Capedcadavers tranny swap blog..;-)
Yea if your not going to be racing and such, I would skip on the VLSD, and wouldn't worry about rebuilding it to much, like tell the time that you need to replace the isb. It should last a long time if your not driving it hard, to be honest with you I did drive it, not like 5000 rpm clutch drops or anything like that, but yea that car has seen 120 mph more then a few times, and once leaving a mark on the road the length of 1 and a half city lots (after a bad ahhhhhhh fungus experience). For the most part I kept it full of gear lube and changed often. It never had a leak, and shifted well, when you down shift into 2nd it helps if you double clutch ( noticed that on every nissan I've driven).
Is this the first manual car you have owned?
Tested the 2 maximas with TCU disconnected: R/D -Gears do engage... I guess this is the safemode? ...and drivable? Didnt test-drive, I want to keep my dailydrive, the other hasn got insurance -orR-, so no testing with it.
My bet is the potentiometer. Its 5min to tst both...
I know this q was not me, but fits: This is the 2nd A/T for me - thus I am all in love with it. Maxima: Really royal compared to -70 AMC Hornet... which was already better than stick
This means I really dont know about A/T pumps and how do they fail; a seal bursts, valve jams - all human made tingies may break suddenly w/o warning.
my clutch pedal pressure increases every few days until the pedal doesn't even think about budging even if i tap the pedal with my foot (it shoud move just a few mm if i tap it.. but it's hard as a rock) so i have to keep opening the bleeder to relieve pressure. any reason why pressure would increase every few days? Once i release it it's too soft for about 5 minutes then it comes back to normal. then it gets too stiff again (usually followed by slipping)
and it appears that once the pedal gets stiff, it starts preloading the PP, which causes the clamping force to decrease, which allows my clutch to slip sometimes.
did you leave the "block" in the circuit?
This is my diagnoses also.
I think it is always pre loading the clutch until he relieves the pressure via opening the bleeder screw, they it just builds back up again after a few clutching cycles.
i may have to cut the rod after all. it seems that if i can get the rod to pull all the way back in the master cylinder when i lift off the pedal it should fix it.
if you can take a pic from an angle showing the profiles of the pedals pointing up toward the defroster vents from the floor... then yeah. i'd like to have a pressure gauge installed in it.. do they make an in-line brake/clutch pressure guage that bolts into the myl and receives the clutch line, that DOESN'T mess up the travel any?
when any one of you had to reinstall the clevis pin after the system was fully bled, could you with no resistance or did you have to push really hard on the clevis rod, or even open the system to overcome the pressure?
I've bleed my clutch m/s system many times with no issues what so ever..it's as simple as....my helper(older son) just pushes in the clutch, I open/close the bleed screw, he pulls the clutch pedal back up off the floor, rinse/repeat.
I'll try to get a pic tomorrow.
well yeah that's easy. i was referring to how hard it is to get the clevis pin back through the hole once you undo the clevis pin post-bleed, for whatever reason. Mine was so stiff i had to open the hydraulic system to push the rod enough to even move it in enough to position the clevis pin through the holes. that's what i was asking about. Bleeding is a piece of cake. The thing i get is that when i undo the clevis pin, the rod itself is pushing on the back of the pedal arm, and if i moved it out to the side it would extend well past the hole in the pedal... meaning the rod is way longer than it needs to be...i want the rod to be just-about flush with the front side of the pedal arm. So the pic that would help me the most would be a pic of the clevis rod at full extension from the side, also showing it pass by the pedal-arm hole that the clevis pin goes through.
i was trying to adjust the rod thingy but i couldn't b/c there was too much pressure on the rod to turn it. so i had to undo it to adjust the rod, at which point i realized it was way way too long.
also i noticed that the one thing that is most likely to overpressurize my clutch is prolonged idling in N. Which makes no sense. But i was driving driving driving and then i got slow for the neighborhood streets, and i stopped for a few minutes to make a phone call after taxiing around in 2nd at 1200rpm-ish, and the clutch was stiff as hell when i went to pull off.
This doesn't make much sense, since the entire clutch pedal assembly should have been at the "optimum" setting when swapped. as long as it was not messed with prior to the swap.
Heat from the engine/transmission will expand the fluid, maybe why you are experiencing this issue.Especially if the clutch rod is misadjusted.(i.e. in too far)
I'm thinking if you're using a stock MC and pedal assembly then the pedal mounting has to be off or the MC is wrong. There really aren't many other reasons for the clevis pin or bracket to be off.
But would the shim/bracket/whatever he used to make it the clutch pedal fit make it that far off???
From what i can gather from his pics/explanation of how far off this thing is, it would have to be a huge shim.
i'm still thinking wrong part here.
i used pliers and pulled/twisted/yanked the stock spacer off the parts car's firewall and it is installed on my GXE. in all aspects that i can see the part looks identical, however, i have not performed a true side-by-side comparison. I may do that when i get home, since it's DST now and staying lighter later.
as far as i can tell using a screwdriver as a 'ruler' and marking it with my fingertip, the new master cylinder's rod is approximately 1/2 to 3/4 inches longer than the stock one. My diagram was dramatized to show the concept, but the actual clearance is not THAT far off. But the rod contacts the back of the pedal more than it should, and with the clevis bracket removed i will position the rod inside the pedal assembly and mark it where it is just barely not touching the arm, for maximum future adjustility.
i am getting off work early today so i'll have plenty of time to document this. i didn't drive the max today, rather, the Pimpmobile Cutlass. I started taking it apart but then i went inside and it was dark by the time i got around to thinking about it again. So i was like w/e i'll do it tomorrow. just whatever i do i'll have to finish today. tomorrow is Probe day. joy. at least i'll officially know how to install an engine tho.
concerning the clevis rods... is the metal soft enough to hack throug?
Last edited by CapedCadaver; Mar 21, 2008 at 11:35 AM. Reason: generalized retardation on my part
i am getting off work early today so i'll have plenty of time to document this. i didn't drive the max today, rather, the Pimpmobile Cutlass. I started taking it apart but then i went inside and it was dark by the time i got around to thinking about it again, it was dark. So i was like w/e i'll do it tomorrow. just whatever i do i'll have to finish today. tomorrow is Probe day. joy. at least i'll officially know how to install an engine tho.
http://s164.photobucket.com/albums/u...-speed%20swap/
look at the last 7 pictures. (it's not on the last page tho b/c the videos are always at the end b/c all my images are IMG_xxxx.jpg and movies are MVI_xxxx.avi)
ok so it's cut, bled, and ready to roadtest. i had to keep adjusting the threads to get it just right but it feels OK right now... I'm going to see how slight changes affect it over the next week but for right now the pedal is good.
i-never-knew-i-was-that-good-at-Halo update:
drove the car, it functions. but the heat soak did stiffen the pedal up real bad once, and after letting it sit for 3 hours i didn't drive far enough to truly re-warm my engine through and through so i will have to see how it behaves tomorrow. but at least now i can adjust it as i need to (it's set at the most preloaded setting and i can back it out as needed). Does anyone notice their pedal get any firmer once the car warms up or the clutch pedal always feels the same no matter what?
