Transmission not engaging...
Old Aug 27, 2008 | 10:11 PM
mrkanda's Avatar
Taking my Maxima to the Max!
I just finished putting my car back together after working on it this past month. I took off the trans to install a new rear main seal and oil pan gasket. After hooking everything back up and lowering the car, I went to take it for a test drive. It revs fine but when I put it in gear is simply revs and moves only slightly. I have to rev it very high to get it to move much at all. I wonder if it is because it needs more ATF. I put in about 3 or 4 qts. I know it needs more. I will try that in the morning.
It was fine before I took it off. Does anyone have an idea what it might be?
Thanks,
Mrkanda
Old Aug 27, 2008 | 11:32 PM
burhan92SE's Avatar
its not getting signals from TPS? (throttle position sensor)
Old Aug 28, 2008 | 12:27 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
almighty dreaded accidentally-swapped harness syndrome?
Old Aug 28, 2008 | 01:44 AM
mrkanda's Avatar
Hmmmm.... There is one wire connected to a sensor that is by the oil filter housing to the driver's side that broke. I didn't know if it would affect the driveability or just give me an error. I guess now I know. BTW, it is single yellow wire. Right now it is just hanging there. Which sensor is that? I thought the TPS was on the top of the engine.
Old Aug 28, 2008 | 01:47 AM
CMax03's Avatar
Make sure you didn't plug you trans harness into the wrong plug there are some the fit each other perfectly (wrong)
Old Aug 28, 2008 | 03:17 AM
burhan92SE's Avatar
Thanks,
Mrkanda
VE = 9.6 L ATF
VG = 7.4 L ATF
how much did u put and did u check if deres enough ATF?
EDIT: hmm yellow wire i donoo sorry but ya TPS is on the top of the engine....sorry i jus had 7 bears...
Old Aug 28, 2008 | 07:54 AM
mrkanda's Avatar
Well, I don't know if the harness is hooked up wrong. I'm pretty sure I connected the tranny harness in the right places considering that the wires are laid out in a normal fashion.
When I get off work I will try to find out where that yellow wire broke off from and splice it back together. I contacted the dealer parts department and they said it is a speed sensor. I'm not sure what it does, but mine may not even be bad. It's probably just the wire. Plus, a new sensor costs about $158 from the dealer (ouch!) and only has a pigtail to splice to existing wiring. If I can't find it I may go to the junk yard and look at the cars there for the right connection.
On a related note, I had to replace my PS Pump and the one I had ended up being from an SE model. Therefore, it did not have the same configuration as the original GXE pump. I did get it hooked up and it seems to be working (besides from some pulley noise) but that round cylinder which is about 3in. long and fits around a post on the GXE pump is just disconnected and hanging in the engine bay. Is that a sensor that adjusts the PS ratio according to the speed you are driving? Will it affect the driveability of the car? I just need to be able to drive it. If I need to I can rebuild my old one and put it back on, put I kind of would like to have the tighter steering of the SE pump.
Thanks,
Mrkanda
Old Aug 28, 2008 | 08:04 PM
mrkanda's Avatar
She Runs!!!
I thought it was the sensor wire, so I took the stock wire, reinforced it with thicker new wire and soldered the connectors at both ends. I then wrapped the whole thing in electrical tape and reconnected between the sensor and harness. Even then the tranny would still not engage.
I ended up seeing my mechanic Friend on the way to the parts store and he mentioned that it may be air trapped in the torque converter and that I might just need more ATF. Well, that's what it was! I added another 3 quarts or so on top of the ~4 I had put in there previously. The car moves!!!
Now, I hear some brake sound. I think the calipers are dragging. I know I should have cleaned up those slider pins while I had it apart. Oh well, something more to do tomorrow.
Thanks Guys!
PS. It was actually just the dust shields that were bent and dragging on the rotor. My buddy noticed it and pushed them back w/ a screw driver. Still, my brakes are not really stopping the car as well as I remember and certainly not as good as my wife's '03 Protege5. I think I'll have to bleed the brakes soon (they haven't been completely bled in about 7 yrs.) and/or go with a BBK.
Old Aug 28, 2008 | 09:13 PM
RustEvador93Maxima's Avatar
hi* i couldnt make my own thread..so ill start here.
I own a 1993 Nissan Maxima GXE auto v6 and for some odd reason it makes a ticking sound when i rev the engine. I can stand still or drive and rev and it makes this weird tick tick tick..I thought maybe I was low on motor fluid so i put some 10w30 in but my oil was just changed by Firestone 1800 miles ago.
So the car has 135,000 miles and its all stock..Everything works in the car including the bose. Theres no rust on the car and the original exhaust is still on the car. I just recently had a new flex pipe installed for a couple hundred at Firestone. I also had a transmission flush around 1800 miles also at Firestone. hmm what else....I really hope someone can help me out here..I used to be a gear head with ls1's and lt1's on the small block 350s but i know nothing about nissan VG300e's
Thank you everyone for reading this.
Mark
Old Aug 28, 2008 | 09:18 PM
BenStoked's Avatar
Jesus was a Zombie.
Mark
ooh!!! I want a vg300e!!
anyway, ticking on a vg could be a few things, typically, broken exhaust manifold studs or valves ticking (<not as common, but still)
you didn't over fill the oil, did you?
(sorry, had to point out the typo)
Old Aug 28, 2008 | 09:28 PM
I'am 100% sure its not over filled b.c i only added 1 qt of oil.
The other thing that is bothering me is that not even a week ago Firestone replaced my Flex pipe from the header down and maybe they did something to the exhaust manifold? but with the valves ticking maybe its b.c i should put some Lucas oil in..new oil filter with new oil.
thanks for the quick reply.
Mark
user 11122324
42
Jul 18, 2022 03:35 PM
Pied
Sep 26, 2015 03:29 PM
