Idle Pulley bent?
Old Apr 17, 2008 | 11:20 AM
Mysticcal's Avatar
Idle Pulley bent?
So, trying to get an AC belt on my AC (hopefully it's the only thing wrong with the A/C) and I noticed the idle pulley is on an axis while the AC pulley is straight, anyone have any clue what this could be? also, whats the best way to tackle the belts? they're far off in the left hand corner and it seems almost impossible to get to some of the back belts from the top
Also, just bought a new transmission from ebay so I can swap mine and finally go over 35MPH (prolly ruined my motor in that process -.-) so we should be getting to the yard sometime soon to replace some other things
Old Apr 17, 2008 | 11:44 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
you may have to twist the belt flat and slip it past the pulleys to get it up and over onto the pulleys. as for the a/c one... that sounds rather strange what you're describing. Can you take a picture, or make a diagram or something?
also how did you ruin your motor, as you say?
Old Apr 17, 2008 | 11:58 AM
Mysticcal's Avatar
potentially harmed it by running on a transmission that wouldnt upshift past 2nd, thus having to drive around san francisco at 35MPH and having to rev up to 6k rpm to actually keep up with traffic for small periods of time
Old Apr 17, 2008 | 12:51 PM
35mph in 2nd should be around 3000rpm which isn't terribly straining on an engine, especially considering that highway RPMs are well over 2500 if you're going "with the flow". 6000rpm shouldn't happen unless you floored it, but even if the tranny worked like it should, the only way it's hitting 6000rpm is to be floored and in 1st gear. it would be redlining at about 70mph in 2nd
so your engine shouldn't be that messed up by it.
Old Apr 17, 2008 | 12:59 PM
92 Max's Avatar
Don't know which engine you have, but on the SE it's easiest to pull the front passenger wheel off, take off the fender liner splash guard , both upper and front lower, and you can get at them easiest there. If the idler pulley seems loose, make sure the pulley axle nut it tightened. It will wobble if this is loose. (To adjust belt tension you loosen this nut, then turn the adjustment bolt on the end of the pulley mount)
Old Apr 18, 2008 | 10:26 AM
Wiking's Avatar
...the best way to tackle the belts? ...
As mentioned, taking wheel off gives lots space.
For me, taking bottom splash guard off to access steering pulley & tightening bolt was enough. Check this writeup and give out an opinion: http://www.cardomain.com/ride/748507/23
Old Apr 18, 2008 | 03:43 PM
Mysticcal's Avatar
it's a 94 SE max DOHC :P sillies
Old Apr 18, 2008 | 05:30 PM
Greeny's Avatar
¯\(°_o)/¯
lets stay on topic here folks, help the op with his issue..
Old May 26, 2008 | 12:24 AM
Mysticcal's Avatar
Wasn't bent, was broken, was just sitting on the bolt, fun fun (I can see why there wasn't a belt on it in the first place, now I just hope the AC system works)
even taking off the fender guard it was hell to get off. it's like the only spot thats covered by metal on all sides.
Old May 26, 2008 | 05:45 AM
internetautomar's Avatar
mod or sell?
looks like the bearing is totally gone.
Old May 26, 2008 | 06:55 AM
Wiking's Avatar
[ IIIII M G ]http://img148.imageshack.us/img148/1181/0525082255aky1.jpg[/I M G]
U could do with a smaller camera
So wassup with the tranny? Self Diag not ok?
Old May 26, 2008 | 12:00 PM
Mysticcal's Avatar
brand new ebay tranny went in about 3-4 weeks ago. runs great
calling today for a new bearring.
Old May 26, 2008 | 06:31 PM
Matt93SE's Avatar
STFU n00b!
Replace the whole tensioner assembly. it's not that much. bearing is only a few bucks, but usually the pulley won't accept a new bearing. they get bent or lose clearance or something when the old bearing comes out, and the news ones never press in properly or wind up falling out.
Old Nov 9, 2008 | 02:18 PM
Mysticcal's Avatar
hate to bump such an old topic but I finally got around to fixing it. one problem. the bolt holding the pully /w tensioner, won't come out, isn't it supposed to pop out the bottom? I believe it's also holding part of the bearing on it which isn't good -.-
Unclejunebug
Apr 2, 2016 05:42 AM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
