4th gen fuel rails
Old Feb 5, 2009 | 07:58 AM
redwood_usa's Avatar
4th gen fuel rails
do any of the 4th gen fuel rails work with a 93- 94 SOHC?
Old Feb 5, 2009 | 08:08 AM
Matt93SE's Avatar
STFU n00b!
most likely not. why would you want to bother? the factory fuel rails support tons of power.
Old Feb 5, 2009 | 08:32 AM
300zmax's Avatar
just use later 4th gen injectors. they fit the connectors on the 93-94 engines. some claim better performace. but there is a thread about that from not all that long ago. stick with stock fuel rail, it will hold just fine. but i suggest replacing the rubber fuel line on the rails.
Old Feb 5, 2009 | 09:34 AM
Greeny's Avatar
¯\(°_o)/¯
Guys, i think he wants to know if they(4th gen rails) are a direct swap onto the vg lower intake manifold.
--> http://forums.maxima.org/3rd-generat...d-gen-max.html
Either way, i don't think they are a direct swap, you will have to remove the injectors from the 4th gen rails.
Old Feb 6, 2009 | 08:12 AM
Exactly - I have the option of buying 4th gen injectors in a 4th gen rail or a set that's not in the rails. I guess I should just buy the one already out of the rail so I dont have to bother removing them.
Old Feb 6, 2009 | 08:16 AM
Greeny's Avatar
¯\(°_o)/¯
Actually, they can be removed from the rails quite easily.
http://www.viddler.com/explore/MyGreenMax/videos/5/
Old Feb 6, 2009 | 08:28 AM
300zmax's Avatar
cool vid. i pulled my out with a strap wrench i made up. but i like your method BFH!
MAXSE5SPD
Sep 17, 2022 04:00 AM
Violator
Sep 9, 2015 10:14 AM
Hdnseek
Sep 9, 2015 05:55 AM
Lowered_a33
Sep 1, 2015 07:49 PM
