Transmission problems
Old Jul 2, 2008 | 07:41 PM
'93maximaGXE's Avatar
Sorry if this has been brought up already, but i don't really have time to look for it. So here's the problem. My transmission keeps slipping out of 3rd gear so i have to drive in 2nd gear and earlier this afternoon i started it and every time i put it in reverse, drive, 2nd, or 1st gear, it shuts off. Please don't tell me the only option i have is to get a new tranny.
Old Jul 2, 2008 | 07:47 PM
Darkwing48's Avatar
Your second problem sounds like Idle Air Control Value/Mass Air Filter problem to me. Try cleaning it. you can do it by searching the older threads, it has instructions to do so.
Old Jul 2, 2008 | 07:51 PM
i just cleaned it the other day so i don't think that's it
Old Jul 2, 2008 | 09:36 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
how violently does it shut off?
Old Jul 2, 2008 | 09:44 PM
it shakes the whole car pretty roughly
Old Jul 2, 2008 | 09:54 PM
and it snaps off very quickly or fights and fizzles out. if it snaps off suddenly there's a rogue chance that your tqconverter is locking up when it shouldn't. the odds are slim, but it is possible, if there's a wiring fault or hydraulic failure of some sort.
Old Jul 2, 2008 | 09:56 PM
it kinda fizzles out quickly. haha
Old Jul 2, 2008 | 10:15 PM
if you get it to stay running somehow does it drive in a manner that is very jerky and harsh, almost like it's a manual?
Old Jul 2, 2008 | 10:38 PM
yes
Old Jul 2, 2008 | 11:16 PM
yes
and if you come to a stop does it kickdown through the gears (od to 1st around 1100rpm) roughly, and then just die when the car stops?
Old Jul 2, 2008 | 11:25 PM
yes
Old Jul 2, 2008 | 11:29 PM
i just started it and put it in drive and it seems fine now
Old Jul 3, 2008 | 01:28 AM
LvR's Avatar
LvR
Read this - most likely the same situation and possible temp cure, delaying the inevitable
Old Jul 3, 2008 | 09:21 AM
thanks, i want to get a 5-speed anyway, but i dont have any extra cash
Old Jul 6, 2008 | 07:41 PM
UPDATE:
tranny seems to slip into neutral changing from 2nd into 3rd gear, but only when the engine is cold.
any suggestions greatly appreciated.
thanks.
Old Jul 7, 2008 | 12:34 AM
daftinnovations's Avatar
do you think the soft or firm shifting options on automatics would have anything to do with it ?
Old Jul 7, 2008 | 01:19 AM
say wha?
Old Jul 7, 2008 | 05:02 AM
there's no such option..... what are you talking about?
comfort/power? has nothing to do with soft or firm. all that controls is what rpm it shifts at
Old Jul 7, 2008 | 10:27 AM
internetautomar's Avatar
mod or sell?
UPDATE:
thanks.
your trans is toast.
you can try to extend it's life a little with some fresh fluid and some lucas.
Old Jul 8, 2008 | 11:18 AM
Darkwing48's Avatar
Sound's like my car, months after a bought it. You're tranny's giving you the slip = rebuild.
Old Jul 8, 2008 | 06:05 PM
1992maximase30's Avatar
removing the harness for the line pressure resistor might work....
or try to have the shift cable between D and 2 and see what happens.
Old Jul 8, 2008 | 09:05 PM
would it be easier and or less expensive to do a 5-speed swap?
Old Jul 8, 2008 | 09:09 PM
that's an express trip to the tranny graveyard, mang
slightly less expensive but not necessarily easier. depends how easily you can get your hands on all the swap items. and whether or not you feel like driving a stick all the time.
Old Jul 9, 2008 | 09:04 PM
^^ i kno, i kno but it seems he's showing symptoms of the tranny goin.
my ve did the same thing...
Old Jul 9, 2008 | 09:12 PM
well if the tranny is going then no need to play with anything... just replace.
Old Jul 9, 2008 | 11:36 PM
but the problem is i am a little tight on money right now.
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
boomerbrian
Oct 31, 2018 10:25 AM
The Wizard
24
Oct 1, 2015 08:47 PM
