Easily remove Comfort Control?
Old Jan 13, 2009 | 07:51 PM
Mysticcal's Avatar
What's the trick? I unscrewed all the front screws I could see but there's the 2 mounting plates on the side blocking it in from the plastic infront of it.
thanks.
Old Jan 13, 2009 | 07:58 PM
BenStoked's Avatar
Jesus was a Zombie.
wat?
climate control?
power/comfort switch?
PICS?
Old Jan 13, 2009 | 08:18 PM
Mysticcal's Avatar
the thing that makes cold air come from your vents. or hot air. or..... lukewarm?
manual version.
I completely pushed the "temp" tap inside the thing. i think it's time for a fix on that stupid plastic track.
Old Jan 13, 2009 | 09:29 PM
burhan92SE's Avatar
manual version.
jus pull those mounting plastic plates to the point where u think its jus gonna break...then gently take ur climate control out ( its a short cut )
other wise u can take ur speedo meter cover and the front cover that covers around ur climate control and stereo etc etc...
Old Jan 13, 2009 | 11:40 PM
gapboi210's Avatar
yeah gotta love how they are mounted from the back. if you unbolt enough stuff you can push the unit in then turn it sideways to access the harnesses on the back of it
Old Jan 14, 2009 | 08:41 AM
Matt93SE's Avatar
STFU n00b!
remove radio.
push climate control crap in and down into the radio hole.
that's how I did it.
Old Jan 22, 2009 | 12:32 PM
Mysticcal's Avatar
Sorry to bump this but I haves a problem. my track is completely busted. i would like to upgrade to auto climate control but the odds of me finding one and then the undertaking would be big.
is there any other comfort control that wont break as easily? i actually think my only other option is removing the track completely dremeling a small nook into the space where it used to be and installing some sort of metal product of the same size into it.
Old Jan 22, 2009 | 12:39 PM
maxitech's Avatar
Umm...Engrish, please? What broke and what is this 'track' you are referring to?
Old Jan 22, 2009 | 03:22 PM
internetautomar's Avatar
mod or sell?
the track does not break easily, people just don't take the time to keep it clean and lubricated.
Old Jan 22, 2009 | 03:27 PM
Matt93SE's Avatar
STFU n00b!
I've had mine sieze up several times on different 3 gens I've owned/driven. The wya I fixed them was to use an xacto knife and smooth the edges on the slider. what happens is they dig in at an angle and create a ledge.. then it gets stuck there again.. and worse.. makeing the problem worse.
So I took it apart and smoothed over the edges with a razor knife and the problem went away. last time I had to fix the one in my VE was 8 years ago.
Soooooo.. If yours is broken, go to a junkyard and get another manual climate control unit. check the slider before installing it. if it's got any grooves or dings in it, clean them up. then install the 'new' unit and move on with life.
and no.. you do NOT want to try to instal an auto climate control in your car. you have to replace everything under the dash.
Mar 12, 2020 12:06 AM
Starrider
Dec 18, 2015 04:43 AM
jc53
Oct 12, 2015 05:12 AM
carid
Sep 17, 2015 05:00 AM
EdRomo86
Sep 12, 2015 07:49 PM
