instrument panel removal
my speedometer died, but sometimes it will work, so I know that the cruise control works, so i dont think that it would be the VSS. so i would like to know how to remove the instrument panel, and what wires are connected to the speedometer so that i can test them.
.ps i already searched through the post and i had no luck finding this information.
the last thing I want at night is a bright *** clock blinding me, cutting my vision.
actually, there is a way to disable the key-in-ignition warning chime. a true annoyance when working on the car with the door open. see craig brace's page on it.(warning chime mod)
also the always-on cruise is a good one, too. (same page)
wat? WHY???
for the speedo from what I found out when I had my 89, is that the board in the cluster can be cracked causing the speedo not to work all the time. It's easily cracked pulling the cluster out due to getting it out from behind the steering wheel. If your cruise still works that could be your issue due to the signal from the speed sensor goes to that then to the cluster. other then that fallow the wires and look for a lose harness.
mine wouldn't work when it was cold but tend to work when it was warm.
but i'm getting one from goon for him.i would smack it and it would come back up but sometimes drop a half-second later and i got fed up trying to smack the darn cluster while driving (i broke the little rest-peg for the temp needle too so i was like w/e)
i had to chuck the speedo and the temp sensor from the cluster, actually. I stole the one outta my friend's [future] car
http://forums.maxima.org/3rd-generation-maxima-1989-1994/402812-digital-dash-conversion.html
http://pearlmax.t35.com/dd/dd/digidash.htm
Running a search for "digital dash conversion" yields many results.
Man, don't link to that biter's page.. He's a thief and a opportunist. Had my video embedded in there originally and when I asked him to credit me for it, he just deleted it without so much as a response. Not to mention it's basically a clone of my page (http://pearlmax.t35.com/dd/dd/digidash.htm) only more detailed, explaining how to remove everything because he had nothing of any real significance to add.
I was unaware. Fixed.
Heh, I was just complaining, but that works..
Dude, see that metal box on the back of the cluster? Cut either one of the wires, or just remove it completely.
Craig evidently stopped supporting it more than a year and a half ago. He had some great write-ups.
I have a link for clock repair and that's all I have.
http://classic-web.archive.org/web/2...ock/clock.html
I have a link to anoter person's website who also has some how-to's. Maybe one of his will help.
http://www.cardomain.com/memberpage/748507/1
Again, thanks for the links. That was really helpful. BTW, I did take some photos, not sure how to post them though.
my03maxima
Jul 28, 2024 07:40 AM
RealityCheck
Oct 2, 2015 06:34 PM
