Loud sqeeking noise....
Old Nov 2, 2008 | 04:09 PM
coolsun's Avatar
this happes when i turn the wheel to almost lock and it seems like its the belts
but can a leaky hose cause this loud noise?
i did replace a new p/s pump n a new high pressure hose n new belts
now the low pressure hose is leaking and i am about to order one right now
but can this cause a loud sqeeking sound? or did i tighten the belts too much?
Old Nov 2, 2008 | 04:19 PM
Greeny's Avatar
¯\(°_o)/¯
any of the belts have p/s fluid on them?
Old Nov 2, 2008 | 04:25 PM
coolsun's Avatar
i doesn't squeek all the time at all but there is some spray of p/s fuild because of the leaky low pressure hose
Old Nov 2, 2008 | 04:33 PM
internetautomar's Avatar
mod or sell?
check your fluid level. my leaky PS hose causes a squeal when it gets low
Old Nov 2, 2008 | 04:40 PM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by coolsun
i doesn't squeek all the time at all but there is some spray of p/s fluid because of the leaky low pressure hose
Replace the hose first and be sure to refill the p/s system with dextronIII fluid, genuine nissan hose prices below.(it's the suction hose btw) just choose the hose for your year/trans/engine type.
http://www.courtesyparts.com/maxima-...1715_1723.html
or you could go with some generic non-pre bent hose from the local auto parts store, just make sure it doesn't touch spinning belts or other moving parts.
Old Nov 2, 2008 | 05:22 PM
coolsun's Avatar
yeah my p/s fuild is all good and now i have to order a new hose and see if thats really the problem or maybe because of the remanufatured p/s pump... i'll see
Old Nov 2, 2008 | 06:04 PM
burhan92SE's Avatar
i m pretty sure its ur hose....cuz i had the same problem and changed the hose and problem was solved....change ur hose and see if still makes that noise....i use A/T fluid in my p/s
Old Nov 2, 2008 | 06:16 PM
coolsun's Avatar
u should drain it out and change it before it kills the p/s pump thats what happened to me, leaked everywhere
Old Nov 2, 2008 | 06:18 PM
Greeny's Avatar
¯\(°_o)/¯
Drain what out?
Old Nov 2, 2008 | 08:09 PM
coolsun's Avatar
Drain what out?
wow NVM LOL i should of read more carefully i was alil sleepy lol
Old Nov 2, 2008 | 08:19 PM
burhan92SE's Avatar
lol wat did u read instead of A\T (AUTOMATIC TRANSMISSION FLUID???....it doesn't kill P/S pump.....i never heared of it....if it does then i just learned something new
Old Nov 2, 2008 | 08:57 PM
coolsun's Avatar
i like glimsed at it n i thought you wrote p/s fuild LOL
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
alahjahwan09
18
Sep 21, 2015 09:12 PM
pears
Sep 18, 2015 05:25 AM
KGMtech
Aug 18, 2015 09:21 AM
