Twin Cam 24 Valve V6 3000 Engine Stickers?
Old Apr 28, 2008 | 10:33 AM
Pearl93VE's Avatar
I can has?
Anyone know where I can find the red plate that goes on top of the valve cover? I checked the local dealer, ebay, brian's site, and courtesy and can't find them anywhere...
Old Apr 28, 2008 | 10:40 AM
Greeny's Avatar
¯\(°_o)/¯
http://forums.maxima.org/showpost.ph...&postcount=459
http://www.courtesyparts.com/betasit...-p-251979.html
Old Apr 28, 2008 | 10:42 AM
Greeny's Avatar
¯\(°_o)/¯
Old Apr 28, 2008 | 10:49 AM
Pearl93VE's Avatar
I can has?
Ohhh I see... tricky. Couldn't find it on Courtesy just by searching for it for some reason, maybe I'm blind.
Big VE-5 IM/Valve Cover/Intake Spacers/Knock Sensor install is coming up soon!
Old Apr 28, 2008 | 11:33 AM
mikekantor's Avatar
Oooh I want one like that
Old Apr 28, 2008 | 12:13 PM
Greeny's Avatar
¯\(°_o)/¯
That IM looks familiar?
Old Apr 28, 2008 | 12:17 PM
Greeny's Avatar
¯\(°_o)/¯
Mine looks like crap atm(actually the whole engine bay )
dirty dirty dirty...
I need to take the time to clean her up again..
Old Apr 28, 2008 | 12:22 PM
Pearl93VE's Avatar
I can has?
Haha, yeah... it does look a lot like yours, but I think mine is a tad bit more porous looking for some reason. Maybe not. My engine bay definitely needs a good cleaning too... my hood insulation melted to my strut bar
And now I have to figure out how to get the power valve to open with either an RPM switch or wait to put it on after the 5-spd swap and I have the manual ECU.
Choices choices...
Old Apr 28, 2008 | 12:40 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Choices choices...
the problem with a simple RPM switch is that you only really want the valve closed at WOT low rpm... so throttle position factors as well as RPM. but if you steal the TPS signal you can wire it up in such a way to make it work properly (may need a relay and a diode or two).
Greeny's Avatar
¯\(°_o)/¯
Yeah, my insulation melted to mine also, i just cut(dremeled) some slip down notches into the strut bar holders at the towers so the bar would drop down further..
Easy way= manual ecu
tgreen
Oct 18, 2015 06:18 PM
gustavison
Oct 4, 2015 06:50 PM
Max139617
Sep 20, 2015 07:25 PM
Max139617
Sep 20, 2015 07:09 PM
03VQMAX
Sep 5, 2015 03:47 PM
