No air coming out of the vents
Old Apr 26, 2008 | 01:16 AM
Brooklyn Legend's Avatar
It all started recently when the heat started to cut off once in a blue, I originally thought it might be the blower motor untill the car stopped blowing air all together. I tried 2 different blower motors and both did not move when i plugged them into the harness. I tested the harness that connects to the blower motor and the test light did not light nor did it light on the 2 #15 fuses in the fuse box. Is there maybe another fuse or relay that controls the manual air controls? or could it be that my controls are just bad?
thanks for any insight in advance
Old Apr 26, 2008 | 01:25 AM
Wiking's Avatar
Originally Posted by Brooklyn Legend
... it might be the blower motor untill the car stopped ...
Squirrels nest collapsed ? ...if blower is not working when blower motor is ok, try another resistor block.
see the redlined 2screw tingie ... http://www.cardomain.com/ride/748507/7
Old Apr 26, 2008 | 03:59 PM
i tried another one and it worked thanks. before this problem my a/c worked now when i put it on it blows normal temp air. the healt although is still working could it be this "resistor-fan control amplifier has anything to do with the a/c besides air?
Old Apr 26, 2008 | 10:37 PM
Wiking's Avatar
... a/c worked now when i put it on it blows normal temp air. ...
I guess there has been some kind of short, and thus meltdown. A/C does not come on...
Check all fuses first by swapping. Also fusible links under hood, beside batt. Then swap the 3 A/C relays under water reservoir, blk box. (Color coded: you may swap same colored relays for diag purposes.)
The A/C control goes through the control panel circuit board, can be bad. ECU has its say also, but if all other issues work, I think it is ok.
You can test control the A/C direct by giving +12V jumper wire to the compressor - theres only one pin.
MattWithTheMaxima
Jun 30, 2017 01:06 PM
vingodine
45
May 21, 2016 12:46 PM
Johnny9595
Sep 3, 2015 05:18 AM
95Maxi
Aug 29, 2015 09:38 PM
kirkhilles
Aug 8, 2015 10:53 AM
