Back Firing From The Intake?
Old Jan 15, 2009 | 07:35 PM
KaneStyles's Avatar
Alright, i have a 1994 nissan maxima sohc autmatic v6 3.0. I started the car and im hearing a back fire coming from the intake manifold i dont know why the plugs and spark plugs are brand new. timing is set didnt do it with a timing gun just loosen the distrubutor bolt and turned it till it was smooth... uhm E G R pipe is broken but fixed it with sum liquard metal and high temp sliacon... uhm Clean the entire throttle body and put on gaskets back on... so my porblems are 1 Back firing form the Intake.
2 Car has No power
3 Step on gas Bad Reaction time for speed takes to long to get going....
4 hooked it up a diagonise machine that is 15,000 dollars and told me its nothing wrong wit it.... WTF!!!..
5 No response from transmission when on daigonse machine....
if anyone can help greatly appriecated " and i know my spelling isnt great"
Old Jan 15, 2009 | 07:54 PM
LvR's Avatar
LvR
So let me get this right..................
You cannot be bothered to set the timing properly and you then use a $15000 machine that cant tell you **** about either your timing or your anything else? ............... yet still complain?
You looking for attention?
Old Jan 15, 2009 | 08:31 PM
akurtzer57's Avatar
Does it ever smooth outwhile driving?
Old Jan 15, 2009 | 08:45 PM
Dhunterx's Avatar
If the car always feels rough and feels like it's running on 5 or less cylinders, you could have bad injectors.
Old Jan 15, 2009 | 08:53 PM
BenStoked's Avatar
Jesus was a Zombie.
make sure everything is correct, before assuming it is.
Old Jan 16, 2009 | 02:17 PM
Tampamaximus's Avatar
Your timing is off. Your caveman timing technique is not even close to accurate.
Old Jan 16, 2009 | 08:50 PM
CMax03's Avatar
it's overly advanced!!!
Old Jan 18, 2009 | 05:48 AM
Tquick's Avatar
Instead of using a $15000 machine that tells you nothing, how about trying a $20 timing light, and getting the timing set RIGHT, then if it's still backfiring, post again.
Old Jan 19, 2009 | 10:48 PM
xx-Marshall-xx's Avatar
kthxbye2u
check out the injectors see if they are malfunctioning or bad contacts with the spark plugs....check it
http://forums.maxima.org/3rd-generat...s-missing.html
Old Feb 5, 2009 | 07:13 PM
KaneStyles's Avatar
re set the timing now its not backfiring but as soon as i step on the pedal no power car stalls out and then shut off also i look at the engine and the exhaust manifold pipe going down was Red fire hot... going to change the termostate and the engine temp sender
Old Feb 5, 2009 | 07:15 PM
KaneStyles's Avatar
how do i set the timing then??
Old Feb 5, 2009 | 07:20 PM
BenStoked's Avatar
Jesus was a Zombie.
timing light. 15* btdc, I believe.
Old Feb 5, 2009 | 07:24 PM
BenStoked's Avatar
Jesus was a Zombie.
http://forums.maxima.org/3rd-generat...nt-videos.html
Old Feb 5, 2009 | 07:32 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
this is to be done on a warm engine with the tranny in park/neutral, at idle.
get a timing light and put the pickup on the #1 cylinder wire. shine it down at the crank pulley (there's an arrow pointing at the timing marks) and what you want to see is the arrow pointing at the 4th mark from the left.
0...5..10.15.20.25.30
if it is wrong, at the base of the disty there is a 14mm-headed bolt (also phillips head screwdriver will work... but sockets > screwdrivers 99% of the time on those type of bolt/screw combos). loosen that just a little bit, and then turn the whole distributor a little bit until it does line up with the 15 mark. once it lines up, tighten the lock bolt at the base of the distributor. rev the engine a few times, then let it idle again for a few seconds, and shine the timing light again to make sure it's still right.
Old Feb 5, 2009 | 07:39 PM
burhan92SE's Avatar
fix ur timing and get ur PCV system checked....
Old Feb 5, 2009 | 07:46 PM
Matt93SE's Avatar
STFU n00b!
take it to a shop. you've ****ed around with it enough.
Old Feb 5, 2009 | 08:44 PM
chrome91's Avatar
Old Feb 5, 2009 | 08:51 PM
turbizzy's Avatar
I know the obvious had already been stated but for sure set the timing right, make sure your injectors are good by testing the resistance of them with a warmed up engine and lastly it may be a faulty distributor (cam sensor). I've seen distributors do funny crap on VGs, kinda act like rev limiters but at low RPM like 2-3,000. In some cases you can connect the Consult and put it in Real Time data monitor mode and floor the engine and watch a camshaft position sensor code pop up even with no check engine light.
Old Feb 7, 2009 | 08:01 AM
KaneStyles's Avatar
getting it towed on this tuesday to sts to find out whats really wrong witht the timing and i thikn my water pump is bad cause the anti freeze is not running threw the engine if thats the case i am just going to the junkyard and get another engine and get a vg engine and make sure everything is running in it proper.. my exhaust manifold down tube pipe gets red hot actually see it red and the pushed on the top radiator hose and didnt feel any coolent going in and resover tank is full of coolent... could this be cause by the timing to? and i know its my timing now....
Old Feb 7, 2009 | 06:33 PM
turbizzy's Avatar
Your cam timing might also be off. If your gonna do the water pump it would be a good time to change the timing belt, tensioner, thermostat, cam seals and crank seal while your in there. Then you can be sure you have your cam timing dead on, then set your ignition timing.
Or just take it to the pros like you've mentioned.
Old Mar 10, 2009 | 06:53 AM
KaneStyles's Avatar
alright the timing was set to perfect the car runs fine now towed to STS they are great they only charge me 2 chicken mailno subs and 2 snapples lol there are great lol
alright now the car is running great now i need a turbo for it any idea's?
Old Mar 10, 2009 | 07:31 AM
Matt93SE's Avatar
STFU n00b!
DO NOT EVEN ATTEMPT TO TURBO YOUR CAR!!!!
Old Mar 10, 2009 | 07:45 AM
internetautomar's Avatar
mod or sell?
buy a factory turbo car
Old Mar 10, 2009 | 12:25 PM
+1, where "1" is then substituted for the largest number the human brain can comprehend.
like... even if you paid a shop to take your car for a month and give it back turbocharged..... somehow, i just know something wouldn't end well for you or someone else.
Old Mar 10, 2009 | 12:54 PM
Matt93SE's Avatar
STFU n00b!
turbocharger + stupidity + lead-foot syndrome = quickly dead Maxima.
Old Mar 10, 2009 | 01:23 PM
i was more worried about potential injuries to people when he wrecked it.. passengers or people in other cars, etc. a car is just a car... you can get another one, even if you cry over it. can't get a person back.
Old Mar 11, 2009 | 06:15 PM
Governor's Avatar
This is the funniest thread I have EVER read on here... LMFAO!!!!!
Old Mar 14, 2009 | 02:56 PM
KaneStyles's Avatar
ok so quickly dead maxima uhm NO! this is my temp engine right now untill i install the vg30de engine it with transmission computer and harness so yea right now i want a turbo i can care less if this engine dies within 2 years cause its a junk yard engine in it but it fines fine and only 36000 miles on it from where orginally where the engine came out of the car..... So if u have any idea's on a turbo or supercharge for a 1994 nissan maxima sohc v6 3.0 vg30e engine automatic please let me know cause im most def putting a turbo or supercharger in it..... THANK YOU!
Old Mar 14, 2009 | 03:03 PM
KaneStyles's Avatar
also im looking for a nice guage cluster cause i broke mine the rpm's and speed sensor doesnt work but all the other gauages work as for the fuel engine temp works fine
Old Mar 14, 2009 | 03:12 PM
Matt93SE's Avatar
STFU n00b!
http://www.turbonator.com/index.html...TurbonatorBase
Old Mar 14, 2009 | 03:24 PM
is the bikini model included in the kit?
Old Mar 14, 2009 | 03:31 PM
"dead maxima" meant that if you couldn't even handle the problem that you created this thread about and just threw in the towel and took it to a mechanic, that you DEF can't handle a turbo, period. The maxima would die in a wreck, not because of the turbo. there is no supercharger for this car. and epic lawls @ boosting a VG auto.
and what's tihs about eh VG30DE? you can't put one in this car. won't fit under the hood. and the only transmissions that went with the VG30DE are for RWD, and don't even bother trying to say you're making your car RWD, because you can't even handle an intake backfire, good luck doing RWD (which precisely zero people have done. so don't ask us for tips.)
Old Mar 14, 2009 | 06:25 PM
Maxpwer's Avatar
No turbo, no care!
If he cant fix his timing, how is he going to getting it running with a turbo? I wouldn't worry much about a wreck....
Old Mar 14, 2009 | 09:02 PM
chrome91's Avatar
doing a turbo and engine swaps of that measure should be left to people who did years of research like joeboost
JRod28
Dec 29, 2023 09:56 PM
95Maxi
Aug 29, 2015 09:38 PM
sonic7
Aug 20, 2015 12:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Maxboy23
Aug 11, 2015 11:59 AM
