Smell gas fumes when starting my car please help
Hi everyone
I have a 90 maxima
My car was doing fine until i fill it up with gas and got about a mile and it start putting. (like a dummy) I cut the car off and now it will not start i get a strong smell of gas when im trying to start it but nothing. Just to get it home i was messing with it and took the fuel pump fuse out and it started like it was goin to start so i put the fuse back in and it start and i took it home, but that trick only work once it will turn over but its not catching any one have any ideas on what i should try.
Thank you
I have a 90 maxima
Thank you
how's that fuel filter?
Atl got a gas shortage right?
if you're pumping gas that's at the bottom of the tank you might've picked up some extra dirt in your filter.
if your filter is on it's way out you might have plugged it up w/ the dirty gas. when you removed the fuse it decreased the pressure and it dribbled gas into the motor so it started up for a second...then you put the pump back on it forces more dirty fuel and blocked it up even more.
keep in mind that's all just a theory since i'm not looking at your car.
check ur fuel pressure with fuel pressure gauge if u have available one before changing anything....its around 35 psi at idle engine running and 43 psi wen u turn off the car and jus turn on the ignition not engine...if it has wrong pressure then change the filter and chek again... and report bak
edit: so ur main concern is that ur car shuts off?
if you smell strong gas smell then your fuel lines are going bad...so change them.
this usually occurs when it's cold. do a search...we beat this to death every year.
I have a new fuel filter on there but ill check it. its still warm here in Atlanta. I might be wrong but could it be my coil pack going bad and not burning the gas?
oh and the smell seem to be coming out my tail pipe with some gray smoke...
ha so i'm totally off. yeah check your coil pack.
http://forums.maxima.org/3rd-generat...something.html
Shouldn't he start from checking for spark first? He was quite specific where the smell is coming from, it is not fuel lines. I'm not familiar with VG though and have no idea how to troubleshoot ignition there but it sounds all his cylinders are not firing so it must be in the common for all of them part. Any simple procedure how to check those items in your list?
i was hoping auto zone had away to check it but i just call and they said no. anyone have a way to check the ign coil.
if i buy it and put it on and it dont work i dont think they will let me return it
check your ECU trouble codes (general maintenance sticky, post 18 or 19.. i forget which) and if you get any codes, that'll give you a starting point to see what might be wrong
Then if it is not there you could proceed to check the relevant fuse, 12V presence on the coil, etc.
OK ill try that just to be sure i got it i take one spark plug out and put it in the ignition wire and just lay it near a ground on the car or do i hold it and touch the ground (will that shock me?)
Could you at least confirm that you have no spark on your current one? The old- fashion way: take one spark plug out connect it to ignition wire, put it somwhere on the engine ground and watch for spark when someon is trying to start the car.
and he doesn't have to remove the plug.
anyhow you see 3 wires on the backside of the distributor cap and 4 on the front. notice the 3rd from the left goes down to the little black box between the radiator hose and the breather hose. that's the ignition coil on a VG. so if he takes that wire out of the distributor cap and holds it just barely away from the intake manifold (basically, at the same distance off the metal as a sparkplug gap) he should get sparking. if no spark is happening then either the coil is dead, or the coil is not being told to fire.
ok well im getting a spark.
but i lock me keys in my car and i was pushing the window down and broke the window, 1 thing after another.
( i guess that mean my ign coil is good?)
Caped, does distributor have more specific tests besides checking for spark after it? I understand it has a moving contact 'distributing' spark between cylinders. Has it ever happened that the contact turned around its axle and lost proper timing as a result?
Not only that - everything down to ECU as well. So you're left with distributor, wires, spark plugs or fuel problem but I'd look at the latter the last as it seems it got to exhaust somehow, so it must had been in the cylinders first. You can buy 1 spark plug and test spark on each cylinder without removing one - whatever works for you.
testing an extra plug, one wire at a time, is a good idea tho. a timing light is also a good idea.
this is what happens when your timing is 1 turn of the crank off (cyl 1 and 4 are at TDC at the same time, as are 2&5 and 3&6:
and this is what happens when your timing is like 20 degrees retarded (around 5 ATDC):
Well gas was the last thing i put in the car before it start acting crazy. and i dont know why the timing would be off i haven't touch that stuff in about a year or 2.
If i was to bet i would think its the gas, maybe the gas station had bad gas or something
is there anyway to save the gas in the car or do i have to remove all the gas and put new gas in it
gas to high
gas to high
gas to high
gas to high
)remember that gas eats certain materials tho so you'll have to put it in a fuel-safe container if you do try to do that
as for timing... is the distributor nice and tight? or can you turn it at all? does the tachometer work when you crank the engine?
yes its tight and yes the tach does work
im goin to take the hose loss from the fuel filter and let the gas come out that way is that a good idea?
im goin to have it goin to a container
