Anyone have a clutch cylinder template for 5spd swap?
Mar 23, 2008 | 06:54 AM
Hey everyone, Im about to start the 5spd swap and wanted to know if anyone had the clutch template (for making holes in the firewall). I don't have a parts car (got all the parts from yard) so it'd help a bit if someone had one that they could scan.
Mar 23, 2008 | 06:59 AM
Did your carrier bracket arrive ok?
Mar 23, 2008 | 12:39 PM
Quote: Hey everyone, Im about to start the 5spd swap and wanted to know if anyone had the clutch template (for making holes in the firewall). I don't have a parts car (got all the parts from yard) so it'd help a bit if someone had one that they could scan.
can't you go back and find the parts car at the yard and just get it from there? if i had mine still i would give it to you but then again i don't have a scanner. don't know if anyone else on here might still have theirs?
Mar 23, 2008 | 01:32 PM
Quote: Did your carrier bracket arrive ok?
Yes it did, thank you much
Quote: can't you go back and find the parts car at the yard and just get it from there? if i had mine still i would give it to you but then again i don't have a scanner. don't know if anyone else on here might still have theirs?
I doubt the car is still there, I pulled the tranny off quite a while ago..
Mar 23, 2008 | 01:40 PM
try and see if you can go back and maybe it might still be there if not maybe another one might be there.
Mar 23, 2008 | 08:44 PM
Wish I had one at the time I did my swap. I just estimated, then reamed the holes out with a dremel for proper alignment and fitment, siliconed up the edges and used stacks of washers on the clutch pedal assembly studs in lieu of the OEM spacer...Hey, when you don't have parts available to you, you do what you have to to make it work...Still gets the job done 2 years later...
Mar 23, 2008 | 09:47 PM
i can make one, since my parts car is still in the driveway.
Mar 23, 2008 | 11:14 PM
That'd be greatly appreciated
