The 12 sec VE Auto dies
As I'm decelerating up to a stop light, the engine stalls cleanly. I try to fire it back up and the motor won't turn over, very similar to a low battery. But I check my multimeter, which is always connected, and there is plenty of voltage.
After pushing the car off the road, I try to crank it up again. Now it spins freely. Too freely. Doesn't sound like there is compression. I pull a plug to check spark and nothing. No spark.
After towing the car home, I diagnose the ignition circuit. Everything checks out fine. As I'm scratching my head, I look at the timing chain cover to see metal fragments.
Here's what I see when I get underneath the car:
The first thing I think is that the VTC sprocket cap busted off and grenaded the motor.
Sure enough, here's what I see when I remove the valve cover:
Well, the VE is dead at 203K miles. I really thought the original tranny was going to die before the engine. Or that the engine would pop when spraying the 200 shot at the track.
What now? I can swap in the spare VE engine that I have in my parts car. Or I can do a VQ35 swap. I'm not ready to leave the Maxima family to buy a G35 or BMW. Suggestions?
That's sad to hear.
Did you spray a 200 shot already or was that just something you were planning?
If I were you, I would do a vq35 swap and then design and produce a swap kit for NWP to sell...
DOH!!
Sorry to hear man... mine went without warning too.. but at least I was turning 7000rpm at the race track when mine went.
Most likely the block is fine. If you're lucky, the heads are okay and you can just install new timing components and possibly valves. do a ring& valve job and put it back together.
perfect time to get a set of cams ground for it too.
Thanks everybody for the support. You can tell I'm not the happiest person in the world right now.
No, the biggest shot I've gone with the nitrous is a 75 shot.
I had a little bug that started in March of this year. The car would lose 100% of power intermittently without stalling. Power would always come back if I let off the throttle for a second and got back into it. I never did completely solve that issue.
I know there is a meet in South Florida happening soon. In fact, that is where I am now with my broken car. But, I won't be here for that meet. I have to get back to NC for the huge East Coast Meet that I'm organizing in Maryland on Sept 27th.
Yeah, I can spend more money on this VE. But, I think I have some bad wiring in this car which is causing the little gremlin I've told you about this past Spring. I think it may be best that I rip all of it out and start over again. If I'm going to go through all that work, I might as well put a different engine in there. If I decide to go this route, I will probably start a big progress thread in the All Motor section to share every little obstacle I come across.
But, I would have rather had my engine die on me at the track, not as I'm babying the car.
Turbo isn't really on my mind right now. If I do happen to successfully get a 3.5 in there, I would do nitrous in the short run and who knows after that. But if I just put the VE engine in there that's in my parts car (225K miles), then I feel I would be giving up on this project car. I could go the VE route still and build it up the right way. But, it's still up in the air right now. It depends on what you guys think.
DOH!!
It happens to all [most] of us, you have to remember it can always be WAY worse, and look at it as an oppurtunity. Now, if you're looking for shoulders to cry on, won't find one here, join the [blown motor] club, membership dues are $400/yr.
On a serious note, my condolences, I'm all for seeing you put another VE in there, I've always had a sweet spot in my heart for that motor, and being able to say you have a 12 second VE is SOOOOO bad ***.
OK, that's my turd gen post for the quarter
Taking my Maxima to the Max!
Hmmm.... Well, with that in mind, It would be really crazy to do a built 3.5 VQ swap. I don't know much about VEs and what is possible with them since I am a VG guy, but I know it would be awesome to see a VQ35 finally swapped into the 3rd gen and done up right with a proper N/A or turbo build and a full write up. I think that would probably be one of the best bangs for your buck in terms of power and also notoriety. Besides, there are plenty of VQs around to choose from and also plenty of power options for them. Just something to think about.
Do it right.
come buy the Z32 tranny I just picked up for my S14 and bolt that to the VE. turn the engine the proper direction and use an S14 or Z32 parts car to steal the front and rear subframes.
tho if I were him i wouldn't do that to his current white 92... I'd get another one for that because, well, if something goes amiss, then byebye Aaron's 92SE.
Sorry to hear about the motor Aaron.
I remember you had a thread about your VTC rebuild starting to tick again very soon. Was this one making noise, or was it completely unexpected?
on not doing it to the white 92....
naw i'd do it to another VE. At least that way, he has the harness in place, and a VE ECU. Swapping a VE into a GXE = notfun. Tho I suppose as much work as an RWD swap would be, a VG to VE swap would pale in comparison. So at the VERY least, he'd want a 92-94 GXE so he would still have functional signals and stuff, and not have to hack it up like Mike90SE did.
i don't see it that way at all. I see that as a good temporary solution. There's no rule saying you have to keep the parts car's motor in there for any longer than you need it. It'll give you an opportunity to carefully weigh every option so you don't rush into a decision, and give you time to be detail-oriented [as we know that you like to be] when planning, part-sourcing, and assembling your next drivetrain setup. Granted you probably don't want to beat the s**t out of that motor in the meantime because 225k is approaching the point where I'd start being easy on a motor.... but even so, at least you'll be able to take your Maxima to all of the NWP-sponsored meets and stuff that you want/need to attend, instead of parking it and trying to whip something up in 2 weeks (or *shudder* taking a stock Stanza to a NWP meet ).
But why wouldn't I want to do something like this to my 92 SE? It's already gutted and ready to be hacked into. The only thing I see happening to the car that would make me get rid of it is if it got totaled out somehow and couldn't be repaired.
My main take on this is, if I swap the spare VE to buy me some time, then I will lose the motivation to get the car back up and running. I'd rather do this thing right the first time.
But before the engine died, it gave me no warning. I heard no unusual ticking or grinding going on. One thing I did hear on the last 100 miles of my NC to FL drive was that at WOT, the engine sounded just like the cone filter fell off. The intake had that distinct roar to it. I checked everything and there was no type of intake leak. So, I decided that until I found the problem, I would not go WOT again. Shortly after that, it stalled once and for all.
ah, that makes sense. Same fear i have with my VE tranny is that since i'm installing it now i'll be less likely to get a 2nd gen tranny and swap the parts around to give me 2nd gen gear spacing (more spread out) on a VE differential. But I guess I can find another VE tranny to work with.
with the VQ35 swap are you researching FF or had you additionally researched stuff about a FR (z, or equivalent) setup?
If I did it, it would strictly be a 3.5 from a FWD Nissan. I have lots more details about the swap, but nothing is set in stone just yet. I still have a few different ways I can go about this swap. I'm just trying to figure out which is easiest.
I'm not entirely sure what you mean. But, the Maxima will not be converted to RWD. Matt was just one-upping my extremeness and suggested a RWD type swap.
yooooo
sorry to hear bout gd VTC , im glad we got 2 VQ35 at my house. well untill we get the ve's gone. and the vg. lol
but the car was bad ***, espically when u hit the nosssssss!!! hahahaha
im selling that 92 red se auto. and all my 3rd gen stuff is going with it. which is a lot.
im betting u do vq swap!! fine a rear ended 02+ and swap it all
Aaron, sorry about your motor lunching out... everyone hates losing an engine, although after a while you can get used to it!
Since I've blown three VQs, the Blown Motor club has waived my dues for life.
Honestly, think over the VQ35 conversion - once you go 3.5, you'll never go back. such a torque beast, and spray? oh, they likes their spray.
I am actually sourcing out parts for the VQ35 right now. I may even be able to find a full running parts car for around $2000. I'd much rather go that route instead of buying little parts along the way. It'll be nice to have all the parts you need in one package since there is no telling what weird obstacles I'll run into. If I had a 4th gen, I'd just buy the parts separately and save a little cash. But it's tough finding a write up for the 3rd gen.
I just wish I could have blown it with style! Not a VTC cap breaking lose.
If you could find an insurance rear-end or roll-over total, you'd be set for parts. Seriously, the 3.5 has bunches more torque than a 3.0, and would make a great platform for future builds.
Would this be a 3 + 5 or 3 + 6 hybrid combination ??? 3.5 , 3.6 ? nope ?? - well, you get the idea - but you would have the first of this breed, right ???
Maintain.
Really sorry to hear about the car. Not the most exciting way to take out the world's fastest NA VE.
I have been highly considering a 3.5L swap for a 4th gen if I sell my car. As much as I love my VE, there is no replacement for displacement. haha
For you, I think perfecting a 3rd gen 3.5 swap would be a nice way to continue on the path of extreme 3rd gen building.
good luck
Did your VTC cap actually break? For some reason I thought the actual cap would come off causing that kind of damage.
good luck
good luck
if such a product ever DID come into existence, and Aaron ever needed a test car for wiring up the VG-to-VQ pre-time-control-unit harness hybrid, I'd be down for that
and Aaron....... what tranny were you planning to use, if you do the 3.5?
I've never been a fan of the threads detailing progress while it's going down, especially long-term things, I much prefer it when it's just kept track of while doing it and than in the end making the thread, it comes out much cleaner showing the project all at once. Just make sure to not lose pic's/notes like I did for one I'm working on right now.
It suxs when they go with a whimper, and not with a bang...
Maintain.
Maintain.
I'm not completely sure what you mean by hybrid combination. But it will be a full ECU swap.
good luck
good luck
not to mention how many people would be chomping at the bit for a conversion kit from NWP!! that would be a monstrously large PDF installation guide haha.
I haven't made up my mind which way I want to go with the tranny yet. I am really hoping to link up my stock RE4F04V tranny to the VQ35. The bolt pattern for the casing is slightly different. But the internals are almost identical to the RE4F04B tranny that's used in the 02-03 Maxima. I could possibly have my stock internals swapped over to the new casing and bolt it up. That way, I will be able to use my VE axles, much like the Spec V guys do with the 6 speeds.
Or I can do a full tranny swap along with electronics and make hybrid axles (half 3.5/half VE). And my stock gear shifter looks like it will link up just fine. But, swapping over the TCM and wiring is just one more thing I don't want to worry about.
