what this could be?
Old Oct 17, 2008 | 02:36 AM
burhan92SE's Avatar
what this could be?
ok i have this weird problem in my VE....wen i put the car in D it shakes the whole car as in the video i m holding the camera and wen i put the car in D my camera shakes too as i m holding it....i mean i have my foot on the brake pedal and i put the car in D and it jus shakes the whole car and then its all normal wen i m driving it.....sorry but i didnt know how to explain this or show this cuz it have to be a video....heres the videos
http://www.youtube.com/watch?v=umPHH1-wW5Q
Old Oct 17, 2008 | 07:17 AM
mikekantor's Avatar
Video i kinda useless, but shaking is generally caused by an imbalance in the output of power between the cylinders. Check these things and you will find the problem among them: injectors, coils, compression, engine mounts.
Old Oct 17, 2008 | 07:30 AM
He's exactly right. Just check the injectors, coils, compression, and engine mounts. You will certainly find the problem somewhere there.
Old Oct 17, 2008 | 07:42 AM
Greeny's Avatar
¯\(°_o)/¯
Don't forget cleaning out the t/b and iacv thoroughly with throttle body cleaner( not carb cleaner) Be sure to buy a new iacv gasket before you remove the iacv, they are about $4 from the dealer
Cleaning these two items may solve your problem without blindly replacing expensive parts first.
Old Oct 17, 2008 | 08:01 AM
Greeny's Avatar
¯\(°_o)/¯
It would also be a good idea to check all your vacuum hoses, a few cracked or broken hoses could effect idle when put in gear.
Hell, as cheap as vacuum hose is ( about $1 per foot) i would just buy about 10 ft of it and just replace all of them.
Old Oct 17, 2008 | 09:13 AM
Pearl93VE's Avatar
I can has?
Is your car fine when driving around? Does it accelerate normally without any kind of miss or hesitation? It is unlikely that it will be the injectors or coils if the car drives completely normal. Definitely clean out the IAC and TB like Wayne suggested, check vacuum lines, and clean out all the electrical connectors you can find with a fine wire brush and some electrical contact cleaner (MAF, ECTS, IAC, TPS, etc.)
Old Oct 17, 2008 | 09:16 AM
internetautomar's Avatar
mod or sell?
didn't you recently clean a bunch of electrical connectors?
Old Oct 17, 2008 | 09:49 AM
gapboi210's Avatar
Check your mounts too
Old Oct 17, 2008 | 10:50 AM
Pearl93VE's Avatar
I can has?
I can't keep track. There are three or four members I consistently confuse with each other.
Old Oct 17, 2008 | 07:10 PM
burhan92SE's Avatar
could it be Dropping Resister by any chance? cuz FSM states that resistance should be between 11.2 - 12.8 and i have 13.2 ohms
Old Oct 17, 2008 | 07:23 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
i somehow doubt it... that would affect how it shifts between gears... being in drive is nothing but TC drag.
Old Oct 17, 2008 | 08:01 PM
burhan92SE's Avatar
and my coils resistance seems higher....suppose to be around 0.8ohmes and i have 1.3 ohms on all coils....i don think a lil higher matters does it?
Old Oct 19, 2008 | 09:23 AM
GUS'MAXIMA's Avatar
I had the same problem. Check to see which cylinder has a problem by putting the car on and in drive then disconnect the cables from each coil. They should all have an effect on the car except for the one that has the problem. The check the sparkplug and then if nothing check the injector with the ohms meter to see if it gets a reading. I had a messed up injector fixed it and now there is no shacking.
Old Oct 19, 2008 | 06:01 PM
burhan92SE's Avatar
i disconnected my all coils and injectors one by one while engine running and all effected engine running..so it means they all r gud....it is something related to TRANNY....
can someone point me to where to download 4th gen FSM?...
Old Oct 19, 2008 | 06:09 PM
Greeny's Avatar
¯\(°_o)/¯
Have you checked/cleaned/replaced ANY of the things in my posts????
Why do you want to download the 4th gen fsm??
Old Oct 19, 2008 | 07:33 PM
burhan92SE's Avatar
i didn't clean the TB and iacv yet but i checked all my vacuum lines and they r all gud....
and i wanted to download the 4th gen fsm cuz if i have the the wrong tranny from 4th gen ( as cap stated ) then the Transmission self diagnose from 4th gen should work on my VE cuz 3rd gen TRANNY self diagnose doesnt work on my tranny....so i might as well give it a try....?
edit : and ya one more thing wen my car shifts from 1st to 2nd gear it kicks...and shakes the whole car..
Old Oct 19, 2008 | 07:35 PM
Greeny's Avatar
¯\(°_o)/¯
Clean both items and report back..
you don't have a 4th gen tranny..They will not bolt up to a 3rd gen block.
did you replace the axle yourself?(the one that is sticking out of the trans a little bit)
Old Oct 19, 2008 | 07:43 PM
burhan92SE's Avatar
dats my biggest concern why i m having all these problems....that LSD axle is still dere and sticks a lil out...and i cant figure it out which axle to put there....cuz i have that shinny PIN in my tranny and on the other hand as i heared that VE cant have dat cuz they r all VLSD...then how come mine have that? and which axle to put there? VG's? and my tranny code ends with V
Old Oct 19, 2008 | 07:47 PM
you don't have an actual 4th gen tranny, per-se... you have the equivalent of it. so the diagnostics will still be for the 3rd gen tranny.
to greeny: i've seen some pictures of his tranny and stuff and he does NOT have VLSD. confirmed by hands-on knowledge of my own trannies, as well as FSM and Nissan FAST parts diagrams.
Old Oct 19, 2008 | 07:57 PM
burhan92SE's Avatar
even tho my VE have all these problems but the acceleration is CRUSHING....it could be cuz of this tranny ? just wondering
Old Oct 19, 2008 | 08:18 PM
well it all depends how the car is behaving. if you are revving the **** out of it and the car isn't going... you have a slipping tranny. if the tachometer never makes obvious motions like shifting gears then you may be stuck in failsafe (reverse, neutral, and 3rd gear only). or if it does look like it's shifting and you are just down on power then that's the fuel/engine you need to look at
Old Oct 21, 2008 | 07:31 AM
Greeny's Avatar
¯\(°_o)/¯
All axle issue posts have been merged into burhan's axle thread..
Old Oct 22, 2008 | 08:53 PM
burhan92SE's Avatar
i cleaned my TB and IACV and it didnt help me fixing this thing but ya it helped alot wen i push the accelerator and car jus goes....could it be dropping resister? ( sorry to repeat again but i have a feeling dat this is dropping resister) where can i get this resister? any electrical shop? and wat should i say to them... i need 13 ohms dropping resister or there is something else to fix this.....
Old Oct 22, 2008 | 09:03 PM
i might still have mine somewhere....... i can look this weekend
Old Oct 22, 2008 | 09:06 PM
Pearl93VE's Avatar
I can has?
I seriously doubt it has anything to do with your drop resistor. It just means you'll have 100% line pressure between shifts. So if you have crap motor/transmission mounts your Park to Drive shift will "THUMP" into gear, and 1st-4th gears will be very harsh if you aren't at wide open throttle.
I can't see how it could at all be related to idle or rough acceleration. Why not just unplug it completely and see how the car reacts?
Old Oct 22, 2008 | 09:11 PM
hey now
let burhan think it's the drop resistor
find part
sell part
profit
Old Oct 22, 2008 | 10:24 PM
burhan92SE's Avatar
hey now
find part
sell part
profit
i didnt see that
Old Oct 22, 2008 | 10:32 PM
burhan92SE's Avatar
ya i unplugged my dropping resistor harness then turned the engine off for 2 mines and started again...and i put it in D while foot on the brake and WOW it jus smashes like engine jus gonna come outtta da car....it kickes more harder than wat i have ritenow.....then i plugged it back and it does it but not THAT HARD...so i guess i should change that resistor....as i have seen it. it jus looks like some piece of metal with ALOT OF RUST ON IT....and its giving me 13 ohms
Old Oct 22, 2008 | 11:23 PM
Pearl93VE's Avatar
I can has?
fine, change it.
Old Oct 23, 2008 | 01:23 AM
burhan92SE's Avatar
fine, change it.
it not that expensive to buy is it? and it doesn't hurt to change it either on a 16 years old car...if its not then i will go ahead look at mounts cuz they r pretty expensive up here $90 each mount....
Old Oct 23, 2008 | 04:56 AM
fine, change it. buy cadaver's old one
hey thanks man
seriously tho i'm thinking mounts on this one...
BURHAN:
crawl under your car and look at your mounts. are they totally collapsed? any hairline cracks/microcracks? any tearing? any burns? if the answer is yes, then go to autozone and get replacement mounts. cheaper than $90 each... motor mounts make WAY more difference in how a car drives than most people will believe... moreso on manual cuz you don't have the softness of the torque converter like you do on the auto... but like me, my car just pisses me off constnaly cuz the entire driveline clunks every time i get on or off the gas.
Old Oct 23, 2008 | 04:59 AM
Greeny's Avatar
¯\(°_o)/¯
Sounds like you have a badly broken rear engine mount..
Old Oct 23, 2008 | 12:18 PM
burhan92SE's Avatar
wow i guess its the experience which talks....my rear engine right side mount's bushing is worn out...( right side while standing front of the car )....i m gonna have change them...dyam that mount is in really tight location under the brake booster...cant even get my ratchets in there...
Old Oct 23, 2008 | 12:24 PM
Greeny's Avatar
¯\(°_o)/¯
That is the transmission mount, i would bet your rear engine mount is just as bad if not worse, and the main cause of alot of your issues. engine and tranny mounts are about the most looked over maintenance item on these cars, but cause more trouble with the running of the car then most people know.
Old Oct 23, 2008 | 12:26 PM
yea that one sucked *** when i was doing the m/t swap.... you may have to get a little creative on that one... and just change one at a time... that way your engine and/or tranny will still be held by the other 3.
Old Oct 23, 2008 | 12:30 PM
i think i'm just gonna jack my engine up and stuff some crap in the front mount for now.... just to keep me sane until i buy a spare set to poly-fill.
Old Oct 23, 2008 | 01:46 PM
Greeny's Avatar
¯\(°_o)/¯
brb w/pics.
Old Oct 23, 2008 | 01:57 PM
Greeny's Avatar
¯\(°_o)/¯
Old Oct 23, 2008 | 01:59 PM
DOING THAT VERY SOON!!!!!!! thanks for the idea
