Z31 Rear Brake Conversion/Upgrade Write up
Feb 27, 2008 | 12:45 PM
  #41
Quote: So, if I have a 90 with the rear disks, I would only have to change calipers and rotors? The bracket is the same?
i'd assume that since the bracket on the 89-90 is LONGER, the torque member or caliper must somehow be "shorter" to make for the same hub-center-to-caliper distance on all 3rd gens... meaning that there's something about the 91-94 either torque member or caliper which is consequently longer than the corresponding bolt pattern on our 89-90 hardware, to make up for the fact that the bracket is shorter. my money's on the tq member itself, but it could be the caliper, in which case you'd need to swap ebrake cables for the latter-style. I hope it's the torque members, because another member on the org desparately needs to buy my 91-94 ebrake cables off me.. in which case i'd be stuck with no ebrake. Anyhow, once my car is back on the ground and owning civics even worse than before, i'll need a way to stop faster... hmm.. so i'll DEFINITELY be doing this mod, along with reuptable brake parts.. no more 'duralast' shall ever disgrace the calipers and wheelhubs of this 4DSC.
Feb 27, 2008 | 12:58 PM
  #42
I told you Id replace them, its just a PITA to get to the JY on a non crappy weather day. Plus finding a VE (or maybe 91-94) at all during the winter sucks.
Oh and the 91-94 calipers are actually bigger as well. Not sure on the mounting but they are bigger. I sold triplegmax a 90 se caliper and it ended up not working on his 91
~Alex
Feb 27, 2008 | 02:00 PM
  #43
well i looked at the ride and noticed that maybee it is an 87 se deal or sometin, i dunno maybee someone modded the maxima before me (that might account for the thick *** rear swaybar that i noticed while examining the rear rotors) but my rotors are the same size after the q45 caliper and rotor swap!
BBK FTMFW!!!
now if the rears are vented then i guess i should do it then..
Feb 27, 2008 | 02:08 PM
  #44
86 Z31 are solid not vented
Feb 27, 2008 | 02:10 PM
  #45
just b/c i'm such a cool dude, i'm going to take pics of each of the three components of both early and late braking systems. for size comparison. that way we'll have a decent understanding of what parts to use for those of us who already have the early bracketry.
Feb 27, 2008 | 02:11 PM
  #46
early brackets to strut, late calipers with their bracket to strut bracket.
doesn't matter early or late.
Feb 27, 2008 | 02:32 PM
  #47
So what do you think would work better? My current Brembo rear rotors with hawk hps pads? Or the larger Z31 rotors (non Brembo) and the same Caliper and Hawk hps pad setup?
Reason being is if I went with new rotors for the rear, I'd have to buy non-brembo.
Feb 27, 2008 | 02:46 PM
  #48
Quote: So what do you think would work better? My current Brembo rear rotors with hawk hps pads? Or the larger Z31 rotors (non Brembo) and the same Caliper and Hawk hps pad setup?
ask your significant other.
Bigger is better
Feb 27, 2008 | 04:39 PM
  #49
Caped, I noticed more difference from Drum to disc than I did from stock to z31 but I've got a torn guidepin boot up front which may be causing crappy stopping. I'll look into it when its warmer.
In case there are people interested in the 89-90 bracket and Jeff is not able to get more than 5 people, I can get enough brackets for a decent price.
Feb 27, 2008 | 04:51 PM
  #50
Quote: Caped, I noticed more difference from Drum to disc than I did from stock to z31 but I've got a torn guidepin boot up front which may be causing crappy stopping. I'll look into it when its warmer.
I may get one off of you, I'll keep in touch.... there may be a 89/90 in a yard near me.
Feb 27, 2008 | 05:04 PM
  #51
Quote: ask your significant other.
Bigger is better
Feb 27, 2008 | 05:12 PM
  #52
Bigger is better
Jeeethuthsss christh!!! sthop whorin my thread you sthihleee!
Feb 27, 2008 | 05:13 PM
  #53
Bigger is better
What significant other?
Feb 27, 2008 | 05:14 PM
  #54
You two get a room...
Feb 27, 2008 | 06:28 PM
  #55
Quote: Jeeethuthsss christh!!! sthop whorin my thread you sthihleee!
did that a little well... practice much?
Feb 27, 2008 | 06:34 PM
  #56
lol!!
Feb 27, 2008 | 07:21 PM
  #57
you no speaka da engrish?
Feb 27, 2008 | 09:51 PM
  #58
hmm, well either way i'm going from drums straight to the z31 mod so i'll never know... mwahaha. i've got an 89 parts car, and rear struts/brakes from a VE as well.. so i've got errthing i need.
Feb 29, 2008 | 10:06 AM
  #59
Quote: hmm, well either way i'm going from drums straight to the z31 mod so i'll never know... mwahaha. i've got an 89 parts car, and rear struts/brakes from a VE as well.. so i've got errthing i need.
While you're ahead and while its been raining and cant really work on your 5spd swap...I'd get the calipers prepped up so they look nice and shiny perhaps even paint them...I didnt get to do that but will be getting mine or some spares sandblasted and cleancoated (or painted.)
I've got 2 choices that I'm leaning towards. Just wirebrush em, sandblast em, you know get em' all shiny and sparkly then clear coat em',
I wouldn't mind some chrome paint but dont know if there's a high temp one..
OR
Wirebrush, sandblast, and paint em red...I'm not sure which to go for
Feb 29, 2008 | 10:23 AM
  #60
Quote: While you're ahead and while its been raining and cant really work on your 5spd swap...I'd get the calipers prepped up so they look nice and shiny perhaps even paint them...I didnt get to do that but will be getting mine or some spares sandblasted and cleancoated (or painted.)
OR
mmm.... out of those two options, I'd definitely go with the clearcoat, though I opted to paint mine black. Even though it's clearcoated they can still get dirty, black hides most of everything. And Red just seems a tad bit rice if you have nothing else on your car done.
Feb 29, 2008 | 10:28 AM
  #61
Quote: mmm.... out of those two options, I'd definitely go with the clearcoat, though I opted to paint mine black. Even though it's clearcoated they can still get dirty, black hides most of everything. And Red just seems a tad bit rice if you have nothing else on your car done.
I agree with you which is why I'm leaning more towards the polish/clearcoat as well, note it was my first option
Now, if you lived in Chicago you would take that statement about black hiding dirt back. Salt spread for the snow and ice will make those look white and they'd look like crap. I did my parallel links just like Greeny..they looked new, shiny and black until the snow got here and then BAM they look like crap. Its all a matter of keeping your car clean
Feb 29, 2008 | 10:30 AM
  #62
Quote: I agree with you which is why I'm leaning more towards the polish/clearcoat as well, note it was my first option
Ohh, true. I don't have to deal with any snow and little rain, and if it does rain... it's nothing a hose can't fix. The polished + clear coat would look clean though, as far as tastefulness goes.
Feb 29, 2008 | 10:32 AM
  #63
Indeed, stands out but doesnt blind you saying "hey look at me!!!"
Anyone know if there's any high temp chrome paint? I'm just gonna polish and clear coat but I'd like to try the paint as well. I googled some a lil while ago and was checkin out the duplicolor site but didnt see any..
Feb 29, 2008 | 12:01 PM
  #64
OR
the calipers are bad anyhow. i'll have to buy at least one, if not both, new. so they'll have that kind of olive-gold color to them, and be clearcoated.
Feb 29, 2008 | 02:10 PM
  #65
Quote: the calipers are bad anyhow. i'll have to buy at least one, if not both, new. so they'll have that kind of olive-gold color to them, and be clearcoated.
I have two extra rear calipers.
Jul 29, 2008 | 10:25 AM
  #66
THIS NEEDS TO BECOME A STICKY \?!?!?!?!
Jul 29, 2008 | 02:32 PM
  #67
Took so long to sell this batch:
Jul 29, 2008 | 07:43 PM
  #68
Quote: THIS NEEDS TO BECOME A STICKY \?!?!?!?!
I'm glad you think so
Jul 29, 2008 | 08:10 PM
  #69
Quote: Took so long to sell this batch:
isn't that the batch I bought from? (how many years ago?)
Jul 29, 2008 | 11:00 PM
  #70
sure...he did pretty good...
so jhon i m gonna do this swap soon...can i use my 92 SE stock caliper? or is there any option that i can use different stronger caliper? and ya can i use 300zx dust shield instead of cutting stock one? and can i jus go to auto parts store and get 89-90 torque member easily i know i can get rotors or the part number u mentioned is the one i must use?
is it only for rear? not front?
Jul 30, 2008 | 03:26 AM
  #71
just for the rear. and the 89-90 torque member is not what you need. he used the wrong terms, and they were poking fun about that a few posts up. it's the caliper adapter bracket. keep your 92's torque member (where the pads go).
before it becomes a sticky john has to fix that
Jul 30, 2008 | 03:39 PM
  #72
You should be able to use your 92 SE rear calipers as I dont know any upgrades. 89-90 torque member (not the name as I was corrected earlier but I know what you mean) you will not find at a parts store... only dealer or JY. If you need the 89-90 members I can get you a pair for a good price in case you cant find any. I never tried using a 300zx shield so that I cant answer. And Yes you can ONLY use the rotors I mentioned. I got mine from Brian (internetautomar) for a real good price.. just give him a holler
Jul 30, 2008 | 06:32 PM
  #73
Quote: You should be able to use your 92 SE rear calipers as I dont know any upgrades. 89-90 torque member (not the name as I was corrected earlier but I know what you mean) you will not find at a parts store... only dealer or JY. If you need the 89-90 members I can get you a pair for a good price in case you cant find any. I never tried using a 300zx shield so that I cant answer. And Yes you can ONLY use the rotors I mentioned. I got mine from Brian (internetautomar) for a real good price.. just give him a holler
ugh. cmon mang!
calipers and tqmembers from 91-94
these things from a 89-90. not called tq members. called caliper adapter brackets. i have some of each part. i can take a pic of each individual part, and label it, with years, for a graphic representation.... i can even hold a tapemeasure to it for actual size info if needed. just no wrong names!
Jul 30, 2008 | 09:09 PM
  #74
http://i164.photobucket.com/albums/u...8/IMG_2122.jpg side shot
the shiny gold thing is a 91-94 torque member. the nasty rusty-ish thing it's attached to is a 89-90 adapter bracket. the shiny silver thing is a z31 rotor
Jul 30, 2008 | 09:24 PM
  #75
Quote: http://i164.photobucket.com/albums/u...8/IMG_2122.jpg side shot
ah, hm. I've always called the shiny gold thing a caliper bracket. The nasty rusty-ish thing a caliper adapter plate, and the shiny silver thing a rotor.
Jul 30, 2008 | 09:32 PM
  #76
Quote: ah, hm. I've always called the shiny gold thing a caliper bracket. The nasty rusty-ish thing a caliper adapter plate, and the shiny silver thing a rotor.
caliper bracket is an OK name. look at post 17 for the fsm pic. it's just that he was calling the adapter plate the tqmember... the gold thing is the tqmember not the nasty rust-ish thing.
Jul 30, 2008 | 10:19 PM
  #77
alternate method for modifying the rotor dust shields. photo credit 95BLKMAX
Jul 31, 2008 | 12:22 AM
  #78
u made those cuts, pulled the shield's edges up, and made the dust shield flat instead of cutting it?
Jul 31, 2008 | 06:34 AM
  #79
Quote: u made those cuts, pulled the shield's edges up, and made the dust shield flat instead of cutting it?
Correct, that is what was done.
Jul 31, 2008 | 06:39 AM
  #80
well, I didn't do that. mine were rusted to holy hell so i just pulled them off. but the guy that made that pic did it that way.
