fall tune up !!
Old Sep 24, 2008 | 02:22 PM
sams's Avatar
fall tune up !!
Hey guys. i need some help on repairs. I have a 1994 maxima with the 160 hp engine. what should i do for average maintenance? should i buy some nice motor oil>.....if so what kind is best? (I only fill up with regular gas not premium)If that matters.. only problem i have whatsoever is... My brakes make a skreeching sound when i stop on cold days. good or bad
You guys have helped out me and my max so much this year keep it up thanks!!
Sam
Old Sep 24, 2008 | 02:31 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
Sam
plugs
wires
disty cap
rotor
seafoam
check vac lines
i use mobil1 full synthetic and purolator pureone gold filter
fuel filter
air filter
pcv valve
clean TB
clean MAF
get a wirebrush and clean the electrical contacts on all the harness plugs and put some dielectric grease in there to prevent corrosion (ESPECIALLY battery posts/terminals)
then go give her a good flogging and blow her nose out
Old Sep 24, 2008 | 02:47 PM
Pearl93VE's Avatar
I can has?
plugs
wires
disty cap
rotor
seafoam
check vac lines
fuel filter
air filter
pcv valve
clean TB
clean MAF
+1 to all of that, as far as the brakes go; it might be the wear indicator screeching telling you your pads are low. Or it could be a build up of brake dust and they just need cleaned with some brake parts cleaner. Take the wheel off and look.
Old Sep 24, 2008 | 03:58 PM
jonmandude's Avatar
Never been a big fan of seafoam in the engine. It is hard on seals.
Old Sep 24, 2008 | 06:05 PM
PBfrEAk's Avatar
Has anyone else had problems with seafoam??
I've been contemplating it off and on....
//thread jack
hey jonmandude...
where exactly in the snow/rust belt are you located???
Old Sep 24, 2008 | 06:58 PM
Pearl93VE's Avatar
I can has?
//thread jack
hey jonmandude...
Used it in many vehicles, never had a problem with it. Don't know about long term seal damage but my VE doesn't leak anywhere.
Old Sep 24, 2008 | 07:50 PM
burhan92SE's Avatar
plugs
wires
disty cap
rotor
seafoam
check vac lines
fuel filter
air filter
pcv valve
clean TB
clean MAF
Old Sep 26, 2008 | 10:30 AM
braxsusriely's Avatar
seafoam
Used in the gas tank but never in crankcase as i've heard horror storries. Doesn't leak at all. I drive a VE
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
mclasser
22
Nov 12, 2020 01:58 PM
uttadms31
Sep 30, 2015 05:24 AM
Socalstillen
Sep 26, 2015 12:01 PM
