Exhaust Studs
Old Mar 31, 2008 | 01:20 PM
majordan's Avatar
Exhaust Studs
What is the best way to check them to see if they are bad? Can I get a visual on all of them from the engine bay?
Old Mar 31, 2008 | 01:25 PM
maxitech's Avatar
Start the engine, pop the hood, and listen! In some cases you can also feel the exhaust by holding your hand above the manifold. If they haven't ever been replaced, then chances are you need to do it.
Old Mar 31, 2008 | 01:31 PM
goon9's Avatar
They are bad. They all are bad.
Greeny's Avatar
¯\(°_o)/¯
Most of the bolt ends can be seen from the engine bay, but some needs to be seen from under the car, mainly the rear stud/bolts.
If the nut is missing, then the stud has broken.
Old Mar 31, 2008 | 04:31 PM
Tampamaximus's Avatar
LOL! Well said. Greatest post in this thread.
Old Mar 31, 2008 | 04:32 PM
GRNMAXDMON's Avatar
just replace them all.
Old Mar 31, 2008 | 05:00 PM
Alex_V
Indeed. Even max's that have been repaired before have broken studs again a few years down the road. Or so Ive read on here. But the quality of the workmanship and replacement studs (non OEM etc etc) was questionable.
Do it right with OEM studs and it should last a while.
~Alex
Old Mar 31, 2008 | 05:31 PM
maxitech's Avatar
Use Z31 turbo studs.
Old Mar 31, 2008 | 05:54 PM
Greeny's Avatar
¯\(°_o)/¯
IIRC the maxima/z31 manifold studs have been superseded into the same part.
Old Mar 31, 2008 | 06:08 PM
maxitech's Avatar
Well that should make them easy to pick out...
Old Mar 31, 2008 | 06:09 PM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
Our cars seem to have a " sickness" for broken studs Both of my 3rd gens had broken ones. Both VE AND VG... Use z31 TURBO studs and replace em all.The tricky one is behind the power steering pump..lol
Old Mar 31, 2008 | 06:35 PM
Greeny's Avatar
¯\(°_o)/¯
I've been extremely lucky on my ve, 320,000 miles and only one broken stud, but no exhaust leak from it as of yet..
Old Mar 31, 2008 | 06:38 PM
goon9's Avatar
There is a write up how to replace them. I did it the first time to the 't' according to the write up by drilling and EZ outting them. That took me 6 hours to back out about 8 broken ones. The 2nd Time I did it it only took an hour with a Mig welder! Just build a weld out by hitting the broken stud, then weld a bolt on to it and wrench it out
Old Mar 31, 2008 | 06:45 PM
shoult's Avatar
I bought mine at 124K with no broken studs. By 130K I had broken 4. I replaced ALL of the studs, washers and nuts with the z31 parts in the driveway of my apartment complex over one weekend. Thank God for right angle drills and left twist drill bits..... oh and PB Blaster!!!!!
Old Mar 31, 2008 | 07:01 PM
internetautomar's Avatar
mod or sell?
none of my 4 had bad studs
Old Apr 4, 2008 | 08:01 PM
augiedog964's Avatar
I sometimes hear a tick, like the noise you hear after turning off the car. Should I assume it is exhaust studs?
Old Apr 4, 2008 | 08:48 PM
BenStoked's Avatar
Jesus was a Zombie.
does it tick faster when you rev the engine? if so, its definitely a leak. with the engine cold and off, stick your head in and take a peak.
Old Apr 4, 2008 | 09:05 PM
GAMERA30's Avatar
sometimes u can smell exhaust fumes in the engine bay too
Old Apr 4, 2008 | 10:36 PM
Tom's Avatar
Tom
Study these diagrams, then when the engine is COLD, simply stick your fingers there and feel for the studs where they are supposed to be..
For VG
For VE
Old Apr 8, 2008 | 09:17 PM
beez5spdmax's Avatar
nissan gets away with a lot between the studs n window regulators n trannys
Old Apr 9, 2008 | 12:52 PM
Cliff Clavin's Avatar
Way out West
I agree...great post.
On my original engine, they weren't making noise, but when the engine was pulled, I could see some black around some of the studs. Of course, a couple were gone...
Old Apr 9, 2008 | 03:03 PM
Tom's Avatar
Tom
The replacement studs (Z31) are little better, but not perfect
I did the studs TWICE. Back in 1998 and then again in 2007.
I did replace one window regulator, but transmission still shifts like it did 11 years ago when I bought the car.
Old May 27, 2008 | 12:57 AM
Wiking's Avatar
VGE poem: My tickin stopped as bolt dropped.
goon9: "There is a write up how to "
---> where is there?
Old May 28, 2008 | 12:26 PM
goon9's Avatar
Why in the stickies of course. http://forums.maxima.org/showpost.ph...68&postcount=7
Here's what I did recently.... Not studs but was super cheap and pretty strong, surely not as strong as a turbo stud.
The bolts are rated 10.9 and thread in much further than a regular stud.
Old May 28, 2008 | 01:42 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
goon you rock. what length did you use? and what class are the turbo studs? I'm using some class 10.9 bolts on my pressure plate, hope that's strong enough.
Old May 28, 2008 | 02:19 PM
mod or sell?
um, be careful when you use longer bolts. some places a longer bolt will either come out the other side or bottom out and break something inside the block (seen it happen many times before)
Old May 28, 2008 | 06:06 PM
goon9's Avatar
I measured and trimmed the bolts.... I them 1-2 mm shorter than the full length.
I don't know the what class the turbo studs are.
Old May 28, 2008 | 07:05 PM
mod or sell?
it was more of a warning to those reading it. people get happy with air tools and don't feel the end of holes crack open
Old May 28, 2008 | 09:46 PM
Wiking's Avatar
I want u to come and help; free lodging promised in exotic midnight sun summer... I promise to swap all the mosquitoes.
--->I guess no scheduling in bolts change with these gasoline prices... Stud broke and now O2 semi-froze.
Old May 28, 2008 | 10:22 PM
you might want to add a few of the Scandanavian Blondies to the list of promises... and maybe a few pints of something that burns a little on the way down that we don't get in the States.
Old May 28, 2008 | 10:33 PM
Wiking's Avatar
The green pastures are full of em for u to chase - take care, some even driving on red.
Maxima drinks all, driver none.
Old May 28, 2008 | 10:42 PM
1993-VG30E-GXE's Avatar
I agree, plus the OEM ones are possibly weaker than other generic stuff available out there. I bought 2 long ones from Nissan and there isn't even a strength rating on it. I found 12.9 bolts for .80 a piece - not through Nissan.
Old May 29, 2008 | 12:05 AM
Wiking's Avatar
One reason behind broken studs could be Y-pipe heat expansion strain. Why not weld a short flex in the front pipe while doing this job? Objections?
Old May 29, 2008 | 03:39 AM
Greeny's Avatar
¯\(°_o)/¯
Broken motor/trans mounts may have something to with it also, imo.
Old May 29, 2008 | 02:21 PM
MaxDude08's Avatar
Good post answers my ticking question; turns out i have a bolt missing. But now my other question. This week i have been having trouble starting my car from cold.(its fine once its warm) So of course i have been popin the clutch but anyway i stop today at the gas station to fill her up. When i went to start her and pull off i couldn't get the car over 2000rpm with out sputtering. I have not put the bolt in but could that be the cause?
Old May 29, 2008 | 03:25 PM
would it still climb to any RPM you asked of it (just sputtering on its way there), or would it hit 2000rpm and say "no more!"? if it's got a 2000rpm ceiling then look at your maf wiring and stuff.
Old May 29, 2008 | 04:15 PM
MaxDude08's Avatar
Yes it would still climb but slowly so i would just switch out. But under futher review it looks like i am missing 2 bolts and also seems like the gasket has burned away. Ill take some pictures to show. VG motor.
Old May 29, 2008 | 04:20 PM
Matt93SE's Avatar
STFU n00b!
The studs don't break off because they're too weak. The studs are breaking off because they were installed improperly at the factory.
You're not supposed to bottom the stud out in the bottom of the hole OR butt the tapered shoulder against the side of the head. either of these actions will cause points of high stress in the bolt and will cause premature failure.
I'll scan the article I'm referring to when I get some time.
Old May 29, 2008 | 04:28 PM
MaxDude08's Avatar
http://tinypic.com/view.php?pic=2v0zzbc&s=3
pic of studs / gasket
Old May 29, 2008 | 05:22 PM
how do you get the stud in and then tighten the nuts onto it without it bottoming out into the holes in the head? seems the nuts would force the stud to spin in some more? or would that not happen?
