How Do Mechanics Pinpoint The Exact Source of an Exhaust Leak?
Old Oct 13, 2008 | 11:28 PM
1993-VG30E-GXE's Avatar
In plumbing I remember a guy sprayed soapy water on pipes to check for leaks. Does anyone know the common procedure the garage uses?
By listeneing very closely to the repetitive crackling/putting sound coming from the engine when I hit the accel, i'm not exactly sure right now that the leak is in fact coming from the snapped off front exhaust manifold stud. It does sound like it's coming from the engine but I don't know where.
It can't be post LH & RH Manifold to Y Pipe flange, since those components have already been replaced.
Old Oct 14, 2008 | 12:15 AM
Pearl93VE's Avatar
I can has?
Cram a shopvac hose/leaf blower in the end of your exhaust pipe while the car is cool and craw under there and check for any air leaks you can around the suspected area's.
Old Oct 14, 2008 | 06:10 AM
Greeny's Avatar
¯\(°_o)/¯
There are two(2) places where exhaust leaks typically/most commonly occur on these cars...
1. Broken exhaust manifold studs.
2. Broken y-pipe flex section..
The putting sound you are hearing is most likely from broken exhaust manifold studs, look for black soot around the manifold flanges where they mount up to the heads.
Old Oct 14, 2008 | 06:33 AM
KRRZ350's Avatar
When it's not obvious/can't see soot- I like to put the car on the lift while it's running and use just the hose end of my automotive stethescope, works killer. However, you said at least one manifold stud is snapped...............
Old Oct 14, 2008 | 06:56 PM
1992maximase30's Avatar
or you can try a lil tranny fluid.
it works like seafoam...cept its waay cheaper.
Old Oct 17, 2008 | 07:50 PM
burhan92SE's Avatar
or u can close the muffler tips with something for like 4 or 5 secs depends while engine running and i m sure the smoke will be coming outta the leak and then u will know where to look around...
Old Oct 17, 2008 | 07:53 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
uh......... i wouldn't suggest that.... seems kinda risky...
Old Oct 17, 2008 | 07:58 PM
burhan92SE's Avatar
i know but wen i had a leak in my exhaust, i couldn't think of anything easier than that and it worked
Old Oct 18, 2008 | 05:36 PM
internetautomar's Avatar
mod or sell?
smoke machine
/thread
Old Oct 18, 2008 | 06:53 PM
aminus21's Avatar
To pinpoint my exhaust leak, I let the engine suck up some seafoam through the brake booster hose..
Old Oct 18, 2008 | 08:44 PM
Aminus, you may want to think twice about using seafoam in the engine. I read a tech bulletin from Nissan that said NOT to use fuel additive cleaners or cleaning solutions in the engine, supposedly it may damage some seals. I used seafoam in the past but I'm staying away from it for now.
Old Oct 18, 2008 | 09:22 PM
coolsun's Avatar
you can always go to the beach on the sand n rev the car to see where the sand is blowing
Old Oct 19, 2008 | 11:40 PM
burhan92SE's Avatar
wat if u dont have a beach?
Old Oct 26, 2008 | 05:05 PM
ProphetVG30E's Avatar
buy sand, or some really soft-powdery stuff??!?!?!?!?! OR u can jus use the smoke thru tailpipe trick, i 4got wut kind of gas it is tho.
captchaos
Mar 15, 2016 12:18 PM
Hdnseek
Sep 9, 2015 05:55 AM
TheMafia
Sep 4, 2015 08:26 AM
