ABS humming
Old May 6, 2008 | 05:53 PM
maxima-junky's Avatar
ABS humming
Today I was driving and I hear a humming coming from the car after the initial exceleration was done. I thought it was my ABS so I went around the abs pump and unplugged all the plugs and it stopped. I'm not to familiar with these it's my first Max w/abs. What are the "down the road" consequences to what I've done?
Old May 6, 2008 | 08:40 PM
gfnk357's Avatar
I don't know if there are any long term consequences except no ABS but I had a similar problem happen a few times to me. If I gave the top of the unit a thump with a screwdriver or wrench it would shut off. It happened several times over a few months and then hasn't happened again in the last three years.
Old May 6, 2008 | 08:53 PM
I just wanted to know if it's safe. I had a Lincoln Towncar and the ABS started acting funny. I took it to the dealer and ask how much it would cost to fix? They told me $600.00. I got out the owners manual, found out where the ABS fuse was, took it out and kept it movin. I never had a problem with my brakes after that. I wanted to know if the Maxes kinda worked the same way.
Old May 6, 2008 | 10:12 PM
Wiking's Avatar
Originally Posted by maxima-junky
... What are the "down the road" consequences to what I've done?
hell
but theres a way out of that consequence ... pop these relays out, clean contacts, add contact grease. Also on ALL contacts ... see p14.
Theses under ABS cover, see http://www.cardomain.com/ride/748507/18
Old May 6, 2008 | 10:23 PM
xx-Marshall-xx's Avatar
kthxbye2u
mine goes off when i slow to a stop. not like your ACCeleraction humming
once and a while when i start my car the ABS light is on, and the sound does not come up, air in the lines?...
idk im stumped
Old May 6, 2008 | 10:31 PM
Wiking's Avatar
Originally Posted by xx-Marshall-xx
...idk im stumped
ABS has self diagnostics. Check the linky above, stump the diag....
I cant see how that issue could be bubble -related. Anyways, fluids have to be swapped every 2yrs, just do it.
Old May 6, 2008 | 11:18 PM
Originally Posted by Wiking
hell
Why do you say "hell" what gonna happen worse case scenario? I know someone who removed the whole ABS system from his Max all together. That was 3 yrs. ago. I haven't seen him in a while but what do you think happened to his car?
Old May 6, 2008 | 11:36 PM
Pearl93VE's Avatar
I can has?
eternal damnation
Old May 7, 2008 | 12:54 AM
Wiking's Avatar
__________________
Did I mention the car is fast as hell?
If ABS is out, that doesnt matter but in stoppin distance.
As u asked the worst case, I also included your sig into my answer: it is not fast but waiting stationary in the distance. Nobody should get there with or w/o ABS = prioritizing all during our life is most important. In the ABS-issue, I think u did the right selection...
Btw, the buzzing sound can also 'kill' the battery; I think ABS is better to be out, than intermittently malfunctioning. Be happy, most ppl dont have ABS. But try running the diag, replacing the relays.
Old May 7, 2008 | 05:58 AM
Where are the ABS relays I looked all around but couldn't find em. I see something marked anti skid but someone told me that had something to do w/the operation of the transmission.
Old May 7, 2008 | 06:20 AM
internetautomar's Avatar
mod or sell?
on ALL USDM cars, if you unplug the ABS electronics the brakes will still function normally.
if you leave it connected you may wake up to a dead battery (BTDT).
Old May 7, 2008 | 06:52 AM
Wiking's Avatar
...I looked all around but couldn't find em. ...
U didnt look at the provided linky, thats why... try anew clicky -or- take ABS plastic cover out.
The ABS fuses have that name. Items [3] &[5]
http://www.cardomain.com/ride/748507/5
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
leatherneck
Sep 30, 2015 09:16 PM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
