VG30eT swap into my maxima??!?!
Old May 23, 2008 | 05:33 PM
1991Maxima1991's Avatar
Hey guys i was thinking about swapping out my vg30e to a new vg30et motor in my 91 maxima. Does anybody have any insight on this swap or have any tips or suggestions, id appreciate what you think.
Old May 23, 2008 | 07:33 PM
BenStoked's Avatar
Jesus was a Zombie.
just save your *** some trouble, either a) turbo the vg, or b) search the forum about the swap (ive seen stuff on here...)
Old May 23, 2008 | 08:55 PM
augiedog964's Avatar
It is in the stickies, under 3rd gen modification information, then mtcookson turbo write up. He did the swap to a jdm vg30et from a vg30e. I believe it gives instructions on turboing the current vg in addition to the swap info. Look there, because you will feel the wrath of people saying "search" shortly
Old May 24, 2008 | 05:36 AM
ok thanks ill look else where
Old May 24, 2008 | 06:28 AM
goon9's Avatar
Lol pretty typical. Noobs claims to want to turbo, then isn't committed enough to search for a link that we have archived with the probably the most thorough vg30et swap content on the web.
This happens 1-2 times a month.
We ppl say "Check the stickies." It means this topic has been beat to death and now is archived.
Old May 24, 2008 | 07:02 AM
Hectic's Avatar
Awhile back I was looking through cook's posts about the ET swap, as well as the ones prior to doing the swap. It's funny how much trash people were talking to him about how he's a noob, doesn't know anything, isn't smart enough to do it and finally he busts out with the completed swap and write up. Classic.
Old May 24, 2008 | 07:11 AM
goon9's Avatar
Now how often does that happen?
Old May 24, 2008 | 12:37 PM
vernk's Avatar
read through the 2nd gen write up lots of info, yea yea its not a 3rd gen but it's the same motor and set up.
Old May 24, 2008 | 02:01 PM
Chris Gregg's Avatar
Get Off My Lawn
I just HATE when you run out of room for Mods!
Old May 24, 2008 | 08:09 PM
hadman's Avatar
Nice segue Chris. Very subtle.
Old May 25, 2008 | 06:04 AM
internetautomar's Avatar
mod or sell?
once?
Old May 25, 2008 | 06:06 AM
mod or sell?
but different mounts so there is variation.
anyhow the big thing is, how good is the OP with a welder? if he can't weld then he's SOL and would have to spend $$ to get it all done.
Old May 25, 2008 | 06:08 AM
goon9's Avatar
once?
Thats my point.
Old May 28, 2008 | 01:16 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
its like ppl want some consollation prize or something, you tell them to search then they find out how hard or easy it is then they either do it, or loose interest.
Old May 28, 2008 | 01:47 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
+1000
and my god you've done some updates under the hood! looks... more organized, to say the least.
Old May 28, 2008 | 04:32 PM
Big_E-Dog's Avatar
2nd Gen Boostinator
i try it still looks like a hay stack tho...
its like your not the only one that wanted or wants to go turbo just look first.
the info is out there just look.
Old May 28, 2008 | 06:47 PM
vernk's Avatar
whats the difference in the mounts between a 3rd gen VG and a 2nd gen? I looked but didn't see any good pics where i could see it.
Old May 28, 2008 | 07:06 PM
ok well thanks to goon for the very quickly and ignorantly calling some one a noob again, especially after the problem was solved and i found all of the information i needed in the other forum. There was no need for you to post that after that forum was basically done...
Old May 28, 2008 | 07:11 PM
Greeny's Avatar
¯\(°_o)/¯
What "other" forum?
mod or sell?
they look TOTALLY different.
the rear left mount may be very similar, but it is different. the rear right appears to be taller on the 2nd gen than the 3rd gen.
front and trans don't even look close.
Old May 28, 2008 | 08:11 PM
how come you used to have so many vac lines and hoses and stuff (and kinda still do)? Is it b/c the 2nd gen is less electronic-control-based and more vacuum-control-based? or is it that and/or the turbo setup that did that to you?
Old May 29, 2008 | 02:42 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
like you said more stuff on the 2nd gens is vacumm ran, i could ditch some of it all together but i want it to look somewhat legit if i get pulled over and told to pop the hood, all the solenoids are there and hooded up in the 300zx diagram, yada, yada, yada. got more plans tho, thinking strongly about doing the undone, the most doubted, the most impratical turbo setup ever.....and its not an engine swap...........
Old May 29, 2008 | 10:39 AM
do tell, if only you can via PM. and what would the cops care if it looked like less of a haystack?
Old May 29, 2008 | 01:21 PM
vernk's Avatar
k thanks, just so I make sure I understand what your saying, by "rear left" you mean the engine mount on the back side (as your looking from the front of the car) of the engine (#1 piston side) "right rear"= rear tranny mount? "front" = engine mount on #2 piston side? and "trans" = front trans mount?
so for the most part it's the same set up i.e. they bolt to the block in the same place and then to the same style cross member so it would be just a matter of a little more or less room for piping between the two?
Old May 29, 2008 | 01:34 PM
http://www.courtesyparts.com/betasit...1612_1617.html
for some reason i don't agree with their names. they call the rear engine mount "rear LH" and the front trans mount "front LH"... they then call the rear trans mount "rear engine" and the front engine mount "front engine". I say they have their rear-side mounts flip-flopped in their database. same applies for all diagrams shown.
Old May 29, 2008 | 02:04 PM
vernk's Avatar
Originally Posted by capedcadaver
DAMMIT once again no listings for U11 but thanks
Old May 29, 2008 | 03:08 PM
505max94se's Avatar
TT?
Old May 30, 2008 | 06:12 AM
mod or sell?
I don't know about block mounting locations, but presumably they are in the same locations.
mount location descriptions always stink in my opinion.
I used to have a location description picture guide, but it's not on line.
Old May 30, 2008 | 12:58 PM
vernk's Avatar
if irrc all VGs have all mounting bosses cast into the block so you can take a RWD and put it into a FWD
but yea i can see why the mounts themselves would be a bit different due to the size different s in the engine bay and the way the the the factory piping is set up
my point being that he was asking about info on putting a VG30et in so I thought that I would mention the 2nd gen area where there is info on it.
personally I would stick with the 9:1 cr of the VG30E use 2nd gen ex. man. mount the turbo over the tranny and use a PF intake
Old May 31, 2008 | 03:11 AM
Big_E-Dog's Avatar
2nd Gen Boostinator
yes you are correct about the mounting holes on the blocks all vg30 blocks are the same its some acessories that change such as oil pump, crank, pistions, heads yaa, yada, so you would be able to swap in a 84-88 vg30et into your maxima. its easy as pie, all youd have to do is one motormount(the front one) and downpipe, oil return bung. an dyour good to go.
and if you go factory tuned you dont really have anything to worry about(ecu wise) unless you wanna drag race it then you might pop a head gasket. so go to the turbo section and look at engine electronics.
Slamrod
Apr 10, 2016 05:24 PM
maxima-junky
Oct 21, 2015 05:17 PM
Finkle
Sep 27, 2015 09:53 PM
maxima-junky
Aug 13, 2015 09:59 AM
Blackwind
Aug 5, 2015 06:35 PM
