Check Engine Light
Old Aug 20, 2008 | 12:11 PM
Jon94SE's Avatar
Check Engine Light
Well I just recently replaced three of the rear injectors along with one of the front injectors and everything has been going better except the car would start bucking from time to time at low rpm under light load which I thought might have some thing to do with the throttle position sensor but last night I started the car and it had a dead cylinder and as soon as I started moving I got a CEL. I was only a few miles from home so I decided to drive back and check it out when I got home. About half way home the miss went away and the light shut off. I checked the codes this morning and got a 51 which according to google is a "Injector Analysis" code. What could I have done wrong during the install? Or is it possible the injectors are no good? Thanks.
Old Aug 20, 2008 | 02:15 PM
Greeny's Avatar
¯\(°_o)/¯
"Injector Analysis" code????
Code 51= Fuel injector circuit open = a bad injector.
Old Aug 20, 2008 | 02:29 PM
internetautomar's Avatar
mod or sell?
maybe another injector died.
it does happen.
I replaced 7 injectors on VE#1, but only on 5 cylinders
CorollaULEV
30
Aug 9, 2021 08:11 PM
Justinmc760
Aug 23, 2015 03:10 AM
maxinout93
Aug 20, 2015 02:17 AM
beboski
Aug 16, 2015 05:23 PM
Flores94
Aug 11, 2015 12:53 PM
