Passenger side front window won't move
Old Nov 7, 2001 | 08:21 AM
tmc's Avatar
tmc
I have a 91 GXE. The front passenger side window is dead. I don't know if it is the regulator or the motor or both. I had to manually pull the window up and there is still a small gap at the top. Is there anyway that I can figure out before taking off the door panel what I need? Also, if it is the regulator, is that difficult to install myself or should I have it serviced?
Thanks for your efforts,
TMC
Old Nov 7, 2001 | 08:23 AM
HoJo's Avatar
Re: Passenger side front window won't move
Can you hear the motor running when you press the button? If so then it is deffinatly the regulator. If not then you can't really tell until you take apart teh door. Sometimes the wire can bind up so tight that the motor can't spin the drum so you won't hear the motor running.
Old Nov 7, 2001 | 08:31 AM
HoJo's Avatar
Also...
This is something almost anybody can do. Taking apart teh door is pretty simple and taking the regulator out just involves like six bolts and a couple of screws.
Old Nov 7, 2001 | 08:32 AM
tmc's Avatar
tmc
Re: Re: Passenger side front window won't move
I can't hear the motor. When I take off the door panel what do I check next?
Old Nov 7, 2001 | 09:00 AM
HoJo's Avatar
You'll see the regulator with the motor attached to the bottom of it. There is a wire that controls the window going up and down. The design flaw is on the piece holding the end of this wire. It breaks and teh wire gets tangled up around the little drum attached to the motor. You have to take out the regulator and motor as a unit. There are two bolts on the top and bottom of the regulator holding it to the door. There are two bolts holding the glass to the regulator. Once you get it out there are two or three screws holding the motor to the regulator, be careful with the screws as they can be really tight and can strip.
Old Nov 7, 2001 | 09:36 AM
«§»Craig B«§»'s Avatar
check my page (link in my sig) for instructions on replacing the regulator
it's in the how-to section of my site
good luck
03VQMAX
Dec 7, 2015 04:59 PM
lux97Max
Sep 14, 2015 03:54 PM
doctorpullit
Aug 20, 2015 05:15 PM
KGMtech
Aug 18, 2015 09:21 AM
BassAddictJ
Aug 4, 2015 11:38 AM
