Door lock timer location
Old Nov 3, 2001 | 07:27 PM
abdiddy's Avatar
Does anyone know where the door lock timer is. My power locks don't work and I want to try to resolder the wires cus I was told that it might work. Also what does it look like?
One.
Old Nov 4, 2001 | 02:42 PM
Aaron92SE's Avatar
NWP Engineering.com
Re: Door lock timer location
One.
Pop the panel underneath your steering wheel. Find the 2"x4"x1" black box to the right of your steering column. When you press the power lock switch, you probably hear a "click, click". The noise is coming from that black box. Pop the little lid off the bottom of the black box and slide out the circuit board and unplug the two connectors. There's your door lock timer.
Look at the joints on the board and you will probably see a joint that has a hairline crack in it. Solder it and enjoy your power locks.
Old Nov 4, 2001 | 02:59 PM
93 SE's Avatar
Grey Box a little bit bigger than the size of a deck of cards. with 2 harness plugs going into it, being held in place by 2 screws
Old Nov 4, 2001 | 03:37 PM
Aaron92SE's Avatar
NWP Engineering.com
I guess Nissan made the door lock timer boxes different colors. Mine is black.
Old Nov 4, 2001 | 04:18 PM
93 SE's Avatar
that is odd,cuz your car is pretty much same as mine,i would understand if it was a gxe
Old Nov 4, 2001 | 04:22 PM
Aaron92SE's Avatar
NWP Engineering.com
Old Nov 4, 2001 | 05:37 PM
dmontzsta's Avatar
Ford Only.
Weird, I just took mine out. And I could find no crack at all. My timer clicked,clicked. But nada! I saw no cracks,no nothing...Everything looked in place.
Old Nov 4, 2001 | 09:35 PM
Aaron92SE's Avatar
NWP Engineering.com
Yeah, I didn't see anything wrong the first couple times I looked at it. Look for joints that are not shiny anymore. If you don't see any joints that look different from the others, then you will have to resolder the entire board and hope that works.
Old Mar 18, 2002 | 08:56 PM
93maxVG's Avatar
Re: Re: Door lock timer location
I did a search because my locks werent working. Found this......what joints are they talking about?? On the bottom of the circut board?? Im not good a soldering either. Cracks on the bottom? Im Clueless
Old Mar 18, 2002 | 09:06 PM
«§»Craig B«§»'s Avatar
Re: Re: Re: Door lock timer location
they're talking about the solder joints on teh bottom side of the circuit board
when solder goes bad, sometimes the joint will start to dry out or crack; sometimes you cant see it but sometimes you can, hard to tell if you dont know what you're looking for though
the board needs to be resoldered and that should take care of it, use flux too to help the solder flow better
If you dont know what I'm talking about, you probably want someone else to do this for you. If you dont know anyone who knows how to solder, try PMing Matt93SE, I know he used to do it for a small fee
Old Mar 18, 2002 | 09:11 PM
93maxVG's Avatar
Re: Re: Re: Re: Door lock timer location
I do know what you are talking about, but unfortunally, I dont have anything like that. Where can I pick it up??
Old Mar 19, 2002 | 01:37 AM
Bman's Avatar
Re: Re: Re: Re: Re: Door lock timer location
If you're talking about flux, most places that carry solder will also have this stuff in a little tin.... but I thought solder wire already had flux impregnated in it? It's been a while since I've soldered anything...
Old Mar 19, 2002 | 04:02 AM
Taegost's Avatar
Re: Re: Re: Re: Re: Re: Door lock timer location
Most does... Go to Radio Shack and pick up a soldering kit for like, $10... Not the greatest, but it comes with soldering iron, stand, solder (ERrr, I can't remember the ratio, I think it's 60/40 is MilSpec) and some extra tips...
I use it for computer work and electronics repair all the time
Old Mar 19, 2002 | 09:12 PM
93maxVG's Avatar
I did it! Soldered some today, and now my door lock work. I wasnt sure which one needed to be done, so I just started goin at it, Plugged it in, and it worked. I love this forum, gives great advice.
Old Mar 22, 2002 | 02:40 PM
phat's Avatar
What about door lock working intermittenly( off/on)?
Old Mar 22, 2002 | 02:52 PM
yup, try it
Old Mar 23, 2002 | 11:30 AM
93maxVG's Avatar
yea, thats what mine used to do, untill they started not working at all. Do it, and they will work!
Old Mar 26, 2002 | 05:55 AM
phat's Avatar
Do what? I didn't get the instruction.
Old Apr 28, 2002 | 09:44 PM
ezra's Avatar
Solder Info...
I recently proceeded with this operation on my maxima and here are my conclusions. My locks were working intermitently but it was malfunctioning often enough that I wanted to try this solution. I'm definately a beginner with cars and although I am somewhat familiar with circuits, I have never soddered any before.
It was very easy to take off the panel under the steering wheel using a ratchet set. I don't know why the mfc's use some regular screws that you can't use a ratchet for however. Locating the box was also very easy following the above instructions. I had some minor difficulty sliding the circuit out of the black box. Instead of taking off the entire black box, I opted for popping the thin cover off of the top of the box (the part the plugs connect to which is attached to the circuit) and sliding it out while the box was still attached. This was because I saw no easy way of disconnecting the box.
As far as the soddering was concerned this was rather difficult for me. I was using a 40Watt Craftsman soddering iron (which I think is probly too hot for small circuitry) and a tip that was probly to large for the job (as well as sodder that was also probly to thick). After some examining of the board however, it was rather clear which joint on the bottom of the circuit was causing the problem. There was a circular blob joint that had a circular crack that went around its base, effectively breaking the connection most of the time. Looked kind of like this (magnified):
Code:
  ______
/ .... \  The inner part here is the crack
|{    }|  The XX is where I dropped a blob of
| ~~~~ |  sodder to make my connection.
\__XX__/
I found it very difficult, using the iron, tip, and sodder that I had. After numerous attempts to do a nice clean job of going all the way around the circular crack, I was only able to land a blob in a place that I thought would make the connection. A couple times I believe I got sodder too close to other components however I was able to re-heat that sodder and remove it (I found it useful to use a spliced copper wire to scrape of the excess sodder. I believe using a copper mesh is a method that is often used however I did not have that available). I should note that a clearish brownish liquid came out of the sodder after it was melted. I wonder if this is melted resin because the sodder was resin based? It didn't cause any problems so I am assuming it does not conduct electricity.
In the end, when I plugged the circuit (which was slighly singed around where I had been working) back in, the locks worked fine and everything has worked for the past 3 days. So far so good What did I learn from this expirement? I need better soddering tools
I hope this helps out other's and if anyone can give me any soddering tips I would certainly appreciate it. Now.. to find out why my horn works intermittently ...
Old May 14, 2005 | 11:59 AM
aussie983's Avatar
Okay my door locks are acting intermittently, but im having trouble locating the grey/black box, and ive looked all around the bottom steering column area. Does anyone have a pic that they could maybe circle the area. Id appreciate it. I dont see any panel i can pop off unless it that big long one that requires taking off the screws?
Old May 14, 2005 | 03:05 PM
yes, take off the lower panel that has screws in it
Old May 14, 2005 | 03:12 PM
JTs93SE's Avatar
This should help
http://www.thewardrops.com/maxima/
Old May 14, 2005 | 09:28 PM
aussie983's Avatar
Thanks guys, thats exactly the sort of thing i was looking for.
Old May 15, 2005 | 12:44 AM
JTs93SE's Avatar
Maybe that site should be made into a sticky?
Old May 15, 2005 | 01:37 AM
Wiking's Avatar
Originally Posted by aussie983
... but im having trouble locating the grey/black box, ....
I have no problems with the doors: Maybe its because my max has no such box... lol. Anyways, only the ASCD metalbox, on top of that blk plastic relay.
Door wiring schematics: http://www.cardomain.com/memberpage/748507/13
My box must then be at left of steering column, black. Its in the place US models have the theft alar box. (My alarm is not factory installed.)
The doorwebsite is excellent, more these!
Old May 15, 2005 | 01:55 AM
Wiking's Avatar
Originally Posted by ezra
...As far as the soddering was concerned this was rather difficult for me. I was using a 40Watt Craftsman soddering iron (which I think is probly too hot for small circuitry) and a tip that was probly to large for the job (as well as sodder that was also probly to thick). ....
If I understand right, that is the pistol heavy loopy resistor harpoon? That tool is for sewer pipes, never use that with electronics. Its handle will get more hot than the tip... RadioS has right tools for 9$. Also do not use thumb thick tin (sewer -class), but only thin, reeled electronics solder. If not using proper tools, u burn u printed circuit board PCB +plus u hand.
End of story: U will end hating all electronics repair job.
Old May 15, 2005 | 03:08 AM
jacsmax's Avatar
This is supposed to happen. Solder contains not just the metal but also flux. When you heat the solder, the flux melts just before the metal and flows out around the point you are soldering to help clear contaminants on the surface (from oxidation etc). Oh and it dosen't conduct electricity so don't worry
As for soldering tips, heat the component lead/wire and the pcb track then introduce solder when its hot enough. Don't actually touch the solder with the iron, it should not be necessary. It should melt and flow around the lead to form a neat upside down cone (ideally). Make sure your tip is clean then tin it with a little solder, this helps heat transfer.
Correct me if Im wrong with any of this, but thats what I was taught.
Old May 15, 2005 | 03:57 AM
aussie983's Avatar
That is correct. Always heat the lead then apply the solder to it, or else you will end up with a rosin joint, which is not good.
Old May 15, 2005 | 04:56 PM
bhunter's Avatar
One more tip from an old solderer--Get yourself a Soldapulit. It looks like a funny syringe sort of thing. You set the thing by depressing the spring loaded piston on the top. Set the tip of it against the old solder joint and heat it with the soldering iron. When the old solder melts, press the button on the side and the device sucks up the old solder. Re-solder the joint with new solder. This thing works much better than the copper braid solder remover as the joint doesn't get overheated. If you solder much you have to have one of of these things.
Old May 16, 2005 | 04:40 PM
swowlinc's Avatar
1993 SE
Just fixed mine too, thanks to you guys...and a POS Cold Heat soldering tool!!
Old May 22, 2005 | 05:04 PM
schellbell's Avatar
When i close my driver side door it unlocks, thus unlocking all four doors in my car. I really look like a retard cuz i have to lock my door everytime with my key from the outside. I close my door gently and it still unlocks...... any help?
Old May 23, 2005 | 07:07 AM
internetautomar's Avatar
mod or sell?
hold up your door handle when you close the door
ef9
Sep 29, 2015 11:29 PM
johnaschon
Sep 14, 2015 04:29 PM
Hailstatejig
Sep 2, 2015 06:52 AM
