Write-Up: squeaky clutch pedal giving you the blues?
Old Apr 7, 2008 | 07:57 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
So are any of you stick-shifting 3rd genners noticing a super-annoying creaky-squeaky clutch pedal? You are? Well here's how to fix it.
1) Go to your LOCAL dealer (courtesynissan will end up costing more due to shipping) and get one of these:
2) remove the knee panel of your dash for better visibility and access, and tilt your wheel all the way up and move your seat all the way back.
3) get your 12mm socket, about 12in of extensions and a 3/8 drive ratchet. Look up at the top of the clutch pedal bracket and unbolt that bolt that goes into the dash support beam. Also unclip both harness plugs on the pedal assembly, pop the clevis cotter pin out and remove the clevis pin.
4) open your hood and take a 12mm deep socket, short extension on 1/4 drive ratchet and remove the nut on the clutch master cylinder closer to the brake booster. You'll need a 12mm box wrench for the one closer to the fender. Put the nuts aside and go back inside the car.
5) Wiggle the pedal out. It'll require some force to pop it past the HVAC tube, but just be careful and firm, and it'll come out eventually. the master cylinder should still be in its normal location even after you remove the pedal.
6) Now get a 14mm box wrench and remove the nut that holds the pedal arm into the bracket. Use your favorite tool to tap the bolt out, and grab it once it clears the nut-side of the bracket and then just pull it on out. separate the two pieces and put the bracket aside.
7) remove the old spring bushing from the pedal arm, if there even was one (i didn't even have one). now open the package your bushing is in and pop the bushing into the pedal arm and use some caliper slide pin lube or whatever's handy to fill the notch.
Last edited by CapedCadaver; Apr 8, 2008 at 09:16 PM. Reason: typo on step 4; on step 5, added "the master cylinder should...." & step 7 "remove the old.... even have one)."
Old Apr 7, 2008 | 07:58 PM
8) grab the pedal arm and bracket, and put the arm back in the bracket, but move it around until you can get the spring to fit into the bushing, and just push on it until it pops into place.
9) now pull the pivot of the pedal arm as close to the studs as you can and make sure the pedal is in the pushed position b/c i think that makes it easier to line the holes up. line the holes up as shown, and quickly jam the bolt in so you can rest your hands. It probably won't go in all the way but you can figure that part out.
10) tighten the nut back on the pedal assembly and install everything in the reverse order. remember to lube the clevis pin.
go drive around the block (or take a slightly longer trip, if desired) and enjoy your fresh, silent clutch pedal.
Old Apr 7, 2008 | 10:42 PM
hoyshnin's Avatar
Baby's on the Half Tip!
this is fantastic, thanks!
Old Apr 8, 2008 | 08:56 AM
Lordrandall's Avatar
Sweet! That sound has been mildly annoying me for a few months now.
Old Apr 8, 2008 | 08:05 PM
Jon94SE's Avatar
Thanks, this will definatly be on my list of things to do soon, I just started getting the squeeks in there and would like them to go away.
Old Apr 8, 2008 | 09:28 PM
if the sound works, then this is what mine sounded like before i even removed the half-broken bushing... once i removed it the sound got even worse, and now it's gone.
http://s164.photobucket.com/albums/u...t=MVI_1143.flv
Old Dec 5, 2010 | 03:39 PM
James92SE's Avatar
2 VE's are better than one!
I'm going to do this this week on my black VE. What a shame the whole assembly has to come out to replace that stupid little bushing.
Has anybody tried to re-lube the bushing instead of replacing it altogether?
Old Dec 7, 2010 | 08:05 PM
GRNMAXDMON's Avatar
i have to do this asap.
Old Dec 8, 2010 | 02:51 PM
BklynsmoeVE's Avatar
def a shame to remove the whole assembly but like james asked did anyone ever try relubing lol or probably wouldnt be as effective, like the speak would just return in a few months no?
Old Apr 29, 2011 | 10:56 AM
Kaleobz's Avatar
Clutch padal assist bushings
I was able to get to that bushing on my 01 Max without taking the whole assembly out. I had to replace the two other plastic bushings that the assist spring ends go into that were shot. The one you guys are talking about looks similar to the one in the center of the spring on my 01 Max. I took the spring off and all three of my cluch pedal assist spring bushings were accessible. Might not be the case for the previous Gen. Max's
Old Apr 29, 2011 | 04:36 PM
well in my case, the bushing had disentegrated from the pressure of the spring, so it was metal on metal
it only takes 10 minutes to get the pedal assembly out, no biggie
you can get the spring OUT without taking the pedal out but you can't get it back IN with the pedal still installed. I ended up liking how it felt with the spring gone altogether, so, i just took it out of the pedal with the pedal still attached to the car. You then just have to adjust the rod and stoppers to allow cruise control to still work, and to allow the pedal height to be correct, when the spring is gone.
Old Nov 10, 2011 | 06:40 PM
James92SE's Avatar
So I never got around to doing this. I'm finally ordering all my final parts to finish my black VE overhaul (hope I don't forget something ). Which part is this exactly in the diagram?
I'm thinking it's 4625MA but want to make sure:
Old Nov 10, 2011 | 06:56 PM
tweak's Avatar
I think that would be the one labelled 46525M (and 46525MA being bushings for where the spring attaches to the rest of the assembly, since there's two), although the part shown in the OP is a different number entirely.
Old Nov 10, 2011 | 07:02 PM
James92SE's Avatar
Ahh, yes, you're right. I didn't notice that it shows two of the 46525MA. So that would mean it would have to be 46525M.
user 11122324
42
Jul 18, 2022 03:35 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
carlosvq30
Sep 26, 2015 09:44 AM
ef9
Sep 10, 2015 10:35 PM
