Injector Swap
Old Feb 23, 2008 | 02:13 PM
Deridex's Avatar
Injector Swap
I need to replace one of my injectors with a new one. But I don't have $100 to spend on a new one so I want to replace one on my '94 GXE with one I took off of "91 SE. They are a bit different but I figure they should work the same. I realize I'll have to switch one of the harnesses but I'm just looking for confirmation that I won't run into any technical problems otherwise.
Top one is from my GXE, bottom from SE.
Old Feb 23, 2008 | 03:11 PM
redwood_usa's Avatar
Just make sure you put new fuel hose on those too.
Old Feb 23, 2008 | 03:33 PM
akurtzer57's Avatar
I don't see what it could hurt they are the same size just different plug. Just make sure you test them out switch the plug and new orings. You should be fine.
Old Feb 23, 2008 | 05:50 PM
internetautomar's Avatar
mod or sell?
if your old rail is all good, I would swap all of them over along with their harnesses.
if you look at the rails you see they have different feed points, I doubt it would make any difference, but you never know.
Old Feb 23, 2008 | 08:10 PM
Deridex's Avatar
Yeah, that's what I was thinking too. No reason why I can't do that. Thanks.
Old Feb 24, 2008 | 11:19 AM
subs1000w's Avatar
wernt those supposed to be better injectors if so i agree swap them all over and be done with it
Old Feb 24, 2008 | 12:31 PM
Deridex's Avatar
Alright, I found out that those are completely different. Injectors and rails, both are incompatible with one another, even if they look similar, so yeah, complete swap is the only way to go here.
Old Feb 24, 2008 | 03:46 PM
maximal's Avatar
yeah, you have to swap the whole rail. i went from 92 to 94.
TallTom
57
Oct 14, 2025 05:16 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
ef9
Oct 4, 2015 08:43 AM
HerpDerp1919
Sep 29, 2015 02:02 PM
