Lowering kit with springs/shocks, best price?
Old Oct 4, 2008 | 06:02 PM
G3Karl's Avatar
Anyone have any tips as to who has the best price for a lowering kit for my '92 GXE? Looking to get the springs, shocks and struts in a combo kit for a great deal. Any info is appreciated.
Thanks!
Old Oct 4, 2008 | 06:16 PM
Greeny's Avatar
¯\(°_o)/¯
http://www.shox.com/
Old Oct 4, 2008 | 09:34 PM
burhan92SE's Avatar
i know tokico sturts r the best......but how about springs? which springs r the best?
Old Oct 4, 2008 | 10:14 PM
Pearl93VE's Avatar
I can has?
Koni are the best shocks. Tokico comes in second from our selection. As far as the springs go, "best" varies for what you want. I've heard and read eibach's have the best ride/performance, but they are only a moderate drop (1.2"), Where as B&G, Intrax, and Sprint are all lower, meaning lower center of gravity, but much harsher ride.
Old Oct 4, 2008 | 11:14 PM
aminus21's Avatar
Just like Pearl said, Konis are the best, followed by Tokicos. I've got KYB's on, and the ride is decent.
Old Oct 5, 2008 | 12:47 AM
burhan92SE's Avatar
thanks that helped...
Old Oct 5, 2008 | 07:39 AM
G3Karl's Avatar
Originally Posted by Greeny
is your car lowered? If so, how much did you lower your car by?
Thanks.
Old Oct 5, 2008 | 03:31 PM
Greeny's Avatar
¯\(°_o)/¯
Thanks.
Yes it's lowered, B&G springs 1.6 inch drop.
Old Oct 5, 2008 | 04:41 PM
traxtar944's Avatar
Would be lost w/out the org
I like mine....B&G rock.
New Sig! yay!
Old Oct 5, 2008 | 07:16 PM
G3Karl's Avatar
did you purchase the shock mounts and boots when you purchased new shocks/struts? Or are the one's on the car usually reuseable?
BTW, nice ride!
Old Oct 5, 2008 | 07:17 PM
G3Karl's Avatar
oh, and do you have any rubbing issues with the large wheels and lowered car?
Old Oct 5, 2008 | 08:02 PM
Greeny's Avatar
¯\(°_o)/¯
BTW, nice ride!
The strut mounts are typically reusable, but the strut dust boots are usually trashed unless some previous owner replace them within the last 5 years or so..
Old Oct 5, 2008 | 08:03 PM
Greeny's Avatar
¯\(°_o)/¯
Who? me or traxtar?
Old Oct 6, 2008 | 01:25 AM
Pearl93VE's Avatar
I can has?
New Sig! yay!
Car looks absolutely sick. I expect an extensive thread with lots of pics Beautiful Pearl Paint job too. Makes me want to strip mine down when I get some money and get the body perfect and shave the antenna. Awesome job..
Back on topic:
I think the size of the wheel and offset/ tire size are the main attributes to rubbing. Generally dropping the car on Eibach's or B&G's you won't have a problem with most normal size wheels (16"-18"), anything lower like an Intrax or Sprint (1.8";2.0") You may have to roll fenders. But I'm sure someone who has actually ran with them will chime in sometime.
If not, do a search, there are a bunch of helpful suspension threads.
Old Oct 6, 2008 | 06:09 PM
G3Karl's Avatar
Who? me or traxtar?
both
Old Oct 6, 2008 | 06:12 PM
Greeny's Avatar
¯\(°_o)/¯
both
My wheels are not large, only 16 inch/w 205/50's on them.
They do not rub at all thanks to a 45mm offset, i wish they were about 40mm, as they don't stick out far enough for my taste. but they were free so meh.
Old Oct 6, 2008 | 06:35 PM
internetautomar's Avatar
mod or sell?
dam you got some tiny tires on there.
Old Oct 6, 2008 | 06:37 PM
Pearl93VE's Avatar
I can has?
inexpensive though...
I run 16"x7.5 BBS RX's
+38mm Offset
225/50/16 Tires
No rubbing... on an eibach drop
Old Oct 6, 2008 | 07:05 PM
mod or sell?
+38mm Offset
225/50/16 Tires
205/50 is small even for ricer tires.
Old Oct 6, 2008 | 07:19 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
17x7 +22mm offset 225/50/17 (25.9" outside diameter, compared to 25.5" stock outside diameter) rub on STOCK springs in the back when cornering, over speed bumps, and if you dump the clutch in 1st at a stoplight................ if you want something to stick out that far AND drop the car, you'll need to get the fenders rolled in... unless you want a nice little gouge in your sidewall. Don't ask me how I know this.
Old Oct 6, 2008 | 07:28 PM
but that lower center of gravity comes at a cost to performance as well. there is such thing as too low.... a big drop (i'd say 1.8" and higher) is going to start to make major changes in your suspension geometry due to the angle of the control arms (they should basically always slant down or sit flat.. never up), plus you got rid of almost 2 inches of already-limited suspension travel.the control arm angle is something I'm working on developing a fix for when I drop my car. I'm going to use eibachs.
Old Oct 7, 2008 | 01:06 AM
jonmandude's Avatar
Traxtar, man that came out nice!!! You have got to be happy.
As for rubbing, I have Sprints with 235's and no rub.
Old Oct 7, 2008 | 05:11 AM
Greeny's Avatar
¯\(°_o)/¯
45mm offset limits my range of tire sizes.
Old Oct 7, 2008 | 07:39 AM
mod or sell?
eh, I wouldn't have used them personally then. I need a relatively accurate speedo myself.
Old Oct 7, 2008 | 07:56 AM
and i guess you don't feel like hassling w/ longer studs and spacers?
Old Oct 7, 2008 | 08:31 AM
Greeny's Avatar
¯\(°_o)/¯
meh, my speedo is only 2-3 mph fast, not enough for me to not accept free wheels.
Old Oct 7, 2008 | 08:32 AM
Greeny's Avatar
¯\(°_o)/¯
correct.
Old Oct 7, 2008 | 08:48 AM
well you also accelerate quicker on those smaller tires... but get worse MPG.... I run bigger-than-stock tires with the VE tranny but i'm gonna get a longer 5th gear to put in my tranny so i'll have longer-than-stock-VG top gear. I just hope to hell that I can still drop my car on these tires without having to run majorly negative camber (so the tops won't rub)
Old Oct 7, 2008 | 01:28 PM
mod or sell?
nope, more than that. 7.1% too fast
60=55.7 actual.
Old Oct 7, 2008 | 03:58 PM
Greeny's Avatar
¯\(°_o)/¯
60=55.7 actual.
Not according to the police radar things on the sides of the road around here. They are always 2-3 mph off from my speedo, and that is all that matters to me.
Old Oct 7, 2008 | 04:57 PM
Hectic's Avatar
New Sig! yay!
Looks sick man, I didn't know you had the pearlness.
Old Oct 7, 2008 | 05:37 PM
ColombianMax's Avatar
Is it me or is everyone confusing Super White for Pearl? Unless the monitor at school has a different color to it, that looks like what he already had; Super White.
Matt, when do you plan on coming back to Chicago? I plan on redoing my max as well and would like to "inspect" yours perhaps you can recommend me a bodyshop
Old Oct 7, 2008 | 06:11 PM
mod or sell?
your speedo is broke too
Old Oct 7, 2008 | 06:20 PM
Greeny's Avatar
¯\(°_o)/¯
wouldn't surprise me..
Old Oct 7, 2008 | 06:26 PM
mod or sell?
I used to have a spare
Old Oct 7, 2008 | 06:30 PM
Greeny's Avatar
¯\(°_o)/¯
me too
i'm about out of extra parts..
Old Oct 7, 2008 | 06:32 PM
mod or sell?
me too
I've still got a bunch of odds and ends buried in the garage.
Old Oct 7, 2008 | 08:05 PM
Pearl93VE's Avatar
I can has?
I could never confuse Super White with Pearl. It may not be a CHO pearl, but it is definitely pearl.
Old Oct 7, 2008 | 10:30 PM
Eh I guess it it pearl, I'm at my home PC now and can see it. It also says it on his sig...
Old Oct 8, 2008 | 05:09 AM
tripleGmax's Avatar
CHO FTW!
and to the OP:
my car sat on Intrax with Tokicos. The ride was a little rough, but i really liked it. http://www.gregg-henry.com/gallery/ there are some pics for you to see my drop.
