K&N Drop in filter question
Old Nov 6, 2001 | 11:20 AM
Pickwick's Avatar
I just got a K&N Drop in air filter, the one that "can run for 1 million miles." What type of gain did I get when I put it in? The car feels a lot more responsive and quickre, but it could just be that I am just thinking that since I just put it in.
Old Nov 6, 2001 | 11:27 AM
SEguy182's Avatar
i didnt feel much gain over stock when i had one. i had it for about 2 months and replaced it with an intake..i felt more power up top with the intake. next step is CAI.
Old Nov 6, 2001 | 11:32 AM
«§»Craig B«§»'s Avatar
not very much, maybe 1HP or so
that's the thing about intakes, the noise is usually more noticable than the gains
as for CAI, you will definitely notice something
Pop charger - a little difference
panel drop in - tiny bit
Happy Birtday James
Old Nov 6, 2001 | 11:35 AM
MadMaxBrent's Avatar
Probably not much unless you have a good exhaust combo to work with the filter. I would say less than 5hp if you have no other mods but you will find it is more responsive as you said.
I had to remove my K&N panel filter due to erratic idle problems, but the car did feel better when it was installed.
Brent.
Old Nov 6, 2001 | 11:37 AM
Sonic's Avatar
You should notice no difference at the track or dynoing.
Old Nov 6, 2001 | 07:25 PM
Z's Avatar
Z
like craig said, you probably get 1hp gain. But on my VG, and I know allot of others have had irratic idling problems.
Old Nov 6, 2001 | 11:10 PM
Pickwick's Avatar
That you for the quick responses. I figured that the difference was small, but at least it's a step forward. Slow and steady...comes in last most of the time.
Old Nov 7, 2001 | 09:07 AM
Pit5Bull's Avatar
Pickwick…
I've only had the drop-in K&N in this car (I bought it used, and it was already in there!) I'm planning on getting the CAI, and then the y-pipe (most likely Warpspeed for both).
I seemed to notice that when I removed the piping from the airbox (the one that leads to the area behind the drivers' side headlamp) that my pick-up and responsiveness was a little better (not much). If you're planning on getting a CAI or a popcharger, you'll probably want to (need to) remove this anyway, so why not do so in the meantime and see what you think?
peace2u
Old Nov 7, 2001 | 09:12 AM
Pickwick's Avatar
Re: Pickwick…
peace2u
Just cut off the part that is a "poor mans" cai?
Old Nov 7, 2001 | 09:45 AM
Pit5Bull's Avatar
Poor-man's CAI…
Yeah, if you want to call it that (and if you do, it'll be very loosely called - CAI )
BTW - You'll have to unscrew it instead of cutting it off, unless you don't mind the engine bay remnants. Good luck
peace2u
Old Nov 7, 2001 | 01:50 PM
Pickwick's Avatar
Originally posted by «§»Craig B«§»
maybe 1HP or so Happy Birtday James
Now I am one more HP closer to the 93se I should I bought.... and thanks
The Frye
Sep 2, 2021 11:03 AM
aminus21
Sep 12, 2015 04:53 PM
Maxboy23
Sep 4, 2015 06:04 PM
lux97Max
Sep 4, 2015 05:42 PM
sdotcarter
Sep 2, 2015 09:53 PM
