Passenger side front window won't move
Old Nov 7, 2001 | 10:12 AM
tmc's Avatar
tmc
I have a 91 GXE. The front passenger side window is dead. I don't know if it is the regulator or the motor or both. I had to manually pull the window up and there is still a small gap at the top. Is there anyway that I can figure out before taking off the door panel what I need? Also, if it is the regulator, is that difficult to install myself or should I have it serviced?
Thanks for your efforts,
TMC
Old Nov 7, 2001 | 11:47 AM
Shep's Avatar
Re: Passenger side front window won't move
TMC
When you try to move the window up or down, do you hear the motor trying to run, but the window won't move? If so, then it's the regulator. I've changed a couple, it's not too hard, just takes a little bit of time the first time you do it.
Old Nov 8, 2001 | 07:30 AM
93bluemaxSE
Have recently replaced both rear window regulators. When they went, I could not hear the motor very well, but knew that something was preventing the motor from moving the windows up and down. Only way to find out for sure is to remove the door panel. On my rear windows, I removed the window regulators and held the windows up by using a length of wood and a couple of screws until I got the parts.
I would not pay someone to replace the regulator. It is fairly simple to do. The window regulators for your car are available at www.nissanparts.cc for about $50.00 each. If you search around a bit, you'll find that price is very reasonable.
Good luck with it. Give yourself a couple of hours if this is the first time you have disassembled the door.
TMC
03VQMAX
Dec 7, 2015 04:59 PM
lux97Max
Sep 14, 2015 03:54 PM
doctorpullit
Aug 20, 2015 05:15 PM
KGMtech
Aug 18, 2015 09:21 AM
BassAddictJ
Aug 4, 2015 11:38 AM
