Ball Joint... Stuck
Old Mar 21, 2009 | 02:17 PM
coolsun's Avatar
Ball Joint... Stuck
well all this morning i have been trying to replace my passenger side ball joint. It does not seem to come apart at all. I have removed the control arm and all is left is the ball joint hanging there. I wacked it with the hammer and it still wont move at all. I have tired the ball joint U tool and it oozed all the greece out now....
The question is, how do i remove the ball joint? or i should just go n let someone do it?
Old Mar 21, 2009 | 03:17 PM
Governor's Avatar
They make a gear puller type tool to seperate them but all you should have to do is loosen the crown bolt, give it a good whack with a hammer and it should seperate.
Old Mar 21, 2009 | 03:20 PM
fishforlife2007's Avatar
try heating where it sits with a torch and see if that dont help ya out
Old Mar 21, 2009 | 03:41 PM
300zmax's Avatar
i would have left the LCA on. it makes breaking the joint easer since the spindle wont move.
give the spindle a good rap with a hammer.
Old Mar 21, 2009 | 04:01 PM
Greeny's Avatar
¯\(°_o)/¯
Which part are you "whacking" with a hammer? The ball joint, or the round part it fits into?
Old Mar 21, 2009 | 04:26 PM
coolsun's Avatar
im wacking both parts, i saw in one of your theard's that u wacked the part that it fits into. it did not move at all.
Old Mar 21, 2009 | 04:27 PM
coolsun's Avatar
well i dont want to spend more money on tools that i use once and i saw in other theards that i dont need to use it.
Old Mar 21, 2009 | 04:31 PM
Greeny's Avatar
¯\(°_o)/¯
Don't hit the ball joint dude..You have to hit the round part on the spindle..
Borrow a larger hammer from someone..Or eat a bowl of wheaties and whack the shiet out of it with the hammer you have, multiple times..
If you have access to a propane torch, try heating up the round part only on the spindle, then give a whack.
Old Mar 21, 2009 | 04:39 PM
coolsun's Avatar
so i should heat up the part where its holding the b/j, is it safe to heat it up since i have sprayed on PB plaster, and the greece that came out ball joint? i dont big flames burning my eyebrows off
Old Mar 21, 2009 | 04:42 PM
Greeny's Avatar
¯\(°_o)/¯
wipe off as much of the grease/blaster as you can, they give the area a good spray with brake parts cleaner, this will clean most all the grease left off of it.. be sure to let the parts cleaner evaporate( a minute or two) before putting the torch to it..
Old Mar 21, 2009 | 04:45 PM
coolsun's Avatar
i will try this first thing in the morning. Its getting cold n dark here. Thank you all, i will tell you guys hows it tommorrow
Old Mar 21, 2009 | 05:40 PM
Governor's Avatar
From one of Matts old post's back in '05
"Bah.. slide a small piece of steel plate between the axle and the nut on the top of the ball joint before you remove the nut. then just unscrew the nut and let it press the metal plate against the axle. eventually it will pop the ball joint out and it won't require removal of the axle or damage any parts. easy stuff."
Old Mar 21, 2009 | 06:09 PM
coolsun's Avatar
ohh that seems like it would work
Old Mar 21, 2009 | 08:15 PM
Governor's Avatar
It does but you have to have the LCR on.
Old Mar 21, 2009 | 08:57 PM
gfnk357's Avatar
When I was getting my ball joint off I tried using the pickle fork and hitting it with a normal nailing hammer... nothing happened. I gave up after a while and the next day tried hitting the pickle fork with a 2 pound sledge hammer and the ball joint popped right off.
Old Mar 21, 2009 | 09:07 PM
coolsun's Avatar
wait i thought u have to put it under the axle and on top of the b/j screw then just turn the screw n it will pop the b/j out?
Old Mar 21, 2009 | 09:33 PM
Governor's Avatar
I have never tried this method but in theory it sounds like it should work, you will need a pretty stiff piece of metal.
LCR in earlier post should read LCA...typo, sorry.
Old Mar 22, 2009 | 08:14 PM
coolsun's Avatar
Well i spent 12 hrs all day, i got the ball joint to pop out by letting the b/j nut sqeeze on the axle and then POP the b/j came out. i changed out the control arm bushings too. Thanks Everyone
litch
123
Jan 4, 2024 07:01 PM
tarun900
19
Dec 20, 2021 06:57 PM
D Mason
Jun 21, 2016 04:43 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
