Best spot to drill a hole in the firewall?
Old Feb 11, 2009 | 01:09 PM
cardana24's Avatar
Blown
Where do you guys normally drill the firewall to get wires though? I need to to run my existing wire for my oil pressure gauge though there and also i am getting ready to put in an aftermarket stereo and I need to run a 4 gauge wire to the truck as well. Is there a tinplate? I know a lot of fourth gen guys drill in the same spot. Any pics or tinplate for the best spot?
Old Feb 11, 2009 | 01:17 PM
Matt93SE's Avatar
STFU n00b!
WTF is a tinplate?
do you mean template?
I pulled the inner fender liner and drilled a hole above the dead pedal.
http://blehmco.com/pics/car/interior/alarm/
(start at first pic)
Old Feb 11, 2009 | 01:51 PM
cardana24's Avatar
Blown
Originally Posted by Matt93SE
WTF is a tinplate?
hahahah...yeah sorry I am a spelling genius.
Thanks for the pictures.
Is this where eveyone drills?
Old Feb 11, 2009 | 01:54 PM
Greeny's Avatar
¯\(°_o)/¯
Gee whiz, Batman! That yellow cable is big enough to power Manhattan!
Old Feb 11, 2009 | 03:29 PM
Matt93SE's Avatar
STFU n00b!
Welding cable FTW.
$0.85/foot for 1/0 cable.
Old Feb 11, 2009 | 03:34 PM
Cinnamint's Avatar
I drilled a hole in the rubber around the main harness. I don't want to drill in metal, might start a rust party. I was only running 4 gauge tho.
Old Feb 11, 2009 | 08:57 PM
chrome91's Avatar
i'll try to get a pic where i drilled mine, when i got a guy to help me wire up my subs he drilled somewhere on the driver side to get the wires through
Old Feb 12, 2009 | 01:29 AM
burhan92SE's Avatar
i have my 4g cable and another 8g cable and few more 16 g cables going through the same stock firewall hole...dont ask how i did that but i will post the pics tomorrow...
Old Feb 12, 2009 | 06:30 AM
cardana24's Avatar
Blown
I you guys could post some pictures I would appreciate it. Thanks.
Old Feb 12, 2009 | 07:37 AM
Matt93SE's Avatar
STFU n00b!
For a smaller wire, you might be able to shove a screwdriver through the main harness seal, but I wouldn't recommend doing it for anything bigger than about 8awg. expecially if drilling. Too much risk of hitting a wire inside it or behind it and FUBARing the harness. Maaan I'd HATE to have to pull that harness out of the car to fix that!
Old Feb 12, 2009 | 01:16 PM
hoyshnin's Avatar
Baby's on the Half Tip!
If you take off the fender on the driver's side front wheel (take off the wheel as well, it will be much easier) you'll see a bunch of wires going into the area under the dash. I (and I think others of you above as well) just pushed my 4 gauge wire through there. I found the most effective way to to it was to tape the end of the wire onto the end of a wire hanger and push it through that way.
Old Feb 13, 2009 | 08:35 PM
speedtrap410's Avatar
When i installed my amp kit i drilled a hole in my firewall behind my brake pedal. Maybe 1/2 in in diameter. later on I ran a couple more wires through it. For me it seems to be an easy way to run whatever you need into the engine compartment.
My amp wire is about the size of that yellow cable you have... rock on!
Old Feb 13, 2009 | 08:53 PM
chrome91's Avatar
just took a look at my amps wiring today and yep, exact same thing. right behind the brake pedal
Old Feb 13, 2009 | 10:56 PM
ColombianMax's Avatar
Amen to that
Old Feb 16, 2009 | 04:09 PM
nickgzzjr's Avatar
What I did was that I drilled a hole where the clutch petal should go, but that's because my car is an automatic, i don't know about yours.
sliptap
Sep 30, 2015 05:57 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
