM
Greeny's Avatar
¯\(°_o)/¯
Bad knock sensor and a bad injector..
Old Feb 11, 2008 | 03:56 PM
Thanatos's Avatar
wow. so were is the best place to get new injectors. i guess i can get the knock at autozone right. i guees it would be best to replace all inj. at the same time too also.
Old Feb 11, 2008 | 03:58 PM
Thanatos's Avatar
i wonder if this could be the reason i have a rough idle after reving. what do you think?
Old Feb 11, 2008 | 04:00 PM
Greeny's Avatar
¯\(°_o)/¯
The best place to get new injectors and knock sensor would be CLICK HERE
Be prepared for a $600 parts bill for 6 new injectors..
Old Feb 11, 2008 | 04:01 PM
Greeny's Avatar
¯\(°_o)/¯
yes,a bad injector will cause a horrible idle.
Old Feb 11, 2008 | 04:06 PM
Thanatos's Avatar
hey Greeny i really appreciate you helping me on this. i just started it agian a few min ago and now it is running fine . go figure.
Old Feb 11, 2008 | 04:09 PM
Greeny's Avatar
¯\(°_o)/¯
Heh..I've had 2 injectors go out on my ve...both started out the same way as your ve is doing now...at first intermittent...then steadily worse until they stopped working altogether..
Old Feb 11, 2008 | 05:38 PM
Thanatos's Avatar
do i have to register to get any info.
Old Feb 11, 2008 | 05:43 PM
BenStoked's Avatar
Jesus was a Zombie.
send him a PM
internetautomar
Greeny's Avatar
¯\(°_o)/¯
Nope..just click on your year model on the left on the page,then follow the prompts from there..
This might make it easier for ya..
Injectors--->http://www.internetautosupply.com/ca...c41167bf939b15
Knock sensor--->http://www.internetautosupply.com/ca...c41167bf939b15
Old Feb 11, 2008 | 06:56 PM
Mike90SE's Avatar
Ok, I missed that one....but from your description, to me it sounded like it could have been a burnt valve. That is, didn't matter what coil you had on that cylinder, it stilled skipped. I guess I missed something.
We can't all be right all the time. LOL
Old Feb 13, 2008 | 11:59 AM
Wiking's Avatar
Can also be sticking IACV - needs cleaning 'every 80k' ... for VG see http://www.cardomain.com/ride/748507/4
wyobbagy
Jan 3, 2023 12:03 PM
The Frye
Sep 2, 2021 11:03 AM
9aj9
Apr 5, 2020 12:11 AM
