mystery tapping noise
Old Oct 31, 2001 | 02:44 PM
herreby
My 90SE seems to think it's a popcorn maker. Here's the catch though. It only makes this tapping noise when the following conditions are met: 1.the outside temperature is at least 60F. 2.only at speeds between 73 and 85 mph. 3.only when there is a demand on the engine, (no noise when coasting at these speeds) it sounds like its coming from the front right of car. No one seems to be able to figure this out. ANY IDEAS or PERSONAL EXPERIENCES WELCOME
Old Oct 31, 2001 | 05:30 PM
Brian_TII's Avatar
Re: mystery tapping noise
What octane gas are you using and have you checked your timing?
Old Nov 1, 2001 | 08:16 AM
herreby
Re: Re: mystery tapping noise
I only use the best gas, 92 or better. And I had a mechanic check the timing already. any other ideas? Both of these were good suggestions because i know that if I don't put the best gas in it runs like crap, and i mean crap!! thanks
Old Nov 1, 2001 | 03:12 PM
eric93SE's Avatar
I'll take a stab. Could possibly be a sticking valve. Does the engine miss when those conditions you mentioned exist.
Old Nov 1, 2001 | 08:56 PM
Aphrodisiac's Avatar
Does it happen when you're parked?
Is it similiar to the issue addressed in the FAQ?
I remember one day someone warned me about it while I was driving (how kind )
Old Nov 1, 2001 | 09:11 PM
Matt93SE's Avatar
STFU n00b!
have the mechanic check your exhaust manifold studs.. usually that just happens on a cold engine, then goes away after 2-3 minutes, but it could also happen on the highway at speed.. you're just not likely to hear it unless it's really bad.
Old Nov 5, 2001 | 03:38 PM
herreby
No, I don't believe it sounds like a valve. Thanks anyway
Old Nov 5, 2001 | 03:50 PM
herreby
Well actually I had Nissan look at it and they agree with you, but I thought that it just didn't seem like a good diagnosis because i wondered why it would do it at highway speed and only when it's warm outside. So you think that this is my problem, because now i think i believe them.
Old Nov 5, 2001 | 06:49 PM
The Flem's Avatar
it sounds like an exhaust leak to me. You might want to run a heavier oil just to make sure its not something in the engine, but my moneys on the exhaust.
Old Nov 6, 2001 | 09:06 AM
herreby
I agree, thanks for the info
user 11122324
42
Jul 18, 2022 03:35 PM
Miket2006
Mar 1, 2021 03:55 AM
D Mason
Jun 21, 2016 04:43 AM
uttadms31
Sep 30, 2015 05:24 AM
