speaker amp?
Old Mar 8, 2009 | 12:10 PM
BruceM99's Avatar
speaker amp?
Im looking to get a amp for my speakers because the stock amp isnt giving much power to the front speakers, dose any one have an idea of what kind i should get? i have aftermarket Infinity - 6" x 8" Custom-Fit 2-Way Car Speakers in the front 180 watts peak power (60 watts RMS) and 6x9 pioneers in the back( not sure what kind) but the back speakers sound great. i also have an aftermarket alpine head unit, and its not the bose system
Old Mar 8, 2009 | 02:24 PM
internetautomar's Avatar
mod or sell?
play with your fader.
Old Mar 8, 2009 | 02:52 PM
BruceM99's Avatar
nope. already tried that its forward 3 and still back speakers are soo much louder iv even bought and installed new front speakers but nothing changed.
Old Mar 8, 2009 | 03:33 PM
mod or sell?
did you bypass the factory amps all around?
you should not be using them with aftermarket equipment
Old Mar 8, 2009 | 03:43 PM
BruceM99's Avatar
If i bypass the amp then wont that make the back speakers not as loud?
Old Mar 8, 2009 | 04:00 PM
sleepyvg30e's Avatar
my speakers didn't work at all till i figured out i had to bypass the amps.... but if u got an alpine head unit u should probably match the amp to the head unit heres a cheap amp i was planning to get for my alpine system
http://www.alpine-usa.com/US-en/prod...model=MRP-F300
Old Mar 8, 2009 | 04:56 PM
BruceM99's Avatar
that's a nice one, my back speakers work amazing and are so loud its hard to notice the fronts are quiet. but it is noticeable and i want them all to be loud.
Old Mar 8, 2009 | 05:30 PM
i had the same problem when i did mine...my front speakers were pioneer and were relatively new so i didn't wana replace them i just got the head unit and these rear speakers: http://www.bestbuy.com/site/olspage....=1166840026861
but as soon as i got them the rears just drowned out the front even though i thought the fronts were loud i still had them replaced the next day because the rears were so loud i had to drive with the fader on 15 just to make it sound balanced....but heres what i got up front try swapping them out they are definetly stonger than your infinity speakers check the stats http://www.bestbuy.com/site/olspage....=1199495218609
Old Mar 8, 2009 | 05:46 PM
BruceM99's Avatar
yea those are 6x9s though, and the front speakers are already brand new i don't think switching them out would do much of a difference, i have already tried.
Old Mar 8, 2009 | 06:09 PM
Phatmatt's Avatar
If you haven't bypassed your bose amps, do it.
your HU already has a amp inside to run your speakers.
if you do not bypass the bose amps, in the long run it will possibly damage either your HU or speakers from what I've been reading from other users. since those amps were made to run speakers @ 1ohms and most aftermarket speakers are 4ohms. to use those amps properly you need a bose HU and bose speakers, otherwise bypass them.
Old Mar 8, 2009 | 06:15 PM
BruceM99's Avatar
as i said earlier i never had the bose system
Old Mar 8, 2009 | 06:18 PM
Phatmatt's Avatar
Sorry I misunderstood
Old Mar 8, 2009 | 07:02 PM
mod or sell?
then you had/have the active speaker system which had/has a single amp in between the 2 rear speakers. BYPASS it, it is the reason the rear sounds louder than the front.
Old Mar 8, 2009 | 07:05 PM
BruceM99's Avatar
yea thank you, but will that make the back speakers quieter?
Old Mar 8, 2009 | 07:13 PM
mod or sell?
yes. right now the amplified rear output from you head unit is being amplified by the amplifier on the rear deck which the factory installed on car with the active speaker system. It only amplified the rear speakers not the fronts.
Old Mar 11, 2009 | 10:21 PM
gladiator's Avatar
is my HU toast or what?
I just got my hands on a used 94 Maxima with the Bose stereo system. I don't know if the HU is broken. The previous owner blames the amp.
When I press power, the antenna goes up but nothing is displayed on the unit.
Seems like people always have issues with this HU.
Old Mar 14, 2009 | 01:52 PM
makowski's Avatar
how do you bypass the amps
Old Mar 14, 2009 | 03:00 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
4 wires on the amp plug. thick wires = power. thin wires = signal. so just put the thin wires on your new speakers and cap off the thick wires.
Old Mar 30, 2009 | 05:32 AM
AlexOS's Avatar
So I tired to bypass my factory amp for the back deck speakers. And I did everything as it was said to do. But when I was done, and turned the car on nothing happened. The radio did not come on, or the clock. After alot of rewiring I got it all to come back on, I had to wire all the wires to their normal selfs, except the yellow wire and the yellow wire w/ green stripe. I had to wire them together. But The radio and clock reset themself's to the default settings each time the car is turnned on and off, and the keypad no longer works with the car off. Does anyone know how to solve this problem?
Old Mar 30, 2009 | 06:25 AM
BenStoked's Avatar
Jesus was a Zombie.
have you tried to check the fuses? i am not sure if the keypad and the constant power to the clock/radio (for maintaining proper time) are on the same circuit, but that should be the first thing you check.
Old Mar 30, 2009 | 07:02 AM
kringle03's Avatar
Accessory line grounded out somewhere so as not to keep in continuous circuit with the battery? People this is not hard... You run and amp kit for the new amp... that doesn't interfere with any existing wiring... You're head unit should be able to push enough power to all your component speakers to just run off it (that is if you're buying quality stuff) and then you simply run the HU to the amp for a Sub line (or your components if you have to have that setup) and boom you're done! The only time you splice into factory wiring is for the HU wiring harness that's it... Never reuse factory amps! It's always a bad idea if you're "upgrading" your sound system.
magiconthetire
Oct 26, 2015 09:03 PM
sliptap
Sep 30, 2015 05:57 AM
Redfox
Sep 28, 2015 10:41 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
