RIMS
ya i read wut u said at the first time but the rim shop i went to ( they only deal with rims everyday) told me to use 25mm spacer only on the REAR...fronts r just fine....i m not saying u r not right....but hey lets see wat they do....i m going to the rim shop in 2 or 3 days...see wat happens..
they r not charging me any money for labor cuz its my friend's friend shop...and for 25mm spacer and 15 mm spacer they were charging me same amount...50 buks....the same spacer i was getting from other shops for $150 a pair....so charging me extra money is not the matter..i could do all that stuff by my self but then why not if they r doing it for me...oh well lets see wat happens cuz they r giving me 15 days money back warranty on it....dont like it bring it back we will take the spacers out and give u ur money bak....
- put your tires under the fender itself, causing you to rub like I did, even on STOCK ride height
- eat up a full INCH of your wheel studs, meaning you will have nothing left to thread your lugnuts onto
- put undue stress on your rear wheelbearings, (do you know what happens when wheel bearings fail?)
it doesn't matter if you can get a 1000mm spacer for the same price as a 15mm spacer. 25mm on a hX7.5X45mm wheel is too much for a 3rd gen maxima. Goon ran 18x9x40 with 18mm spacer (compensated offset of 22mm) and he had to ADD material to his fenders to keep the tires from hitting them. Are you interested in major bodywork?
listen burhan. money isn't the issue with the spacers. running a too-thick spacer will do 3 things here:
I cannot be sure about the severity of strain on the bearing in this case (too lazy to do the math, changing location of leverage, etc.), but just because they are giving you a deal on spacers, and maybe studs, will it be worth it in the long run? you made it sound to me that it was almost right, why go to extremes? if all you need is a few more mm, go with what would work, save you (and your buddies) a **** load of work on changing studs. but if you got 'em doing it, may as well change the bearings back there, at the same time.
edit: or theres another way... i have a friend who is machinist he can machine them exactly to wat i will tell him....so if u guys really think that this isnt gonna work out ( experience ) then i wont even bother doing all that stuff and i will just have them machine to probably 18 mm...?
i totally agree with ur that point, thicker the spacer the more stress will be on bearings...absolutely no doubt....but the idea we came up with is that they r going to put 25mm spacer and we gonna measure that how far is the wheel from the strut and how out its from the center line....then i m going to drive it for 4 todays maybe 5 days then i will see in these 5 days how the ride is and if it touches the fender or no....then we r going to take the wheel off and inspect the threads of studs and condition of the bearing if anything went wrong or no....then we r machining the spacer to make it thinner....probably around 20mm then that would be ok cuz i want the minimum stress on bearings...and as u r talking about that i will be left with less threads to bolt on so i think this the picture and bolt will be all way tight....and in any case to jus make it clear u r talking about only REAR rite? cuz i m only talkin about rear lol....heres the pic of hubcentric spacer.... ( i m thinking of selling the tires cuz u guys made me scared now lol specially BEN )
arite... i finally installed them...first i sanded them with hand all 4 wheels and dont ask it was really hard to sand them all with hand then i washed them, cleaned them then painted them with white and left them in garage for 2 days with cover on.......next, i installed 25mm spacer on the rear and ntn on the front.....and i changed the tire size to 225/50/16 instead of 225/60/16 ( decreased the ratio, more wider and less height )...no fender rubbing with them at all and 25mm spacer was perfect on the rear...might machine the spacer in future to 22mm but doesnt really need it since its perfect.....here i took some pics with my CELL PHONE CAMERA i will take more inside side pics of the rims in the morning...
sounds like luck that they aren't rubbing in the back. tho, my rear struts are blown to hell and yours might not be. how close are they to hitting the fender if you have a friend sitting in your open trunk?
o ya greeny i remember that...thats the important part...but our instructor changed and the new instructor doesn't even let us work on our own cars...and thats the reason i couldn't even take the axle out and take the pics....i m waiting for him to change hes only teaching us engine mechanical for 5 weeks then our old instructor gonna come back and then i will be able to take pics....and at home i dont have tools available for do that job....i will take pics of the axle hole as soon he leaves....
alots of space cap...i have a heavy *** boom box of two 12 MTX woofers in the trunk all the time...no rubbing even if someone sitting on the back...
<<---------------- REAR
i know you have plenty of vertical clearance on non-collapsed struts. Mine sag a lil bit i think. this is what i have for vertical clearance (sorry best pic i have atm.. no glamour shots on the new 2k2 rims yet)
i want to see how much you have for if you ever lowered the car on eibachs... or lower. this istake one from this angle:
yours is 7.5" 20mm compensated offset (wheel - spacer)
yours should stick out a bit more than mine did.
ok, i been driving around on normal city speed limit ( 35mph) and didn't notice anything but today i went on the highway and i pushed the car up to 60mph and i felt pretty harsh vibration in my steering then i came down to normal speed around 35mph and vibration was gone....i came home and checked the clearance on the front between struts and the tires and there were pretty gud clearance between them and obviously on the rear i have plenty of clearance....
now my question is that if my struts were bad or bearing i would feel that vibration on low speed too?...but i only feel the vibration on high speed so COULD it be that tires r not balanced properly? the guy who did the balance probably didnt do it properly?
If no, did you put used tires on the wheels, or new?
Did you check the wheels for any bends?(inner lip)
no we dont have snow yet but its really cold around 46F in day time and around almost 33F at night....
yes greeny wen i bought the rims i got tires with it but 2 of them were badly worn out and 2 of them were in really good condition like 80% tread left...then i changed the other two to almost brand new tires but they were used for a month only and had like 95% tread on them....tires r gud and i inspected the rims too i don see any bends on any of them....
we are already below that here and we have snow.
i was wondering wat happened this time in VANCOUVER it didnt snow yet and its almost December....in other cities like calgary or toronto its already snowing since 2 months....i guess its GLOBAL WARMING lol
about the rims... like what'shisface said, are they balanced
Originally Posted by burhan92SE
i was wondering wat happened this time in VANCOUVER it didnt snow yet and its almost December....in other cities like calgary or toronto its already snowing since 2 months....i guess its GLOBAL WARMING lol. except i dun rly believe dat CRAP lol who wud?
i didnt say that red part lol
and about the rims....i m gonna go to shop back and ask him if he balanced them properly and to show me again if they r balanced....
anyhow, yea, get a verification that they are balanced right. i can tell you first hand that unbalanced wheels will make the whole car shake like a jackhammer. when i first put the SE sawblades on, one of them was 2.25oz out! that's 2 weights worth! and my god that thing was torture even at 45mph! got the front to rebalanced and it was better.. still had one bent rim tho.
i added it, hoping that you were at least thinking it in your head...
and thanks man...then it must be unbalanced tire and the guy who did the balance looked suspicious to me tho...
Make sure all 4 tires have been balanced, not just the two you had put on.
ok i have a question which maybe never been asked before.....
now i have changed my tires size and rims from OEM....how much air i suppose to have in tires now? in OEM tires specs it says 29psi front and 29psi rear..thats wat it says in gloves box sticker tho....so air pressure changes with tire size changed?
225/50/16....
225/50/16....
225/50/16....
225/50/16....
but uh... on a shorter-sidewall tire like that, you will need a little more air pressure in the tire. those super-incredibly-low profile tires (like 30-35 profile) sometimes run 50psi... but on a 50, i'd use something more like 35. Keep an eye on tire wear to see if it indicates underinflation or overinflation though.
and seriously... "a question that's never been asked before"... about tire pressure...
225/50/16....
225/50/16....
NO!
that just tells you the maximum pressure the tire can handle! The tire manufacturers have no idea what car you're putting it on....... they just make tires.
For me, I have the same tire size as a stock 17" 5.5gen, so i can just look in the 5th gen forum and copy what people over there are doing. Burhan might be able to go to a Z forum and copy what they are doing... assuming the Z runs a similar size tire and weighs a similar weight.
NO!
but yeah, for an 16 or 17, i'd say mid 30s. But it's a matter of personal taste. Some people that corner harder like 40psi to reduce sidewall flex... but unless you corner rough alot, that's not necessary.
paying citations??? why would high tire pressure cause you to get a citation? or you mean getting pulled for driving aggressively just to 'get the most' out of your brick-hard tires? I actually had mine set at 40.... i guess i'll drop it to like 36 now.
Opposite opinion:
Some ppl just who want to get a fast pleasant ride from A -to- B ... thus use stock rims std rubber.
When the speedbumps come, yall ppl stop/block the traffic with all u skirts and rims... Watch out: I use kickdown instead and watch this "bow down worship act" from my mirrors...
= with stock shocks with stock wheels u can conveniently sail 50mph through speedbumps. With a 3gen that is [I am sorry am I, not all maximas can do that].
I've always liked the 300z wheels, they are light as sheit compared to most other aftermarket wheels for our cars, and cheap as hell now! good luck having them installed.
