Epoxy/Adhesive for V6 3000 Logo?
Old Feb 17, 2008 | 12:56 PM
505max94se's Avatar
What type of epoxy or adhesive should I use to secure the "V6 3000" logo/sticker thingy that goes on the VE's valve cover?
Old Feb 17, 2008 | 03:36 PM
jonmandude's Avatar
3M tape. They sell it at auto body supply stores. It is used for trim and sticks like crazy.
Old Feb 17, 2008 | 04:25 PM
maxima-junky's Avatar
Is that the double sided white foamy tape?
Old Feb 17, 2008 | 05:03 PM
mikekantor's Avatar
Try to find a spray adhesive that is designed for high temps.
Old Feb 17, 2008 | 06:54 PM
505max94se's Avatar
I just used some two part 60-second epoxy and it worked great. Hopefully it stays on there.
Old Feb 18, 2008 | 09:18 AM
jonmandude's Avatar
There is a couple kinds. I don't like the foam stuff. There is also a black that is stronger. Check with your supply shop. They will proly have a few kinds
Old Feb 18, 2008 | 11:49 AM
Matt93SE's Avatar
STFU n00b!
superglue.
you could also use contact cement. works pretty well on stuff like that. they sell it in pretty small cans w/ a brush applicator. brush a thin layer on both the valve cover/manifold and the logo strip, then wait 5-10 min for it to get sticky.. then press & hold them together for a minute or two, then voila! never coming off!
Old Feb 18, 2008 | 08:58 PM
DanNY's Avatar
Ad·min·is·tra·tor
use the 60 second epoxy.
the double sided tape makes the piece stick up too much.
Old Feb 19, 2008 | 11:00 AM
505max94se's Avatar
Originally Posted by Matt93SE
superglue.
I thought about using superglue or contact cement, but I decided to use epoxy and it worked great!
Old Feb 19, 2008 | 11:01 AM
505max94se's Avatar
That's exactly what I used.
Old Feb 19, 2008 | 11:11 AM
Matt93SE's Avatar
STFU n00b!
I'm not familiar with that stuff, but if it works, then it's the right stuff for the job!
Apr 16, 2020 05:15 AM
NewMax03
Oct 29, 2015 07:44 PM
NewMax03
Oct 7, 2015 08:27 AM
MaximaNoob1
Sep 18, 2015 01:01 PM
DZN13
Aug 24, 2015 11:00 AM
