Steering column alignment / higher gears
So I posted a while back about me having to hold my steering wheel quite a bit to the left for the car to go straight, otherwise it'll just turn right constantly. not fun.
After my car fire and new rust damage from the past winter, Fixing this car became a project. But it's one step at a time, and first on the list is this goddamn steering problem, of which i noticed something that I should have noticed a long time ago, but never really... payed attention.
When I first start up my vehicle, the steering wheel is pretty much straight and need to turn it slightly to keep it straight, recently upon shooting out of an intersection whilst flooring it (heck it's still a mechanically sound dream car), I noticed the shift in gears and the steering column itself showed another piece of evidence to this problem...
after letting my foot off the gas the steering shot to the right pretty quickly, and I quickly compensated by yanking the steering wheel to it's 'normal' hap-hazard jerk - it - to - the - left spot.... So, apparently my steering needs to be pulled further and further to the left with each higher gear. Alas, I no not what that's all about, and I could really use some skilled insight from my fello 3rd gen freaks so that I may better able myself to fix this thing one step at a time.
And don't worry, another 3rd gen isn't going to fall into nothingness. This thing will be restored, as God as my witness.
yeah.... check your pass side control arm bushing. its probably gone from power steering fluid leaking onto it and you have no bushing.
replace your control arm as Matt said.
internetautomar sells them for cheap and comes with all the hardware i replaced mine a week ago
Oh wow I'm dumb. Thanks.
If I have to hold my steering wheel to the left... And my front left tire is constantly loosing air and wearing down much faster then my other tires... I'm guessing, it's the lower left control arm that needs replacing? or the right?
Yes, I'm learning here.
James92SE
142
Jan 2, 2024 09:23 AM
BrandonCause
Sep 14, 2015 10:41 PM
