speed sensor or cluster
Old Dec 30, 2008 | 08:04 PM
Justinleo1984's Avatar
ok haven't been here in a while but mainly due to no money for parts. I saved up bought new injectors and my 92 gxe auto is running good. my speedometer stopped working along with the odometer. i changed the cluster (wanted white faced gauges anyway) and still no luck. there are no codes on my ecu 55 all the way and the only thing i can think is the speed sensor and wouldn't it set off a code if it was bad?
Old Dec 30, 2008 | 08:34 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
unplug the speed sensor and see if the car behaves any different. Also, does cruse control currently work?
Old Dec 31, 2008 | 01:21 AM
burhan92SE's Avatar
dude its either ur speed sensor...or the harness behind the cluster has busted wires ( lose wires )....chek both and i guess u will find ur solution...
Old Dec 31, 2008 | 05:24 AM
Ok I checked the wiring, and its all good. Is there a way to test the sensor without removing it because it seems like its realy hard to get to? Also anyone who has removed this tell me how/what size it was because space is limited in there.
Old Dec 31, 2008 | 05:36 AM
BenStoked's Avatar
Jesus was a Zombie.
if your cruise works, its the wiring, if not, its probably the speed sensor.
I am assuming you checked fuses?
Old Dec 31, 2008 | 05:40 AM
speedometer fuse? i would think that all the dash is hooked up together on one fuse and all the other stuff on the dash works. am i wrong? going to go hop in the car and go down the road and see if the cruise works.
Old Dec 31, 2008 | 06:09 AM
BenStoked's Avatar
Jesus was a Zombie.
still, cant be too sure, unless they are all (meaning every single one) gets checked.
Old Dec 31, 2008 | 06:23 AM
Greeny's Avatar
¯\(°_o)/¯
cruise will not work without a functioning speed sensor...
Old Dec 31, 2008 | 06:43 AM
internetautomar's Avatar
mod or sell?
1. it probably is the speed sensor.
2. before you replace it, it sometimes has a plastic/rubber plug on the top that pops up and causes it to fail. if you push that plug back down it may work again. Cheaper than a new sensor.
Old Dec 31, 2008 | 08:35 AM
ok checked the cruise not working. and sometimes it feels like my car's transmission is in safe mode like now is there a way to reset this i checked everything and it seems fine was leaking fluid and got a little low would this cause it to go to safe mode?
Old Dec 31, 2008 | 10:38 AM
300zmax's Avatar
run the trans diagnostic. http://forums.maxima.org/3rd-generat...nsmission.html
Old Dec 31, 2008 | 12:53 PM
Originally Posted by 300zmax
at this point i wouldn't call that necessary. No speedo, no odometer/trip, no cruise, not shifting at proper times, if at all (failsafe). That's a dead giveaway for the VSS if i had those symptoms on my own car.
Good news is the OP can enjoy his new sexah SE gauges instead of the plainjane GXE ones.
Djsmaxima
Sep 14, 2015 11:58 PM
Max139617
Sep 6, 2015 06:02 PM
sdotcarter
Sep 2, 2015 09:53 PM
