Ahhhhhhhhhhhhhhhhhhhhhhh..........
Old Jul 18, 2008 | 03:42 PM
ProphetVG30E's Avatar
-now my maxima stalls almost everytime i come to a stop. what the heck.
-im thinkin its either a clogged converter, bad sensor, or something REALLY stupid.
193K miles by the way. anyone have any ideas????
Old Jul 18, 2008 | 03:46 PM
Pearl93VE's Avatar
I can has?
Clean IAC, Throttle Body, EGR, Etc. All Intake Parts with Throttle Body Cleaner.
Clean MAF with Electrical Contact/MAF Cleaner.
See if it helps. Remember to get new gaskets for IAC/EGR.
Old Jul 18, 2008 | 07:44 PM
-figured it was along that line. searched alldata for diagnosis, but i swear, sometimes i think they need to change their name to nodata.com
Old Jul 18, 2008 | 08:37 PM
burhan92SE's Avatar
how long its been since u changed ur fuel filter? check ur fuel pressure and volume...believe it or not u could try to advance ur camshaft sensor timing...only TRY
Old Jul 18, 2008 | 08:44 PM
mikekantor's Avatar
just throwin this out there: vacuum leak
Old Jul 18, 2008 | 08:56 PM
fuel filter hasnt been changed since i bought it.
Old Jul 18, 2008 | 09:55 PM
Pearl93VE's Avatar
I can has?
Get to it then! Hah...
Vacuum leak is also a good one, check all around the engine for cracked/broken/disconnected hoses
Old Jul 19, 2008 | 07:55 AM
Matt93SE's Avatar
STFU n00b!
IACV.
Old Jul 19, 2008 | 10:08 AM
first thing i assumed was a vacuu leak. no vacuum leak.
Old Jul 21, 2008 | 10:06 AM
ninjasword71's Avatar
Mine did that awhile ago. It was my MAF sensor (Mass Air Flow). Bought one on e-bay for $25 and works perfect now. You could check your computer under your dash for the specific problem.
Old Jul 21, 2008 | 08:05 PM
sleepyvg30e's Avatar
if u got a k&n air filter that will happen with your MAF if you dont clean it
Old Jul 21, 2008 | 08:16 PM
burhan92SE's Avatar
how long its been since u bought the car....?
Old Jul 21, 2008 | 09:27 PM
3g94MaxGXE's Avatar
urban myth'd
http://www.knfilters.com/MAF/massair.htm
When I started having problems with my car with the cone I blamed the oil. I think it boils down to the fact that some mechanic didn't like a cone and made up some snake oil myth or maybe it was an accident just like when everyone told me my car wouldn't start because my starter was bad when all along it was a neutral safety switch. My MAF screen got dirty from being stock for 120K miles. I haven't noticed anything from wiping the screen since I bought my cone.
Old Jul 21, 2008 | 09:42 PM
Pearl93VE's Avatar
I can has?
Originally Posted by 3g94MaxGXE
urban myth'd
hmmm... I can actually feel my cai tube on the inside when I take off the filter and feel a very thin slimy substance. I guessed oil.
Old Jul 22, 2008 | 08:40 AM
braxsusriely's Avatar
Can you turn on the A/C to test if its the IACV?
My car was comming to a stall to when i'd push the clutch at a light. New fuel filter and properly gaped NGK plugs not Autolite XP.
EDIT: After replacing the plugs and fuelfilter i got my smooth idle back
Old Jul 22, 2008 | 08:45 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
speaking of a/c and iacv stuff, is the idle supposed to bump up a little when you push the clutch when stopped, put it in gear, and slightly lift (enough to get off the clutch-start switch, but not enough to actually start engaging the clutch? or maybe it's just because i am still using my old a/t ECU, and it's compensating for my nonexistant torque converter.
Old Jul 22, 2008 | 03:24 PM
cleaned the MAF sensor. and now, it only sounds crappy. thanks
Old Jul 22, 2008 | 05:47 PM
MaximaN00b's Avatar
lol.. sorry, shouldnt laugh at that.. just how you said it was funny.
Clean the IACV like people have been saying.. that and Id say check your fuel injectors! + Yea change the fuel filter yet? It's a $10 part, 10 minute job. You have high miles, could be many things.. PCV valve, simple cheap, change it. Just, tune it up, start cheap to narrow things down.. Change the plugs, new distrubutor + wires..
set timing..
Old Jul 23, 2008 | 01:41 PM
CMax03's Avatar
Could also be your Maf sensor wiring harness. They tend to break wire strands and cause the idle to be erractic( right at the valve cover). Are you sure it's not an injector or spark plug? Also what are u driven an auto or manual? If it's a auto then your idle maybe set too low!
Old Jul 23, 2008 | 03:17 PM
i meant with the exhaust leak and all. the injectors are gonna be replaced soon, and the wires nd plugs gonna be as well. by the way, 92 max auto, 194K, daily driver 100+ miles 5 times a week.
