replace rear window?
Old Feb 18, 2008 | 05:48 PM
maximal's Avatar
anybody here replace one before? my sister's car got broken into. they broke the rear driver's side window. i've done regulators before, but never the window...how hard is it? anybody have any advice?
Old Feb 18, 2008 | 06:10 PM
akurtzer57's Avatar
well if you can replace a reg u can replace the window got to take the window out to get to the reg might take you in hour at the most.
Old Feb 18, 2008 | 06:33 PM
Greeny's Avatar
¯\(°_o)/¯
----> http://forums.maxima.org/showthread.php?t=396172
Old Feb 18, 2008 | 06:35 PM
Greeny's Avatar
¯\(°_o)/¯
No.....
You do not have to take the window out to replace the regulator.
Old Feb 18, 2008 | 07:11 PM
maximal's Avatar
thanks greeny. i read that. i just figured that getting it in would be harder than that. i'll take a look at it in the morning.
Old Feb 18, 2008 | 07:42 PM
mikekantor's Avatar
The actual replacement is much faster than removing all the tiny glass.
Old Feb 18, 2008 | 09:52 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by Greeny
No.....
for the fronts and rears or just rears? i replaced a front regulator on a friend's 3rd gen on saturday and removed the glass. didn't try to remove the regulator without doing so mainly because the regulator was stuck in the up position so i kinda had to take it out so i didn't have to guide it back down. front window removal is EASY anyways. dunno about the rear tho.
Old Feb 18, 2008 | 10:51 PM
Mike90SE's Avatar
I have replaced both front and rear regulators and did not have to remove the glass. It might be less frustration but you don't have to.
Old Feb 19, 2008 | 12:34 PM
GRNMAXDMON's Avatar
i never removed the glass to replace all of my window regulators.
Old Feb 19, 2008 | 12:58 PM
internetautomar's Avatar
mod or sell?
me either.
I did remove the glass when I stripped VE#1 though. I still have the glass I believe in the garage.
Old Feb 19, 2008 | 10:21 PM
Cliff Clavin's Avatar
Way out West
I would take all of the door panel apart and vacuum everything really good with a shopvac and try to get all of the glass out. Go over it multiple times.
Old Feb 19, 2008 | 10:24 PM
maximal's Avatar
yeah, i plan to. i haven't looked inside yet, but hopefully there isn't too much glass.
Old Feb 20, 2008 | 12:03 PM
jmichaelrush's Avatar
I'm gonna have to do this. I'm not sure how the windows are put together inside, but mine is off some sort of track. It doesn't stay up on it's own. So, I had to jam some card paper in between the frame and window to get it to stay up.
Old Feb 20, 2008 | 12:10 PM
mod or sell?
your window regulator is bad, fairly common and cheap/easy to replace.
Old Feb 20, 2008 | 12:24 PM
Cool. Any specific way to get the window out? Door panel, plate behind door panel, etc.?
Old Feb 20, 2008 | 01:04 PM
Greeny's Avatar
¯\(°_o)/¯
http://images.google.com/imgres?imgu...%3Den%26sa%3DG
Old Feb 20, 2008 | 01:20 PM
mod or sell?
http://www.geocities.com/bracecraig/...regulator.html
don't need to take the window out. just tape it up into place while you are replacing the reg
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
homeyclaus
Sep 3, 2015 06:15 PM
mpbclutch33
Aug 21, 2015 06:09 AM
doctorpullit
Aug 20, 2015 05:15 PM
