5 spd jumps out of first gear.
Lately I've notice that when I'm in first and try to move off the gear shift jolts out of first. It would only stay in gear if I hold it in place. Any ideas on the problem?
I was hoping you wouldn't say that. There was a time when I started the car and heard a grinding noise, it turned out to be the starter was hanging on by a bolt. I think when I started it some teeth from the flywheel broke.
I guess your right about getting a new tranny. if and when I get one I'll have the shop check it out before I put it on. How long do you think I have left on the old trans.?
well that is typically associated with an input shaft bearing, but some other type of internal rubbing on the input shaft could cause that as well. i forget which shaft the 1st gear meshes to.
first he can check that check ball, and also see if it's a bearing gone bad on one of the shafts... also the throwout bearing makes noise when the clutch is DOWN, he said his noise goes away when the clutch goes down.
it's a metal ball, about the size of a medium sized pearl, that is pushed on by a spring. the shift rods have little divits in them so when you put it in gear, the divit moves over the ball, ball pops up into it, and holds tension on it. pull it out of gear you feel resistance then it just loses resistance into neutral.
http://www.zukiworld.com/month_01010...wler/step7.jpg
if that spring breaks, the ball won't push on the divit anymore. there's like 5 of them i think? maybe more maybe less.
sounds like the input shaft bearing is gone, when the plastic spacers between the ***** falls out and the shaft is free to move around and soon the plastic pieces will get jammed in the shifting forks and lock you out of gears, try not to drive it that much if at all and get new bearings put in ASAP
or check with maxima-junky to see if he has a tranny
This may help. Today I parked and put it in 1st gear. when I took my foot the clutch and brake, the car kept rolling. Its as if 1st doesn't engage at all and/or the teeth on 1st gear are worn. I put in reverse and it didn't move when I parked.
only way to fix either problem is to pull the tranny.
rebuild the tranny and install a new clutch kit (w/ to bearing) while you're in there and it'll be done.
expect $1200 if you pay a shop. you can do it yourself for about $400 in parts.
It's not a check ball.. Caped is taking a wild guess and is confused. If there was a missing check ball, it would get locked in or out of gears, not pop out.
Input shaft bearing needs replaced, brass needs replaced.
wild guess, sure you can call it that. I've heard of issues with particular gears caused by check ball problems... after reading more of what he said I realized it wasn't a check ball-related issue after all, but didn't actually make a post saying so. no need to call me out mang...
if the bearing is worn, the shaft isnt where it should be, its wobbling around. it would pop out of a gear if not fully engaged, and the car could roll if the gears are not touching.
Nmax: A broken IPS bearing alone is most likely not going to cause it to jump out of gear. I drove for about 10k miles with a blown bearing and finally I was forced to replace it because it started to make bad gear grinding sounds when I let off the clutch or i'd be unable to move the shifter to the 1-2 side of the gate, and position switch was shorting out and kept blowing the engine control fuse just by moving the shifter. All 3 of these syptoms started happening at the same time, but it never jumped out of any gears. If that's what's happening, on top of the input shaft bearing, you're probably looking at a complete rebuild because you have two seperate issues. If you just replaced the input shaft bearing, I bet it would still pop out of gear because of worn synchros. What ben said is likely the cause of the grinding sound that I experienced, but it's not going to make it pop out of gear because the alignment (or misalignment) of the input shaft doesn't have anything to do with how the gears mesh.
Anyway, it's replacement tranny or rebuild time.. At the very least, you could do what 505Max has done before and work on the tranny while it is on the car by taking the cover off. To do that though, you really need to know how everything goes together or it will be easy to lose things. In order to rebuild the shafts, you need several specialty tools as well as a press. All you need for the input shaft bearing is a press really but like I was saying, sounds like you need all new brass which requires a rebuild of the shafts. If you pull the tranny yourself and take it to a shop, you could get a decent price on a full rebuild. Opposed to having them remove and reinstall it.
I wasn't calling you out, I just assumed you were confusing other threads about being stuck in gear, with popping out of gear..
Anyway, it's replacement tranny or rebuild time.. At the very least, you could do what 505Max has done before and work on the tranny while it is on the car by taking the cover off. To do that though, you really need to know how everything goes together or it will be easy to lose things. In order to rebuild the shafts, you need several specialty tools as well as a press. All you need for the input shaft bearing is a press really but like I was saying, sounds like you need all new brass which requires a rebuild of the shafts. If you pull the tranny and take it to a shop, you could get a decent price on a full rebuild. Opposed to having them pull and reinstall the tranny.
if you continue to drive with the bad bearing it will wear on the main input gear and soon the gear set will have to be replaced or the whole tranny will be worthless and these trannys are getting hard to come by these days
ef9
Oct 4, 2015 08:43 AM
Need help
23
Oct 2, 2015 08:56 AM
markevans999
Sep 10, 2015 04:29 PM
trungg86
Sep 4, 2015 04:58 AM
