OMG Power Steering Going Again
Old Oct 7, 2008 | 05:51 PM
coolsun's Avatar
Yup only been 2 years when i had my power steering pump replaced. They filled it up with regular power steering fluid Not Dex II-. Then came this week
all the fluid leaked out and made a mess in my garage.
I am a complete noob in changing belts and lower mechanical Parts, even though i got to do my knock sensor over the summer.
Can some one give me an idea what tools and steps to change it
Is there any specific torque for tightening the belts?
Is it difficult to remove the high pressure hose?
OK so what i need is a new Pump, and do i need a p/s Gasket kit?
Also I would like to know how to bleed the p/s system?
THANK YOU ALL .ORG IS THE BEST
and sorry if this is a repost of anything and asking so much. i couldnt find any specific answers
Old Oct 7, 2008 | 06:17 PM
Greeny's Avatar
¯\(°_o)/¯
It may not be the pump itself leaking, check the high pressure hose for a break/leak in the hose.
you will need to clean up the engine bay area of the leak with engine degreaser and a water hose. then refill the system with DEXTRON III!!...start the car...turn the wheel from lock to lock a few times...then pop your head under the hood/under the car with a good flashlight...start looking for the source of the leak.
Old Oct 7, 2008 | 06:30 PM
coolsun's Avatar
im sure i think it is the pump because its makeing a grinding noise like before, when i had it replaced it stoped. then i do want to update all my old hoses, so can u point me out the hose, thanks
Old Oct 7, 2008 | 06:34 PM
Greeny's Avatar
¯\(°_o)/¯
It's making that noise because the sytem has been depleted of fluid from a leak somewhere..a brand new pump installed and ran without any fluid will make the exact same noise...CHECK FOR LEAKS ELSEWHERE FIRST!
Old Oct 7, 2008 | 06:38 PM
coolsun's Avatar
Its not fully empty though n i refilled it when i got home today
Old Oct 7, 2008 | 06:42 PM
Greeny's Avatar
¯\(°_o)/¯
The p/s sytem is probably full of air pockets now from the leak..
meh nevermind...now that i think about it, you probably have a bad pump also due to using the wrong fluid.
but still..look for the source of the leak before just blindly replacing the pump...
Old Oct 7, 2008 | 06:44 PM
coolsun's Avatar
ok thanks for the help, i wanna drain it first so i can see the blood flow, as in seeing where leak is coming from, How do i drain the old because i know the resovior wont be all of it
Old Oct 7, 2008 | 06:47 PM
Greeny's Avatar
¯\(°_o)/¯
ok thanks for the help, i wanna drain it first so i can see the blood flow, as in seeing where leak is coming from, How do i drain the old because i know the resovior wont be all of it?
Create a leak via low pressure hose removal..
Old Oct 7, 2008 | 06:49 PM
coolsun's Avatar
im sorry, but idont know where its located =) sorry to annoy u
Old Oct 8, 2008 | 04:01 AM
Greeny's Avatar
¯\(°_o)/¯
Disconnect the low pressure hose at the fluid tank, run engine, the fluid will drain out of this hose as the engine runs, as it is draining out, continue to pour dextronIII fluid into the tank, it will eventually all turn red coming out of the return hose.
you might accidentally find your leak if you look around in the engine bay while you are draining the system of the wrong fluid.
Old Oct 8, 2008 | 04:04 AM
Greeny's Avatar
¯\(°_o)/¯
Here is a useful thread on high pressure hose removal, and the the p/s system bleeding procedure.
http://forums.maxima.org/3rd-generat...ld-people.html
Old Oct 8, 2008 | 06:17 AM
internetautomar's Avatar
mod or sell?
is that pic from the 3rd gen FSM?
I don't recall seeing any with a cooler. it looks alot like my 4th gen setup, right down to the drops coming out of the cooler's hose connections!
Old Oct 8, 2008 | 07:17 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i have a cooler loop i'll check my parts car to see if it has one too.
Old Oct 8, 2008 | 07:32 AM
BenStoked's Avatar
Jesus was a Zombie.
yeah. I have a cooler too.
Old Oct 8, 2008 | 01:33 PM
Greeny's Avatar
¯\(°_o)/¯
yes nooblet, it's a 3rd gen fsm pic.
The wifeys vg auto has one.
Old Oct 8, 2008 | 01:35 PM
but your VE doesn't?
Old Oct 8, 2008 | 01:42 PM
Greeny's Avatar
¯\(°_o)/¯
I've never seen a ve with one.
Old Oct 8, 2008 | 01:48 PM
prolly cost-savings to help afford those extra 12 valves haha
Old Oct 8, 2008 | 02:13 PM
Greeny's Avatar
¯\(°_o)/¯
More room for pretties
Old Oct 8, 2008 | 02:16 PM
my valve covers are black too yaknow!
i need to cut the zipties on my hood to check my own PS fluid level. after i replaced the tierods and had the car on jackstands for a month doing other crap and not having money for parts... i turned the wheel and the fluid started spurting out the CLOSED PS resevoir.... i was worried it was a problem but after i started the motor i guess it sucked it back in. i wonder if I lost much fluid tho.
Old Oct 9, 2008 | 04:40 PM
coolsun's Avatar
hey I have the extra cooler loop on my VE
anyway the only tools i need to remove the power steering pump and the high pressure hose is, sockets and a large close end wrench right?
and there are 2 small screws and a lage one holing the pump right?
Old Oct 9, 2008 | 06:59 PM
mod or sell?
I haven't owned a 3rd gen in roughly 2 years. my paperback FSM is sitting in my dresser. I also never had occasion to worry about anything in front of my radiator. the only reason I even noticed the dang thing on my I30 is because the sucker is leaking.
Old Oct 9, 2008 | 08:50 PM
Pearl93VE's Avatar
I can has?
We should start a club...
lowpost99
Oct 26, 2025 06:53 PM
Fbana41
Aug 29, 2016 12:18 PM
rbarnes
Dec 31, 2015 06:29 PM
Mochedda
Dec 15, 2015 11:27 AM
fastcarny
Oct 12, 2015 07:06 AM
