Water **** Solenoid
Old Jul 23, 2008 | 06:39 PM
burhan92SE's Avatar
Water **** Solenoid
how would you find out if your water **** solenoid is working properly or no?
Old Jul 23, 2008 | 06:46 PM
Hectic's Avatar
Go to the urologist.
Old Jul 23, 2008 | 06:49 PM
BenStoked's Avatar
Jesus was a Zombie.
HA! HAHAHA! HAHAHAHAHAHAH! hoh!
ahem...
Old Jul 23, 2008 | 06:52 PM
BenStoked's Avatar
Jesus was a Zombie.
anyway, what are you talking about? the valve to open the heater lines? its the only valve I can think of, except the thermostat...
Old Jul 23, 2008 | 07:10 PM
burhan92SE's Avatar
lol...
Old Jul 23, 2008 | 07:14 PM
burhan92SE's Avatar
ya ya u r right benstoked....ya ya u r right benstoked....there two small hoses rite? one go to the engine and one go to this solenoid....my heater stopped working so wat i did i took out that one hose which goes to that solenoid and my heater started working and wen i put that hose bak my heater stopped working...what should i do?
Old Jul 23, 2008 | 07:15 PM
HM_Motorsports's Avatar
Dude I just spit Mt Dew all over the screen.
Burhan I think you're talking about the heater control valve? I'm not real familiar with 3rd gens but most cars I've seen are just vacuum controlled, and you can just apply vacuum to it and see if it moves freely. Or move the rod manually and see if cures your problem. Is it not heating? Or what?
Old Jul 23, 2008 | 07:17 PM
Probably available at a parts store, they're ussually pretty cheap to buy.
Old Jul 23, 2008 | 07:23 PM
BenStoked's Avatar
Jesus was a Zombie.
I would not recommend trying to move it manually, as you could damage the diaphragm(sp?). either try the vacuum method, or get in the car, start it up, with the temp setting on cold, make sure the blower is on. now make a mental note of where the plunger is. turn it to hot. has the plunger moved? it wont be much, maybe 1/2 inch (a cm or so), but the part is small, so you should see a difference.
no change? check the vacuum lines. longer one should have a little disk like thing near the valve, on the line. the other end should attach to the intake manifold, on the passenger side, on the back. make sure the lines arent cracked.
Old Jul 23, 2008 | 08:25 PM
Chris Gregg's Avatar
Get Off My Lawn
These little vacuum lines are renowned to crack or disconnect themselves from the water **** (which is what Nissan calls it). I check these lines every time I pop the hood.
Old Jul 23, 2008 | 09:05 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
ibnissannameditadirtynameonpurpose
Old Jul 23, 2008 | 09:22 PM
Cinnamint's Avatar
lol, water ****
Old Jul 23, 2008 | 09:32 PM
scarface4522's Avatar
hahahahahahaha
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
uttadms31
Sep 30, 2015 05:24 AM
RWCreative
Sep 21, 2015 11:01 AM
